Wheel and tire sizing - JeepForum.com
post #1 of 7 Old 05-06-2013, 05:28 PM Thread Starter
dippedWJ
Ok I'm shopping rock crawler wheels. Does the width (8,9,10) factor into the tire size at all? Like what is the benefit of a 10" rim vs a 8"? I'm wanting to buy 16" with 4" backspacing rock crawlers. Wanting to put some mts on it. Basically I have a 2.5" suspension lift and wanna put on 265/75r16 mt
dippedWJ is offline
post #2 of 7 Old 05-06-2013, 05:31 PM
EisBlade
De Oppresso Liber
EisBlade's Avatar
JT
Harley-Davidson Touring Bikes (60K members strong)
EisBlade is offline
post #3 of 7 Old 05-06-2013, 05:46 PM Thread Starter
dippedWJ
dippedWJ is offline
post #4 of 7 Old 05-06-2013, 07:01 PM
bpolly_2004
i would use the 8 inch wide wheel. that way you can fit a wider tire if you ever want to go that way. you can fit a 12.50 wide tire on that rim the only thing that the wheel size matters is that you don't want a wider rim than tire, bc that would look ignorant, and be easier to pop a bead if you air down.
the tire you want to run is a 31.6x10.50 you would be perfectly suited to run the 8 inch wide rim.
bpolly_2004 is offline
post #5 of 7 Old 05-06-2013, 07:45 PM Thread Starter
dippedWJ
Thanks a lot man. I'm wanting to buy the rims for the wider stance they'll provide. And I'm gonna need new tires soon also
dippedWJ is offline
post #6 of 7 Old 05-06-2013, 09:27 PM
tidal9
If you want a wider stance, get spacers
tidal9 is offline
post #7 of 7 Old 05-06-2013, 09:36 PM Thread Starter
dippedWJ
I have spacers, but I'd rather have a little more.
dippedWJ is offline
