whats the length - JeepForum.com
post #1 of 8 Old 03-27-2012, 09:14 PM Thread Starter
chriswj
whats the length
Hey guys im puttin my longarm lift this weekend what are the lengths you guys have ie how far did you extend them to get it right i have a clayton cross member and iron man long arms with a 4.5 inch lift
2000 Wj in the works taking donations daily!!
chriswj is offline
post #2 of 8 Old 03-28-2012, 09:46 AM Thread Starter
chriswj
bump anybody have any measurements
chriswj is offline
post #3 of 8 Old 03-28-2012, 02:04 PM Thread Starter
chriswj
Really nobody has the lengths
chriswj is offline
post #4 of 8 Old 03-28-2012, 02:22 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I think that if you are installing a long lift, people expect you to be able to figure the control arms out yourself.
~Richard
billzcat1 is offline
post #5 of 8 Old 03-28-2012, 07:53 PM Thread Starter
chriswj
ok understood and i am very capable of doing this this not my first rodeo this my first grand so i was just wandering what people lengths are so im no playin around allday to figure ir out is that such bad info to ask am i admitting some kind of post nono or somthin i just want a little dam info
chriswj is offline
post #6 of 8 Old 03-28-2012, 07:58 PM
TjinTopeka
Give the guy a break he just wants a starting point, it's not like he's cheating on a test. Not a hit at you billz but for some reason no one is willing to answer this question anytime someone asks it no matter the model or lift.
TjinTopeka is offline
post #7 of 8 Old 03-28-2012, 08:43 PM
billzcat1
2003 WJ
No I get that. I don't have the answer. I was just hypothesizing about why there's no response. I'd think that setting up a long arm system takes a lot of trial and error, and one person's measurements won't guarantee success on someone else's rig.
If you install the crossmember at stock height, measure from crossmember to LCA mount (on the axle), you should be able to extrapolate the approximate length with a lift using a little trig. But that only gives you stock axle location, and you might want to stretch the axle forward a little for tire clearance.
~Richard
post #8 of 8 Old 03-29-2012, 06:24 AM
skain8
skain8's Avatar
If you are using Clayton's crossmember, then use his instructions. Clayton gives you an eye-to-eye measurement, which will be a good starting point. There really is not much to it.
Wher's der rodeo n Williamsport?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
Driveshaft length Rocklobster WJ Grand Cherokee Forum 0 12-10-2011 07:21 AM
Track bar length sinbad85 WJ Grand Cherokee Forum 1 05-10-2011 10:21 PM
shock length wjnewguy WJ Grand Cherokee Forum 1 10-06-2010 07:49 AM
V8 WJ Rear DS Length FirefightinWJ WJ Grand Cherokee Forum 1 09-21-2010 02:52 PM
