what shall i do? Please read! - JeepForum.com
post #1 of 4 Old 11-15-2010, 03:26 PM Thread Starter
XJ57
PLEASE READ I NEED YOUR OPINION>> I have asked alot of questions about this, but i have the hydraulic fan on my wj and i put normal ps fluid in and then it started whining and ive flushed it and on long drives it goes away put around town it whines, now i have a leak from around the ps resivoir and i think its a gasket or o-ring cause the hoses are fine. so i cant decide weather to try to save the P/S pump which it might not be savable or i can buy one from a junkyard for 45$ so what do you think is the best idea?
XJ57 is offline
post #2 of 4 Old 11-15-2010, 05:05 PM
straty1987
clean up the mess with break clean and make sure were the leaking is coming from.
did you upgrade to the new PS hose?
straty1987 is offline
post #3 of 4 Old 11-15-2010, 05:48 PM Thread Starter
XJ57
upgrade?
XJ57 is offline
post #4 of 4 Old 11-15-2010, 08:01 PM
straty1987
yea. 01-04 Grand Cherokee 4.7L Hydraulic Power Steering Hose
the hose was updated since the original one would leak at the fitting were it connects to the pump.
if you leaking at the fitting that this hose connects to on the pump replace it with teh newer version 5019708AE and pick up 2 quarts of PS fluid MS5931from the dealer to replace all the old fluid. 3 quarts if you want some extra. dont take ATF+4 from them
i know a new pump is around $300 and i hear most say its not worth trying a used one.
i posted how to flush the PS and a pic hear if you see your leak at #1 on the pic its a bad hose most likely .
http://www.jeepforum.com/forum/f310/...ement-1103711/
WJ Picture Thread ArloGuthroJeep WJ Grand Cherokee Forum 1980 09-11-2017 08:19 PM
WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) swirls WJ Grand Cherokee Forum 20 02-27-2011 01:54 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
