Wheels - JeepForum.com
post #1 of 7 Old 10-12-2017, 07:23 PM Thread Starter
D-Grimm1994
Wheels
I have a 2004 jeep Grand Cherokee Laredo sport v8 4.7 4WD full time and I would like to know if these set of wheels and tires would fit it. It says they go to a 07-17 jeep Wrangler and was curious if they would still fit my Jeep before I actually decide to buy them please let me know thanks
D-Grimm1994 is offline
post #2 of 7 Old 10-12-2017, 09:19 PM
rabidpenguin
My wheels are off a 2017 jku. Bolt pattern should be 5x5
2004 WJ,242tcase,255/75/17 Wranglers,UnidenCB w/4ft firestick. Member of RDJ
rabidpenguin is offline
post #3 of 7 Old 10-13-2017, 05:52 AM Thread Starter
D-Grimm1994
So as long as they are 5x5 bolt pattern they should fit then?
post #4 of 7 Old 10-13-2017, 09:45 AM
ChrisHager
Administrator
ChrisHager's Avatar
If they fit a JK, they'll fit a WJ. Both have 5x5 bolt patterns.
What size wheel and tire is that?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 7 Old 10-13-2017, 10:25 AM
Jeeples
Jeeples's Avatar
Bolt pattern is correct, but Offset/Backspacing can be a whole 'nother can of worms.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 7 Old 10-13-2017, 09:41 PM
RoysJeep
Junior Member
RoysJeep's Avatar
I was just gonna say, the bolt pattern is the same, but it boils down to the backspacing and tire size.
On Edit: @ChrisHager ask and you shall receive
After looking at the package, it looks like a minimum of 3-4" lift with trimming is going to be needed.
Wheel Size: 17x9 with 4.75" bs or 20x9 with 5" bs
Tire Sizes: 17" - 33x12, 33x12.5, 34x12.5, 35x12.5 or 285/75 (33.8")
20" - 35x12.5, or 37x12.5
2004 WJ Laredo, 4.0, 197,xxx miles and counting, 3:55 gears, D30/D35c. Stock for now
RoysJeep is offline
post #7 of 7 Old 10-16-2017, 07:04 AM
ChrisHager
Administrator
ChrisHager's Avatar
You got it. That backspacing would work but you'll need a lot of trimming for those tires!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
