Where can i get a driveshaft like this? - JeepForum.com
post #1 of 5 Old 12-06-2013, 08:52 AM Thread Starter
atinari
Would carolina driveshafts be able to build one like this so i can bolt it onto my existing yokes?
atinari is offline
post #2 of 5 Old 12-06-2013, 09:16 AM
cubalz
Yes or Tom Woods (this is what I have on my Rubicon). You could just yank one out of a GC with the double cardan front driveshaft. That is what I did and it only cost me $50.00. Cheaper=bueno
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #3 of 5 Old 12-06-2013, 09:20 AM Thread Starter
atinari
yeah but how hard would it be to replace the yokes? I have a double rezeppa
atinari is offline
post #4 of 5 Old 12-06-2013, 10:09 AM
gatorchin
I'm in the same boat..i got a used drive shaft (double u joint) but have yet to change my yokes( i too have double repezza)..waiting till spring as long as my current drive shaft holds out that long..installed spring coil lift (2.5") last spring..still not sure what all i'm gonna have to do/have...i have the 247 tc, i think its on the way out too, so probably change that out too to a 242 if i can find a deal on a used one
gatorchin is offline
post #5 of 5 Old 12-06-2013, 10:25 AM
cubalz
More than likely you should take it to a mechanic and get them to change out your yokes. They can set the right pinion nut pre-load when installing the yoke. Have them replace the diff fluid while they are doing it.
cubalz is offline
