what would cause tail wag - JeepForum.com
post #1 of 17 Old 05-10-2013, 11:05 AM Thread Starter
derekmac
So my WJ like to "wag its tail" when driving if I let off the gas. From what I've read, it seems like it could be the rear LCRs, but just wanted to check with you guys first before I start replacing parts.
2005 TJ Rubicon
derekmac is offline
post #2 of 17 Old 05-10-2013, 11:08 AM
js12278
Could check tires for a twisted belt. Could be control arm bushings.
js12278 is offline
post #3 of 17 Old 05-10-2013, 11:11 AM
mikeydmikeyd
you are correct... i spent a lot of money chasing this issue.... check the oval bushings in the arms for the slightest bit of play while your helper rolls the jeep back and forward with the front tire
mikeydmikeyd is offline
post #4 of 17 Old 05-10-2013, 11:47 AM
85IrocZ-28
Control arm bushings (Front/Rear) and Rear a-arm busings and joint would be the first place I looked.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #5 of 17 Old 05-10-2013, 11:56 AM Thread Starter
derekmac
It's done this on three different sets of tires/wheels, but good suggestion.
Thanks, I'll give that a shot. I was looking at replacements on RockAuto, and they seem fairly cheap, but the shipping is pretty steep.
I'll check the a-arm bushings too, thanks!
2005 TJ Rubicon
derekmac is offline
post #6 of 17 Old 05-10-2013, 12:04 PM
js12278
If you find the UCA bushings to be bad, replace the UCA and bushings as an assembly and definitely install a new ball joint on top of the diff. No need to have to do it all over again.
js12278 is offline
post #7 of 17 Old 05-10-2013, 08:06 PM
narnwv
narnwv's Avatar
x2 on the rear upper control arm bushings. Tail Wag is the exact way I described it, and new upper control arm bushings (and ball joint while it's out) took care of the issue for me.
~Aaron
narnwv is offline
post #8 of 17 Old 05-11-2013, 12:43 AM
Upside
I have the same issue. Step on the gas and the nose goes left, let off and it goes right. Sounds like a new A-arm or at least bushings and ball joint are in order. Maybe I should go with a spacer to match my lift?
Upside is offline
post #9 of 17 Old 05-11-2013, 01:07 PM
Krom
had the exact same issue as upside, Mine needed LCA's replaced as the oval bushings where shot and actually sliding on the sleeve that the bolt goes through
Krom is offline
post #10 of 17 Old 05-13-2013, 05:36 AM Thread Starter
derekmac
I ordered LCA's through RockAuto. I can't wait to get rid of this bloody tail wag!
2005 TJ Rubicon
derekmac is offline
post #11 of 17 Old 05-31-2013, 05:38 AM Thread Starter
derekmac
I changed the LCA's a couple of days ago, and no more tail wag!
That's the drivers side, and the passanger side was even worse!
2005 TJ Rubicon
derekmac is offline
post #12 of 17 Old 06-04-2013, 10:50 PM
Upside
Looks like I need to get under the Jeep and pry side to side to see if the sleeves are detached from the rubber.
Upside is offline
post #13 of 17 Old 06-07-2013, 03:30 PM
Merc1973
Im having the same issue. I have new a-rm bushings (Dorman), new ball joint and new LCA (Crown).
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #14 of 17 Old 06-07-2013, 11:12 PM
js12278
Are all those parts installed already and you continue to have the wag? If so, check the lower control arms. Look at worn bushings as well. Use a pry bar and see if the rubber in the bushing is torn or disconnected from the bolt sleeve.
js12278 is offline
post #15 of 17 Old 06-08-2013, 02:27 PM
Merc1973
Yes, all are only 2-3 months old. I'll check them out. I may order some LCA from IRO with Clevite bushings to get rid of those silly oval bushings. It's very frustrating.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
