What size of tyres for a WJ with +4" lift and rims with -12mm offset - JeepForum.com
post #1 of 45 Old 04-02-2010, 05:40 AM Thread Starter
thierryben
Hi Guys , my name is thierry , I'm from France and I'm all new on your Forum , I have just posted my first message in " introduction "
I have just buy a Grand Cherokee WJ 2001 4L7 since 1 month and I need your advice
I have put on my WJ a Zone OffRoad Lift of +4" and I have buy 4 rims dik cepek DC-2 in 16x8 with an offset of -12mm
I have try yesterday with a tyre in 285/75/16 and it's very very too big , I can't turn the steering wheel , the tyre touch immediatly the bumber or the fender
what is your advice , what is the best size of tyres for my WJ for playing offroad with the sway bar disconnected ?
and sorry , I hope that I'm clear because my english is not very well
thierryben is offline
post #2 of 45 Old 04-02-2010, 06:40 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Try a 265/75/16.
They should work but you may have to trim the lower corner of the bumper. Nothing to crazy, just a little bit of plastic.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 45 Old 04-02-2010, 07:04 AM Thread Starter
thierryben
yes , many thanks for your answer brian , I have look on the forum that some WJ's with 4" of lift had this size of tyres 265/75/16 , but all the WJ's that I have look with this tyres are on the stock rims , do you think that my offset of -12mm on the DC-2 is a problem , because I think that the stock rims have a big positiv offset
there is someone on the forum with a WJ +4" and dik cepek rims in 8x16 ?
post #4 of 45 Old 04-02-2010, 07:17 AM
Apollo21
those rims just help your backspacing so they would allow you to have a wider stance for more stability they also may allow you to fit a slightly larger tire. People often times keep the stock rims and use wheel spacers for the same effect. this is what i'm doing i'm also on the Zone 4in lift. my build thread is in my sig
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #5 of 45 Old 04-02-2010, 07:59 AM Thread Starter
thierryben
Hi appolo21 , and many thanks for your answer , I have look on your ^post that you have 265/70/17 , is it the same than the 265/75/16 ?
and are you enjoyed by your zone lift?
post #6 of 45 Old 04-02-2010, 08:39 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
we talk about backspacing instead of offset here for rim dimensions. the backspacing means a whole lot more.
ratmonkey is offline
post #7 of 45 Old 04-02-2010, 10:37 AM
Apollo21
my tires measure 32.25in and they rub a lot i had to trim a good amount to make it able to drive on the street. i do like my zone lift and would recommend it to anyone. it should also be noted that i have a 3/4in spacer up front to give me a little extra.
SOLD
Apollo21 is offline
post #8 of 45 Old 04-03-2010, 12:39 PM Thread Starter
thierryben
ok well , you are sure that they fit well with my 4" zone ? but it's rub a little
if I don't want to rub what is the biggest size that I can choose ?
post #9 of 45 Old 04-03-2010, 12:54 PM
Apollo21
probably a 31.6 with your offset although i'm not positive
SOLD
Apollo21 is offline
post #10 of 45 Old 04-03-2010, 03:27 PM Thread Starter
thierryben
OK , many thanks appolo for your advice ,
and if someone have mounted the DC-2 on his WJ , if they have pictures for me , it's cool
post #11 of 45 Old 04-04-2010, 12:59 PM Thread Starter
thierryben
Hi Guys , it's the **** , I have buy today 4 tyres in 265/75/16 Bridgestone dueler Mud terrain , I have mount 1 tyres this afternoon on a DC-2 with the offset of -12mm and when the car is on a clean flat surface, when I turn the steering wheel, the tyre touch the bumper or the fender ,
I think that the problem is the offset of the rims , and if the Tyre touch the bumper when I turn on a flat surface , I think that I will be big problem in offroad ,
post #12 of 45 Old 04-05-2010, 05:14 AM
Apollo21
it just means you need to trim
SOLD
Apollo21 is offline
post #13 of 45 Old 04-05-2010, 05:17 AM Thread Starter
thierryben
yes , I have look this morning , trim the bumper is not a problem but I'm afraid to trim the inner metalic fender
post #14 of 45 Old 04-05-2010, 07:14 AM
Apollo21
you should not have to trim that part if you are properly bump stopped
SOLD
Apollo21 is offline
post #15 of 45 Old 04-05-2010, 08:31 PM
22remud
ok well from what i can find it has 4inches of back spacing,which is borderline. although it has 4inch of back spacing it is a 16x8 which means it is sticks out further than a wheel with spacers. if the wheel had more back spacing like say 4.5 it would prolly solve some problems. having a wider stance does not realy allow for a bigger tire because it doesnt allow it to fit in the pockets designed for it. with less off set you more prone to hitting your fender and bumper due to the pivot point.
1998 TJ 4.0L NP231, 4inch skyjacker kit
1992 XJ 4.0L NP231, 6inch Gonzo Lift, Cherry Bombed Exhaust,Custom Cowl Snorkel,33x12.50 BFG km m/t's
22remud is offline
Looking for new rims for my WJ, Not sure how offset works mikesd1981 ZJ Grand Cherokee Forum 2 02-12-2009 07:07 AM
Recommended budget lift kit for 33" tyres dxmedia ZJ Grand Cherokee Forum 24 10-19-2008 05:36 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 07:25 AM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 07:15 PM
