What's this please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > What's this please
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-17-2013, 01:19 PM   #1
sbsshadow
What's this please
I'm sure this is what needs replacing because my wj has no air , but what do ask for , thank you
sbsshadow is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 01:29 PM   #2
MadderThanMax
Wow! Whereabouts is that located?? Not Seen that before..
MadderThanMax is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 01:31 PM   #3
sbsshadow
Hehehehe, it's on the passenger side under the glove box
Unread 12-17-2013, 01:35 PM   #4
YZ212
2003 WJ
That is your blower motor resistor see this writeup http://www.jeepforum.com/forum/f310/...te-up-1285431/
and for the parts http://www.amazon.com/Grand-Cherokee.../dp/B004GVYCNU
03 GC Limited 4" IRO Long arm with upper rear a-arm Bilstein 5150's Duratracs 285/70/17 IRO Sliders Iceland Flairs if they ever arrive (gave up and cancelled order) 247-231 swap
YZ212 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 01:55 PM   #5
sbsshadow
Ok that's brilliant thank you
Unread 12-17-2013, 02:44 PM   #6
sbsshadow
Just need to find one in the UK now lol , and nothingi seem to find looks like it at all
Unread 12-17-2013, 02:46 PM   #7
Jeeples
Jeeples's Avatar
That's because there's usually a plastic cover over it, generally you won't see the circuit board and its associated parts like that. You see the rubber grommet that's used to pass the wires through the cover in your pic.
His: '00 WJ 4.7 Limited- stock
Hers: '03 WJ 4.7 V8- IRO 3", 245/75/16 Duratracs
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 02:50 PM   #8
MadderThanMax
Contact This chappie as he's very good, you can mention me:
http://www.4playjeep.com/index.php?_a=viewDoc&docId=1
Unread 12-17-2013, 03:02 PM   #9
sbsshadow
That's brilliant , thank you very very much
Unread 12-19-2013, 02:31 AM   #10
sbsshadow
Just ordered the resistor from jeep , not bad at £50 !
