Where to buy 4.7 HO engine parts? Are these any good? - JeepForum.com
post #1 of 12 Old 07-03-2010, 11:03 PM Thread Starter
03GCherokee
As everyone knows the 4.7 HO engine isn't the most reliable engine that Chrysler has built. Why is it that internal parts for these engines are so few and far between? Everyone who has a good used engine wants $1500-$2000 for it. I've torn down my 4.7 and have the block at the machine shop.
The following are the parts I'm planning to buy
These Heads, but they don't say for Vin J or N----http://cgi.ebay.com/ebaymotors/CHRYSLER-DODGE-JEEP-CHEROKEE-DAKOTA-4-7-CYLINDER-HEADS-_W0QQcmdZViewItemQQhashZitem255709339aQQitemZ16037 4010778QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Timing chain-Claims it is for Vin J---http://cgi.ebay.com/ebaymotors/02-07-4-7-L-Dodge-Van-Pick-Up-V8-VIN-J-Timing-Chain-Kit-_W0QQcmdZViewItemQQhashZitem53e20ae649QQitemZ36027 4650697QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Are these parts any good? Any experience with them?
I'm also planning to buy a felpro gasket kit, an autozone oil pump, etc
The problem I am having is finding .010 oversized pistons and crank bearings.
I can't imagine they are more than $30 each when bought as a set? Anyone insight would be appreciated.
03GCherokee is offline
post #2 of 12 Old 07-04-2010, 09:59 AM
WiCkeDuDe
WiCkeDuDe's Avatar
I ran an aftermarket timing chain off ebay and it was fine. Get the factory oil pump, its less money than aftermarket. Check rock auto for all the pistons and bearings. The clevite oversized bearings I bought were within a few dollars of the standard size bearings. Its the oversized rod bearings that your stuck with, they are double the cost of the standard size.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 12 Old 07-04-2010, 02:46 PM Thread Starter
03GCherokee
Thanks.
Ok so
OEM for the oil pump. $120 Online - OEM
Felpro gasket stuff for everything else. $220 Autozone, etc.
Ebay heads for $580 shipped $580 EBAY
Ebay (Brand PCI) timing chain kit $200 Ebay
head bolts $30 Autozone
Thermostat/Water pump $75 Autozone
Crankshaft (if needed) $240 Napa
Pistons $330 Rock Auto
over sized piston rings $100 Rock Auto
undersized bearings (or oem sized if new crank) $60 Rock Auto
rod bearings $100?? - rock auto error loading
rod nuts/bolts? $50??? - rock auto error loading
Machine shop cost to bore cylinder/check block $400 Local machine shop
I'm $2500 into it
Am I missing anything? Anyway I can cut back on that price? I'd like to stay @ $1800.. If the crankshaft can be cleaned add $75 to the machine shop and take off $240 for a new crankshaft. Anything else I can do?
post #4 of 12 Old 07-04-2010, 04:52 PM
Andyh
The VIN code J Timing chain set on ebay....
I am in the process of sourcing parts for mine, 4.7 HO and asked the question to the seller, is this ok in the HO engine, they looked into it and said yes, its the same chain as the standard Vin Code J 4.7 engine.
Let me know how you go with it, i am due to purchase one and get it sent to Australia in the next few weeks.
OEM timing chain set in Australia = $1100 AUD.. WTF ????
Regards
Andy
Jeeps in Australia = big $$$$ for spares :(
Andyh is offline
post #5 of 12 Old 07-04-2010, 05:03 PM Thread Starter
03GCherokee
I work at a dealer (not a Chrysler dealer, but I still get parts at wholesale) and my cost on an OEM was around $550. Cheapest I could find locally was autozone for $520. Ridiculous. I imagine as time goes on and more people start replacing these chains the price will drop significantly. (At least aftermarket chains) I also contacted PCI and they said that the timing chain set will work for VIN J.
I'm seriously debating throwing in a used engine, eating the machine ship charges and selling the Jeep if I can't get below $2000
post #6 of 12 Old 07-06-2010, 10:11 PM Thread Starter
03GCherokee
Buying listed parts above tomorrow... Any insight on quality and price would be appreciated. Thanks in advance.
post #7 of 12 Old 07-07-2010, 09:43 AM
WiCkeDuDe
WiCkeDuDe's Avatar
I wouldnt be in a hurry to buy those heads. Most of them dont even include new keepers. What happened to your old heads? I just had mine redone and installed new valve springs, keepers, retainers, for almost half of that price.
post #8 of 12 Old 07-07-2010, 09:06 PM Thread Starter
03GCherokee
My old heads have three broken valve seats. two broken seats on one head and one broken seat on the other head. All three seats are just hanging on the valves. Also three of the rocker arms seemed to have just fallen out for some reason. These heads are shot. By the time I had new seats put on and these heads decked I would be well over $600 without even replacing any other parts.
How do you know these heads don't come with keepers? We are speaking of the same heads correct? CHRYSLER/DODGE/JEEP CHEROKEE/DAKOTA 4.7 CYLINDER HEADS: eBay Motors (item 160374010778 end time Jul-27-10 08:44:25 PDT)
Any other recommendations on where to get reman heads or used heads?
Engine is at the machine shop. Should be done by the end of next week. Would like to have the parts and gaskets by then.
post #9 of 12 Old 07-08-2010, 08:27 PM Thread Starter
03GCherokee
Bump
post #10 of 12 Old 07-08-2010, 09:14 PM
jcooperdj
I did not realize these were problem motors. They should have kept putting in the old 360.
jcooperdj is offline
post #11 of 12 Old 07-08-2010, 11:06 PM Thread Starter
03GCherokee
Ok I shouldn't have said that. I retract my previous statement, lol. They do have some problems, but MOST of them are due to lack of maintenance. If you keep the oil changed at the correct intervals, change the oil immediately after towing anything heavy, etc these engines are just as reliable as some other designs. They are not without their problems, but they are relatively reliable.
Again, I retract my statement and apologize to anyone who might be wanting to flame me.
Now with that out of the way, Wickedude do you have any experience with these heads or know of anyone who does?
Anyone else on this forum have any experience with these heads?
Any better place to get new heads? Rebuilding these heads would cost over $1000 between the machine shop labor and parts and just isn't cost effective.
I eagerly await your response.
post #12 of 12 Old 07-17-2010, 08:20 PM Thread Starter
03GCherokee
well the engine is done at the machine shop. Picking it up on Tuesday or Wednesday. Need to order the heads by Monday at the latest. Anyone have any experience on these heads? any other place to get a good set of heads for a HO engine? Someone must have some recommendations. I can't be the only one on this forum who has done a rebuild on a 4.7?
If I spend $580 on the heads I'm already $2300 into this rebuild. Would like to stay as cheap as possible.
What is a good website for ZJ parts? consalvochris ZJ Grand Cherokee Forum 1 12-18-2008 05:00 AM
Where is a good place to buy suspension parts? Bekim ZJ Grand Cherokee Forum 14 09-30-2007 11:35 PM
Good Used PArts site zjeepin ZJ Grand Cherokee Forum 5 01-22-2007 01:36 PM
Any good sites for interior trim parts jnocerin ZJ Grand Cherokee Forum 4 01-10-2006 06:43 PM
Good source for parts for ZJs? Zaphod ZJ Grand Cherokee Forum 2 01-19-2003 07:25 PM
