What size of tyres for a WJ with +4" lift and rims with -12mm offset - Page 2 - JeepForum.com
post #16 of 45 Old 04-06-2010, 12:13 AM Thread Starter
thierryben
yes , I think you're right 22remud , I think that with my back spacing of 4" on my 16x8 , the biggest tyres that I can mount is 245/70/16 nearly 29.5" I have order 4 tyres in 245/70/16 , I will look
thierryben is offline
post #17 of 45 Old 04-06-2010, 12:41 AM
22remud
yea sounds about right
1998 TJ 4.0L NP231, 4inch skyjacker kit
1992 XJ 4.0L NP231, 6inch Gonzo Lift, Cherry Bombed Exhaust,Custom Cowl Snorkel,33x12.50 BFG km m/t's
22remud is offline
post #18 of 45 Old 04-06-2010, 01:05 AM
ronsaun
2003 WJ
something is wrong! you should not be hitting the fender at all w 265/75/16. i ran 265/75/16, stock rims, 2 wheel spacers and a 4.5 lift for 2 months without adj.control arms. i never even came close to hitting the fender!!!! my picture you see is with the 265's. i had to trim the plastic bumper. that is easy. i was scared at first but after i started i felt silly. everyone on here told me to do it and i wouldnt listen. get out the 4.5 side grinder and an 1/8 cut off wheel and go to town. it took all of 1/2 hour to do both sides. 245's wont look right at all and you will be totally disatisfied. then you will have to sell the 245's for a loss. have someone who knows jeep lift kits and suspension look it over as i assure you something isnt right. try a 4x4 shop even if you have to drive a little way. you may also try wheel spacers they are relatively cheap about $60 a pair. no matter what, they are an improvement as you will have a wider stance, a more stable ride and they will help your tire issue. it will be worth it as opposed to trying to sell a set of tires. this is my opinion only and i wish you the best. ron
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #19 of 45 Old 04-06-2010, 01:16 AM
22remud
The problem isn't the tire size it's his rims, they weren't the best size pick due to back spacing.
22remud is offline
post #20 of 45 Old 04-06-2010, 03:02 AM Thread Starter
thierryben
Hi Ron , yes 22 remud is right , the problem is not the tyre size , the problem is due to the pivot point because the back spacing of +4" of my rims **** Cepek is too big ,
I think that If I have stock rims , there is no problem for the 265/75/16 , the problem is the back spacing of my rims ,
and I have just buy this rims , I don't want to sell it , it's the **** and I don't know what to do
post #21 of 45 Old 04-06-2010, 10:10 AM
ronsaun
2003 WJ
get wheel spacers. 2" are hard to find but i have them. or sell the rims and take the loss. no matter what, you are gonna have a heck of a time living with 245's and a 4" lift. i still dont understand how you are hitting in the back. if you keep your rims, get 2" spacers and buy adj.control arms you should be close to stock backspacing and be able to move your wheels forward. you will have to trim more in the front but there is plenty of plastic to take off and still look right. in my opinion it is time to throw in the towel, get off your wallet, get out the grinder and put this issue behind you. 245's with a 4" lift just plain dont get it! my opinion only. wish you the best. i know upgrading a jeep is really stressfull because it costs a fortune. alot of us have thrown good money after bad and it really hurts. that is why we all suggest solutions and are strong in our opinions. weve been there and feel your pain!!! we know this could be a $1000 plus problem. ron
TO DO:
ronsaun is offline
post #22 of 45 Old 04-06-2010, 10:32 AM
22remud
Wheel spacer would make the problem worse for him it would push the wheel even further out ceaing more problems. My sugestion is to try to either sell those wheels or to see if the place you purchased from would swap you (or pay a small difrence) and try to get a wheel that is the same euivalent back spacing as a stock rim.
22remud is offline
post #23 of 45 Old 04-06-2010, 11:23 AM
ronsaun
2003 WJ
Originally Posted by 22remud View Post
Wheel spacer would make the problem worse for him it would push the wheel even further out ceaing more problems. My sugestion is to try to either sell those wheels or to see if the place you purchased from would swap you (or pay a small diffrence) and try to get a wheel that is the same euivalent back spacing as a stock rim.
i guess i am confused. -12mm is like 1/2 inch. that cant posssibly cause this. so his wheel is pushed 12mm out?
TO DO:
ronsaun is offline
post #24 of 45 Old 04-06-2010, 12:40 PM Thread Starter
thierryben
yes the center of my rim is deported of 12mm ( offset ) and my backspacing is 4"
I have buy today 4 tyres in 245/70/16 , I think that I will be received it in 1 or 2 day , I will try it and I send you photos ,
I hope that it's looks not too little
post #25 of 45 Old 04-06-2010, 02:02 PM
22remud
Offset is mesured front the center of a wheel to it's mounting surface. Backspacing is mesured from the mounting surface to the inside lip of the rim. For instance my old Toyota pickup I had was on 33's. On a 15x8.5 with 4inches of backspace it fit perfect and never rubed. The same exact tires in a set of 15x10's with 4 inches of backspace they rubed every wear. Because it made the tire stick out further causing a wider radius that the tire had to follow. If I had to pick a tire size for the situation it would prolly be a 255/70/16 or a 245/75/16. I'd prolly pick the 245 tho
22remud is offline
post #26 of 45 Old 04-06-2010, 02:05 PM Thread Starter
thierryben
I look when I received the tyres and I post photos for looking together ,
many thanks for all your advices
post #27 of 45 Old 04-06-2010, 07:09 PM
22remud
no problem
22remud is offline
post #28 of 45 Old 04-06-2010, 11:56 PM
robiec04wj
i run 265/70/17s on my 04 wj with just upcountry springs and a 2in budget boost,they rubbed the bumper at first but that just took about 30 min and my pocket knife to fix, the only place they rub is on flat surface at full lock they touch the right control arm barely and that is because of no adjustable track bar, if i could adjust the track bar they probably would rub at all, i am running the freedom rogues with no spacers, so in my opinion the backspacing on the cepeks is what s causing the problem
robiec04wj is offline
post #29 of 45 Old 04-07-2010, 12:14 AM Thread Starter
thierryben
I think too
post #30 of 45 Old 04-07-2010, 12:32 PM Thread Starter
thierryben
I have received today my tyres in 245/70/16 I have mount a tyre immediatly on a DC-2 and I have try on the WJ ,
I post a photos , , what do you think of it :
Looking for new rims for my WJ, Not sure how offset works mikesd1981 ZJ Grand Cherokee Forum 2 02-12-2009 07:07 AM
Recommended budget lift kit for 33" tyres dxmedia ZJ Grand Cherokee Forum 24 10-19-2008 05:36 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 07:25 AM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 07:15 PM
