Where to attach hand winch? - JeepForum.com
 1Likes
  • 1 Post By 99SK04GTX
post #1 of 15 Old 07-19-2017, 08:03 AM Thread Starter
AnExParrot
I need to use a hand winch (some call them come-ups) to move something a few feet in my front yard. It weighs probably 300 pounds. But i have no trees or anything in the yard to anchor the winch to.
I thought about anchoring the winch to my 2000 WJ Laredo, but my jeep doesnt have either a tow hitch or tow hooks.
Is it safe to run the anchoring cable or strap around something underneath the jeep like a diff or both front or rear wheels?
Obviously i dont want to damage the jeep.
I know I could buy and install a rear hitch, but I'm trying to keep the cost down.
Appreciate any suggestions.
Thnks,
AEP
AnExParrot is offline
post #2 of 15 Old 07-19-2017, 08:11 AM
wjjeep19
Thnks,
AEP
If only a few yards, I would make sure I'm careful and strap it to the axle (not the diff). Someone may have a better suggestion.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #3 of 15 Old 07-19-2017, 09:36 AM
Squarecat
1993 XJ Cherokee
There is no "good" way for what you're trying to do.
Something with a static weight of 300 pounds becomes effectively "heavier" when you try to move it.
That doesn't even address the multiplied forces introduced by the act of trying to move it.
That's how you end up with YouTube videos of entire axle assemblies being instantly extracted from vehicles.
Sent from my iPhone using Tapatalk
Squarecat is offline
post #4 of 15 Old 07-19-2017, 10:00 AM
ChrisHager
Administrator
ChrisHager's Avatar
I would find a buddy with a truck and a tow strap...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 15 Old 07-19-2017, 12:48 PM
Double E
Double E's Avatar
I don't love this either but, were the job mine to do, I'd hook it to one or a couple of the molded-in cargo tie-down loops on the cargo area floor. They're plastic but tough.
That may give you a mechanical lift that could help to "lighten" the poundage too.
If one rips up, no big deal.
The other place is in the spare tire well, where the hook goes up through the middle of the spare tire. Use that metal loop. Again if it snaps, no biggie.
Be sure to use a blanket or something over the rope/cable/chain to dampen the recoil it if it lets go.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #6 of 15 Old 07-19-2017, 05:08 PM
BDW
The axles are subjected to forces much larger than that every time you drive it. Just be careful not to pinch a brake line if you wrap around the rear axle.
04 WJ 4.0/NP242, 3" OME, Bilsteins, 255/75/17 & JKR wheels, 44A, 4.56, ARB lockers, & more
BDW is offline
post #7 of 15 Old 07-19-2017, 08:59 PM Thread Starter
AnExParrot
Thanks for the suggestions. One more thought: What if i take the tow strap through the grille down around the front bumper? I figure the bumper is where an electric winch would attach if i had one. Or does the bumper assembly get reinforced before an electric winch is installed?
Thanks,
AEP
post #8 of 15 Old 07-20-2017, 03:59 AM
Grippy0
The axle is not a good place to strap it to, neither are the tie down points in the cargo area, I drilled one out yesterday, they're only held in by 2 rivets!!! Enough to hold down a box of paper for the ****ter but not for a hand winch.
If you can't get someone to help that has a suitable tow point on their car, dig a hole and use your spare as a ground anchor
Grippy0 is offline
post #9 of 15 Old 07-20-2017, 04:58 AM
drakan1998
Thanks,
AEP
Unless you have a aftermarket bumper then no. There is nothing to attach to there.
Sent from a van down by the river
drakan1998 is offline
post #10 of 15 Old 07-20-2017, 05:09 AM
99SK04GTX
I believe Jeep will install a trailer hitch on your vehicle as part of a recall
Arcticcat340 likes this.
99SK04GTX is offline
post #11 of 15 Old 07-20-2017, 06:54 AM Thread Starter
AnExParrot
I meant running the tow strap behind the inner bumper assembly attached to the frame, not just the plastic bumper fascia. I'm assuming that the inner asembly is the same as when an elec winch is attached and just the fascia is different.
post #12 of 15 Old 07-20-2017, 07:16 AM
Double E
Double E's Avatar
Still no. That bumper cover is not affixed to the metal bumper underneath with anything other then 2 10MM screws on the sides, some pop rivets and the Philips head screws on the grill. Even if you can find a way to get to the inner bumper assembly without taking off the bumper, it's probably going to mess up the bumper with marks from the rope or cable, could permanently mis-shape it or tear the bumper's plastic mounting holes.
If you don't like the rear cargo hold-downs, use the spare tire well components.
One other place would be the transmission cross bar support but that's not going to be very easy to get to.
Double E is offline
post #13 of 15 Old 07-20-2017, 11:46 AM Thread Starter
AnExParrot
Thanks. The trans crossbar is a possibility. But maybe this is the excuse I've needed to get a tow hitch.
AEP
post #14 of 15 Old 07-20-2017, 02:54 PM
Double E
Double E's Avatar
Get the hitch...it was the only thing (with ball hitch installed) that stood up to a rear impact at 30mph and let me drive away.
Insurance totaled the Jeep after but I was able to keep it anyway because of that hitch ball assembly being there.
Double E is offline
post #15 of 15 Old 07-20-2017, 02:59 PM
wjjeep19
Probably a good time to invest in front recovery hooks/shackles as well.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
