Where is heated seat fuse? - JeepForum.com
post #1 of 10 Old 04-25-2013, 03:35 PM Thread Starter
leadsled jeep
I know wjjeeps.com shows the heated seat fuse is in the front junction box located under the dash to the left of the steering wheel.... BUT....
when I get under there what I see sure doesn't resemble this:
http://www.wjjeeps.com/misc/jblock_main.jpg
How do I find the heated seat fuse??
Thanks all.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #2 of 10 Old 04-25-2013, 03:50 PM
ChrisHager
Administrator
ChrisHager's Avatar
F20 -- 10 Amp -- Red -- Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 10 Old 04-25-2013, 03:52 PM Thread Starter
leadsled jeep
Thanks Chris, I've seen that pic on wjjeeps page as I listed it..... But how do I GET to it?
Looking under my dash I don't see a box that matches at all...
Do I take the lower dash trim off to get to it???
And don't I have to check C2 ?
Chris
post #4 of 10 Old 04-25-2013, 03:57 PM
ChrisHager
Administrator
ChrisHager's Avatar
It's behind a little panel on the lower left side of the steering wheel under the dash. There should be a cover that pops off.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 10 Old 04-25-2013, 04:20 PM Thread Starter
leadsled jeep
Ok, I can se I can get to F20. Thanks.
What about C2 as shown in my link to wjjeeps? Don't I need to check that as well?
I get the lights on heated seat switches to light up but both seats suddenly stopped heating. Must be something in common failed.
I replaced both seat elements a year ago.
Chris
post #6 of 10 Old 04-25-2013, 04:22 PM
ChrisHager
Administrator
ChrisHager's Avatar
I'm not positive. It wouldn't hurt to check C2 though...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 10 Old 04-25-2013, 04:24 PM Thread Starter
leadsled jeep
As I mentioned, do I have to remove lower dash cover by my knees to see the rest? That simple cover down by my feet sure doesn't expose all the rest.
Anyone?
Chris
post #8 of 10 Old 04-25-2013, 06:08 PM Thread Starter
leadsled jeep
Bugger... I removed the dash section .... Seat heaters both still don't work in spite of switch lights activating...
I replaced the fuse F20 and circuit breaker C2.
Any ideas Chris??
Chris
post #9 of 10 Old 04-25-2013, 06:16 PM
ChrisHager
Administrator
ChrisHager's Avatar
It's underneath and can be seen by looking up under the dash.
I'm not positive on the seats though. Wish I could help more. Hopefully someone else can chime in...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #10 of 10 Old 04-26-2013, 02:39 PM Thread Starter
leadsled jeep
Think ill start a new thread on what else could take out both seat heaters at same time?
Thanks anyway Chris
Chris
