Whats Your Oil? (4.7L HO) - JeepForum.com
post #1 of 29 Old 06-20-2012, 07:44 AM Thread Starter
fuzzy88
Question Whats Your Oil? (4.7L HO)
I've been running pennzoil 10w-30 and it about that time for yet another oil change. Just wanted to see what oil brand everyone else is using for the 4.7L HO.
I was thinking about changing to CastrolGTX .
Thanks in advance everyone :-)
fuzzy88 is offline
post #2 of 29 Old 06-20-2012, 07:51 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Mobil 1 10-30 with either a Mobil 1 or purolater filter and 8000 mile intervals. I actually change the filter at 4000 and top it off, then a full change at 8000.
~James
ezflip is offline
post #3 of 29 Old 06-20-2012, 07:53 AM
ChrisHager
Administrator
ChrisHager's Avatar
There are quite a few oil threads on here.
http://www.jeepforum.com/forum/f310/...-4-7l-1327729/
Here's a couple discussing oil weight:
http://www.jeepforum.com/forum/f310/...eight-1320104/
http://www.jeepforum.com/forum/f310/oil-weight-1308668/
Oil and Filter choices:
http://www.jeepforum.com/forum/f310/oil-filter-1364641/
Filter discussion:
http://www.jeepforum.com/forum/f310/...4-7-a-1165176/
Mobil 1 HM or Rotella T5 are both good for either engine.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 29 Old 06-20-2012, 11:56 AM Thread Starter
fuzzy88
Thanks. Did a search and nothing came up. Thank you .
fuzzy88 is offline
post #5 of 29 Old 06-20-2012, 12:16 PM
ChrisHager
Administrator
ChrisHager's Avatar
A search for 'oil' brings nothing up. Perhaps the word is to short (though there is not warning for that in the results). Quite amazing really considering how much that term is used.
Try this next time - in Google's search box:
site:http://www.jeepforum.com/forum/f310/ oil
Replace the word 'oil' for whatever it is you want to search for in the WJ section.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6 of 29 Old 06-20-2012, 12:53 PM
buns_1
I run Mobile 1 High Mileage 10w-30 and WIX filter. 129,000
04 WJ Overland, 3" IRO Lift, Yakima Rack, 255/75/17 BFG KM's, ARB bumper and custom rear bumper.
buns_1 is offline
post #7 of 29 Old 06-20-2012, 12:59 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
x2 on the WIX filter. They occasionally make it into my rotation as well, they are just a little hard to find around here for some reason. I can usually find at least one of the three (mobil 1, purolator, or WIX) at any of the parts stores around, so depending on which store I happen to be in, decides which filter I go with.
~James
ezflip is offline
post #8 of 29 Old 06-20-2012, 01:58 PM
04Overland47
04Overland47's Avatar
I use Mobil 1 HM 5w-30 in my 04 Overland. Changes every 4k miles. You should really be running 5w-30 in your 04 HO. The 02-03 models use 10w-30, but Chrysler revised the oil pump in 2004 and recommends 5w-30.
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is offline
post #9 of 29 Old 06-20-2012, 04:04 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Mobil 1 High Mileage 10W-30 or Rotella T5 10W-30. Wix or Napa Gold oversized filter.
~Richard
billzcat1 is offline
post #10 of 29 Old 06-20-2012, 05:31 PM
SirWilliam
Just an FYI, MySQL has a default minimum word length for full text indexing/searches of 4 characters. So unless the server admin changes this to 3 characters, a 4 letter word is the smallest thing it can ever find. Unfortunately for car sites, this leaves out a TON of things.... ABS, PCV, IAC, TPS, PSI, etc. The car forum I ran was on my own dedicated server, so I was able to change the MySQL config file to allow 3 character indexing/searches.
Oh, and I run Valvoline Synthetic 5w30.
2004 WJ Overland - 4.5" Lift - 2012 JK Sahara 18" 7-Spoke Polished Wheels with stock JK Bridgestones
SirWilliam is offline
post #11 of 29 Old 06-20-2012, 05:46 PM
billzcat1
2003 WJ
Using a Google site-specific search helps. "site:www.jeepforum.com WJ 4.7L Oil"
~Richard
post #12 of 29 Old 06-20-2012, 07:09 PM
ChrisHager
Administrator
ChrisHager's Avatar
Ahh a MySQL'er... It's been over a year since I've used open source. Loved it though.
And on subject, I concur with billzcat1.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #13 of 29 Old 06-27-2012, 11:55 AM
coltlacrosse
Valvoline MaxLife Full Synthetic 10W-30
I use Valvoline VV180 MaxLife Synthetic SAE 10W-30 and a K&N HP-2004 filter and change every 3000 miles.
I get both the oil and filter off Amazon with free 2-day prime shipping.
I switched to this oil at 88,000 miles, I had the dealership do my 90,000 mile service then and since then I've been doing all the maintenance myself to save money.
I haven't noticed any performance gains, which you should not expect from oil anyway, but I am confident that my engine is being protected better and also cleaned better because Valvoline synthetics use good detergents.
The K&N filter is extra strong and used in race vehicles, my favorite part is the 1 inch bolt on the bottom because getting a filter wrench around the filter in my 2004 Overland is a real pain.
Always hand-tighten your filter, never use a wrench to put it back on. Just wipe the oil off and put some muscle into it and it will be fine, and a lot easier to get off at the next change.
coltlacrosse is offline
post #14 of 29 Old 06-27-2012, 01:50 PM
KayCeeJeep
Great choice, but that is serious overkill, you should be able to get 5k out of that easily, save some money for something else your Jeep needs.
KayCeeJeep is offline
post #15 of 29 Old 06-27-2012, 02:29 PM
myjeeplovesmud
i use 5w-30 penzoil ultra for 5qts. and for the 6th, i use Lucas synthetic oil stabilizer.... i don't think theres anything that can touch that combo
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
4.7l , oil , what oil
whats my tranny?? meopilite WJ Grand Cherokee Forum 2 01-26-2012 09:49 AM
Whats the difference between ..... Exdecuk WJ Grand Cherokee Forum 2 01-23-2012 09:30 AM
Whats in my jeep? jessebrown WJ Grand Cherokee Forum 3 10-02-2011 07:18 PM
Whats is this please? Mr_Grumpy WJ Grand Cherokee Forum 5 08-27-2010 06:38 AM
whats this? robd2003 WJ Grand Cherokee Forum 5 03-25-2010 08:19 PM
