What tool do I need to remove my fan shroud - JeepForum.com
post #1 of 7 Old 12-21-2011, 07:28 AM Thread Starter
Requi3m
2003 WJ
without taking the front end apart? This is on an 03 4.0 WJ. The search results I've gotten seem to vary. Several people said it's possible. Some said it's not. Some said they made a special tool for it. But the tools used seem to vary. So what exactly do I need? Do I need a bunch of extensions or just a small flexible wrench like this one on amazon? I haven't really looked at where the bolts are yet. I did look at the diagram though.
http://www.amazon.com/GearWrench-Stubby-Flex-Head-Combination-Ratcheting/dp/B000HBDWMA/ref=sr_1_12?s=power-hand-tools&ie=UTF8&qid=1324473683&sr=1-12
edit: this is the part that sounds difficult:
http://www.jeepslimited.com/index.ph...=36&Itemid=126
The lower driver side bolt is nearly impossible to get to. From above, the steering box is in the way. I ended up using a combination of a swivel head socket, 18" extension, universal joint and a 6" extension. I came at the bolt from underneath. Not easy and by far the most difficult part of the project.
Do I really need all that?
Requi3m is offline
post #2 of 7 Old 12-21-2011, 08:07 AM
Jason_alex
I took my fan out of my 2001 with just a 10 mm boxed end wrench... a gear wrench would help a lot when doing this though.
2001 Jeep Grand Cherokee Laredo 4.0L Selec-Trac 2.5" ROR lift
1977 Trans Am 400 bored 40 over new paint new sub-frame.
Jason_alex is offline
post #3 of 7 Old 12-21-2011, 09:32 AM
crazyeyes
I wouldn't recommend this but I heated the tip of a regular screwdriver with a torch and melted through the lower driver side tab because it was so tough to get at and I didn't have the tools for it. I just made sure to tighten the other three bolts well and haven't had a problem. It sees mostly highway and roads. Been well for a year now.
crazyeyes is offline
post #4 of 7 Old 12-21-2011, 10:09 AM
EisBlade
EisBlade's Avatar
x2 on the gear wrench.
JT
Harley-Davidson Touring Group
EisBlade is offline
post #5 of 7 Old 12-21-2011, 11:29 AM Thread Starter
Requi3m
2003 WJ
yep that's what I need. thanks guys.
Requi3m is offline
post #6 of 7 Old 12-21-2011, 06:26 PM
steveheibel
gear wrench is no good unless it pivots. you will probably have the best luck bending the end of a 10mm wrench.
steveheibel is offline
post #7 of 7 Old 12-21-2011, 07:14 PM
xJoshxx
2012 WK
yup take a craftsmen bend it, take it back get a new one
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
'01 WJ electric fan/shroud removal laybackman WJ Grand Cherokee Forum 14 01-12-2013 09:52 PM
Tool to remove tie rod end from sleeve fouraxe WJ Grand Cherokee Forum 19 06-27-2011 07:02 PM
How to remove HVAC (especially how to remove pipes conestions; plumbings) ? diogene WJ Grand Cherokee Forum 6 11-28-2010 08:58 AM
tool kit wjnewguy WJ Grand Cherokee Forum 16 09-29-2010 09:41 PM
Help fan shroud removel help SwaYY WJ Grand Cherokee Forum 4 05-28-2010 01:05 PM
