Whats the best 2-4 inch lift for 03 wj? - JeepForum.com
post #1 of 17 Old 06-27-2012, 07:13 PM Thread Starter
kkbenco
2003 WJ
Wj Whats the best 2-4 inch lift for 03 wj?
I need some input, I have a budget boost now I want to keep the ride as close to stock as possible. What shoul I do?
kkbenco is offline
post #2 of 17 Old 06-27-2012, 07:18 PM
ablaydes
2003 WJ
OLD MAN EMU HD's, New Isolators top and bottom,Bilstein 5100,JKS trackbar and Zone 3 inch sway bar links front and rear
All of the except the sway bar links can be bought from Kolak Contact him and tell him you want his "MAGIC SETUP"
The Zone Offroad sway bar links eBay or Amazon
I just installed the OME HD's and Bilsteins on mine and the ride is the best you'll get, heck might has well say it rides stock, floats and does not hit hard like some lift springs
Check out my build thread for more info, it's all there
03' Jeep WJ|4x4 select-trac|Kolaks "Magic Setup"|OME HDS|Bilsteins 5100's|3/4 spacers front|Moog STB SS|Zone 3" sway links|Homebrewed quick Disco's|17" Moabs|32" BFG's KM's|Hella 500ff's|Rear Oem receiver|Front custom tow Points|Smittybilt receiver 3/4 D-ring|Limited headlights and Grille|
My Build thread
ROLL TIDE ROLL ! ! !
Well let me just quote the late-great Colonel Sanders, who said...I'm too drunk to taste this chicken !
ablaydes is offline
post #3 of 17 Old 06-27-2012, 07:21 PM
Rocklobster
For more stability you can also upgrade your front and rearvl sway bars to the addco brand. They are much thicker than stock.
Rocklobster is offline
post #4 of 17 Old 06-27-2012, 07:23 PM
hammerz71
There is a big difference between going 2-3" and dong 4". You need to do a lot more for 4" of lift. I have the OME HDs (about 3" over standard suspension, 2" over U/C), I have relatively cheap longer shocks (ProComp ES3000s), made my own longer sway bar links (cut & welded them 2 1/2" longer) and I think the ride is great. Bilsteins are great but I was on a tight budget and still can't complain about the ride. I second replacing the isolators whichever way you decide to go, stockers are poo-poo once you get up over abut 50k miles on them...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #5 of 17 Old 06-27-2012, 07:25 PM
asatxj
asatxj's Avatar
http://www.jeepforum.com/forum/f310/...thread-314066/
Do some searching. This gets asked at least 2x a week
OME via Kolak is an excellent setup but costs BIG $$ 3" max and rides fantastic.
Rough country 4" low cost, entry lift. Don't use the rear shock spacers.
Iron Rock off road-- Great quality 3" lift. Skip the shocks and get some from Kolak.
Up to 3" no major issues. @ 4" you start to have issues like needing a trackbar, adjustable LCA's Rear A arm spacer etc.
Remember it's a lifted Jeep it will ride different, not bad, different.
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #6 of 17 Old 06-27-2012, 07:29 PM
Rocklobster
Contact Kolak, he is working on a more BUDGET friendly kit using higher quality parts than other budget kits on the market and some of the parts will be useable as your needs change.
post #7 of 17 Old 06-27-2012, 07:31 PM
ablaydes
2003 WJ
I'm pretty sure after a 2.5 lift you will need a adjustable trackbar, not at a 4", it's recommended at 2.5" and up
My Build thread
ablaydes is offline
post #8 of 17 Old 06-27-2012, 07:36 PM
ablaydes
2003 WJ
Agreed, but you can also just replace the rear swar bar with a Addco and extended links and it will ride fine, the front is already beefy from the factory so its not a must, nor is the rear, but it's in my future plans
My Build thread
ablaydes is offline
post #9 of 17 Old 06-27-2012, 07:44 PM
Kolak
Vendor
Kolak's Avatar
That is correct - I'm putting together a 4.5" kit that will be just a little more expensive than the RCX but use far better quality parts.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #10 of 17 Old 06-27-2012, 07:46 PM
kc2mrg
i have rusty's 2.5" coils and shock lift (rusty brand shocks), it ran me about $440? i think, i like it, comfortable ride not stiff truck springs
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #11 of 17 Old 06-28-2012, 04:57 PM Thread Starter
kkbenco
2003 WJ
Thanks all for the help. I will do my home work now, but it looks like OME is th way to go.
kkbenco is offline
post #12 of 17 Old 06-28-2012, 05:01 PM
ablaydes
2003 WJ
Lucky you I have some OME HDS COILS FOR SALE BRAND NEW check out the classifieds
My Build thread
ablaydes is offline
post #13 of 17 Old 06-29-2012, 06:41 AM
skain8
skain8's Avatar
[pants tent].
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #14 of 17 Old 06-29-2012, 07:04 AM
D0dgeRam1500
Just go for a 4 inch lift. Otherwise you will keep on lifting the Jeep.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #15 of 17 Old 06-29-2012, 07:11 AM
Hopperstien
I like the sounds of this
04 WJ "Freedom Edition" 4x4 4.0L - soon to be lifted
Hopperstien is offline
Whats a good budget friendly 2 inch lift, shocks.. And whatever else i need! Jeepgcl9947 WJ Grand Cherokee Forum 4 04-25-2012 07:14 AM
6 inch lift with 2 inch BB 240impala WJ Grand Cherokee Forum 8 03-29-2012 11:28 PM
whats a better lift? dnovack2007 WJ Grand Cherokee Forum 8 07-23-2011 06:16 PM
A 4 inch suspention lift and a 2 inch body lift. Could that suport 36inch tires? Calpatt WJ Grand Cherokee Forum 27 04-26-2011 05:17 PM
4 inch teraflex lift vs IRO 4inch lift??????? anden02 WJ Grand Cherokee Forum 50 11-01-2010 10:46 AM
