whats the difference between a normal long arm kit and a critical path long arm kit? - JeepForum.com
post #1 of 14 Old 01-02-2012, 04:05 PM Thread Starter
ozgrand
just wondering on iro's website whats the difference between a normal long arm kit and a critical path long arm kit?
ozgrand is offline
post #2 of 14 Old 01-02-2012, 04:06 PM
skain8
skain8's Avatar
Nothing, other than critical path sounds way cooler.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 14 Old 01-02-2012, 04:30 PM
xJoshxx
2012 WK
the critical path you have to cut the factory control arm mounts off, they are also straight arms instead of curved to clear the stock brackets
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #4 of 14 Old 01-02-2012, 04:35 PM Thread Starter
ozgrand
so which would be the better option ?
ozgrand is offline
post #5 of 14 Old 01-02-2012, 04:43 PM
skain8
skain8's Avatar
Clayton.
skain8 is offline
post #6 of 14 Old 01-02-2012, 05:00 PM
Bphase
Critical path doesn't come with the rear longarm kit. The premium kit does. I think that's the only difference.
Bphase is offline
post #7 of 14 Old 01-02-2012, 05:16 PM
WJ04
Not true, you are thinking high clearence arms where you have to cut the factory brakets off. Critical path kit is any of their long are kits that do not include rear long arms but still has every ''critical'' piece you need to to run it successfully. The ''premium'' long arm kit includes the rear long arms as well, but although they are great to have they are still not ''critical''.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #8 of 14 Old 01-02-2012, 05:18 PM
Rocklobster
Originally Posted by skain8
Clayton.
As much as it seems he doesn't like me I agree 100% :-)
Rocklobster is offline
post #9 of 14 Old 01-02-2012, 05:48 PM
skain8
skain8's Avatar
OP -- seriously, "critical path" means nothing. It's marketing. It's like every Kevin's Off Road product labeled "Hard xxx".
skain8 is offline
post #10 of 14 Old 01-02-2012, 05:54 PM
Rocklobster
The real difference in the two "critical path" options is "high clearance" where during the install you cut off the stock mounts and the not "high clearence" where you don't cut the stock mounts. I think the only difference is the shape of the arms.
post #11 of 14 Old 01-02-2012, 06:09 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
This was addressed above, and is wrong. The only difference is that the premium kit comes with the rear long arms as well as the front. The critical path kit is just the critical parts needed to run long arms in the front or the rear. It simply separates the front and rear kits.
~James
ezflip is offline
post #12 of 14 Old 01-02-2012, 06:11 PM
Bphase
I have the critical path iro 6.5 inch kit and I didn't cut off the old lower mounts. They have never hit the arms yet and I do t see how they could.
Bphase is offline
post #13 of 14 Old 01-02-2012, 06:24 PM
Rocklobster
Sorry double post
post #14 of 14 Old 01-02-2012, 06:25 PM
Rocklobster
I aplogize for thinking you wanted to know the difference between the high clearence option and not
The difference between the standard "critical path" and the "premium" kit is:
Jks quicker discos
Adjustable track bar
Adjustable rear lower control arms
You can upgrade to adjustable front long arms and or "high clearance"on either one.
Either way Clayton makes the best long arm lift kit.
how long did your OEM cat last? greta WJ Grand Cherokee Forum 5 03-07-2011 09:36 AM
Wj long arm help? jrberry13 WJ Grand Cherokee Forum 57 02-10-2011 11:57 PM
Whats the difference? BartmanX WJ Grand Cherokee Forum 3 11-17-2010 11:47 AM
can someone describe the difference between jks adj control arms and long arms? kmd1776 WJ Grand Cherokee Forum 13 11-11-2010 06:30 AM
6.5in Critical Path Long Arm Lift Kit (Front)??? JkTheItalianoWJ WJ Grand Cherokee Forum 4 06-07-2010 08:36 AM
