What would happen if I remove my front Sway bar ? - JeepForum.com
post #1 of 19 Old 12-18-2013, 05:07 PM Thread Starter
FordExplorer
I thinking of removing my front sway bar because I been hearing a squeaking noise especially going at speed 10-15 MPh on bumpy road . Ball Joint are old but the suspension is tight . This Squeaking noise is driving me crazy nobody know where is coming from .
2000 Jeep Grand Cherokee 4.0 2wd
FordExplorer is offline
post #2 of 19 Old 12-18-2013, 07:02 PM
Eshindi
You can disconnect it to help troubleh shoot your issue.
Im at almost 7" and I actually dont even have mine installed.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #3 of 19 Old 12-18-2013, 07:05 PM Thread Starter
FordExplorer
I think the noise is coming from the sway bar so I might take off and drive like that ..
I don't think it will make a different driving with out a sway bar ?
post #4 of 19 Old 12-18-2013, 07:16 PM
Eshindi
Be careful without it in. I wouldn't just drive around with it. I dont plan on keeping mine out for ever.
You may need to get new sway bar links or grease up the bushings, if you now know the sway bar is the issue.
Eshindi is offline
post #5 of 19 Old 12-18-2013, 07:23 PM Thread Starter
FordExplorer
Nobody know where that annoying squeaking noise is coming from , I guessing is the sway bar . Suspension are tight is coming from the right front wheel only . I loosing my patience with this Jeep. I might go back to Ford .
post #6 of 19 Old 12-18-2013, 08:34 PM
Pedro7
You and everyone around you will die.
KCCO
2013 WK2
Pedro7 is offline
post #7 of 19 Old 12-18-2013, 08:37 PM
gcjeeping
Go buy a spray can of white lithium grease or silicone spay and lube each bushing 1 at a time and see when it stops squeaking or do them all and be done with it until you can replace them.
_____________
gcjeeping is online now
post #8 of 19 Old 12-18-2013, 10:11 PM Thread Starter
FordExplorer
I did that already and still the noise is there , I thinking is the shock absorber because suspension is tight.
post #9 of 19 Old 12-18-2013, 10:13 PM Thread Starter
FordExplorer
Florida doesn't have state inspection , there are people in here driving with worn out ball joint and tires , cutting off catalytic converted .
post #10 of 19 Old 12-18-2013, 10:24 PM
cr8zynelly
I think Pedro meant "if you go back to ford"
cr8zynelly is offline
post #11 of 19 Old 12-18-2013, 11:15 PM Thread Starter
FordExplorer
That true LOL Ford Exploder will get u kill
post #12 of 19 Old 12-18-2013, 11:24 PM
pmdowd6
Is English your first language? Just curious
pmdowd6 is offline
post #13 of 19 Old 12-19-2013, 10:17 AM Thread Starter
FordExplorer
No . Why you ask that? Is there a problem?
post #14 of 19 Old 12-19-2013, 11:33 AM
MTB04WJ
is english your first language? Just curious
lol! :d
MTB04WJ is offline
post #15 of 19 Old 12-19-2013, 02:32 PM
Notabene
For just checking if the sway bar is the noise culprit, taking it off for a quick drive will be ok. Just keep the speed down if you are risk avoidant.
Me, I have mine undone quite often for wheeling. Then it takes a few weeks before I reconnect it. The main issues is when unconnected, that when leaving the traffic lights in town with foot to floor, sometimes towing a trailer, the whole rig twists like a full blown drag car, and it gets a bit old.
Notabene is offline
