wheel's peeling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > wheel's peeling
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 05-22-2010, 08:49 PM   #1
2000stocker
wheel's peeling
my stock wheels on the WJ are starting to have the clear coat peel off of them. Has anybody sanded the clear coat off or used aircraft stripper to strip it? thanks guys.
2000stocker is offline   Reply With Quote Quick reply to this message
Unread 05-22-2010, 10:52 PM   #2
csouers
I've had this experience on both of my jeeps. Best plan of action is to declear it with something like paint stripper. (a couple coats of that works wonders.) Now if the clear's peeling on the paint (normally doesn't), then you might as well strip it all and paint them.
On mine, I had some nasty corrosion, especially by the center caps (Limited 96-98 owners should know what I'm talking about). To clean that up and any corrosion at all, I bought a scotch brite drill pad. This makes easy work of getting the corrosion out. Beware that this will probably put some scratches in the aluminum (so damn soft), but if you do a good enough job of buffing, polishing (with a foam pad and aluminum polish), and waxing it, you won't notice it too much.
Some pics of when I was going it the the cherokee wheels
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s - The DD
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s - The Rig
My Photography
csouers is offline   Reply With Quote Quick reply to this message
Unread 05-23-2010, 02:07 AM   #3
straty1987
are these the chrome of alloy wheels?
straty1987 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2010, 05:54 PM   #4
2000stocker
not chrome, just plain alloy wheels.
