wheel's peeling - JeepForum.com
post #1 of 4 Old 05-22-2010, 07:49 PM Thread Starter
2000stocker
wheel's peeling
my stock wheels on the WJ are starting to have the clear coat peel off of them. Has anybody sanded the clear coat off or used aircraft stripper to strip it? thanks guys.
2000stocker is offline
post #2 of 4 Old 05-22-2010, 09:52 PM
csouers
I've had this experience on both of my jeeps. Best plan of action is to declear it with something like paint stripper. (a couple coats of that works wonders.) Now if the clear's peeling on the paint (normally doesn't), then you might as well strip it all and paint them.
On mine, I had some nasty corrosion, especially by the center caps (Limited 96-98 owners should know what I'm talking about). To clean that up and any corrosion at all, I bought a scotch brite drill pad. This makes easy work of getting the corrosion out. Beware that this will probably put some scratches in the aluminum (so damn soft), but if you do a good enough job of buffing, polishing (with a foam pad and aluminum polish), and waxing it, you won't notice it too much.
Some pics of when I was going it the the cherokee wheels
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #3 of 4 Old 05-23-2010, 01:07 AM
straty1987
are these the chrome of alloy wheels?
straty1987 is offline
post #4 of 4 Old 05-24-2010, 04:54 PM Thread Starter
2000stocker
not chrome, just plain alloy wheels.
99 Paint Peeling DRE97 ZJ Grand Cherokee Forum 6 05-18-2007 06:11 PM
Looking for a set of peeling Rogue's. hinchcliffe ZJ Grand Cherokee Forum 2 12-17-2006 12:58 PM
Roof rack peeling tbart16 ZJ Grand Cherokee Forum 4 06-05-2006 11:32 AM
Slid into a curb, Wheel's off center. Will this fix? Ruffy ZJ Grand Cherokee Forum 2 02-23-2005 07:46 AM
peeling door panels mnjeepster ZJ Grand Cherokee Forum 1 06-07-2002 12:10 AM
