what to make your wj run better - JeepForum.com
post #1 of 6 Old 03-15-2010, 08:37 AM Thread Starter
fireman88
im getting my 01 wj ready for summer and would like to know what else i can clean to make her run better. i've cleaned my air intake filter, installed a new throttle body cleaned the iac sensor, and oil change and radiator dump, transmission dump about 5,000 miles ago.
fireman88 is offline
post #2 of 6 Old 03-15-2010, 09:26 AM
WJ-matt
How many miles are on the jeep. Try putting some seafoam cleaner threw the motor.
Dude i think i know what your noise is...your jeep is telling me i need a beer....and your gonna need a bigger wallet.
- www.rcoverload.com
WJ-matt is offline
post #3 of 6 Old 03-15-2010, 09:38 AM
xjokee
Check the tire pressure. Amazing how the cold weather zaps the psi's.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #4 of 6 Old 03-15-2010, 10:19 AM
JJAMISON_
2015 JK Wrangler
maybe replece the 4.0 with a 6.1 hemi
JJAMISON_ is offline
post #5 of 6 Old 03-15-2010, 10:32 AM Thread Starter
fireman88
well for now ill stick with my 4.7
post #6 of 6 Old 03-15-2010, 11:30 AM
Eshindi
Replace all other Fluids. (Diff, Xfer Case).
Hope you used good Motor Oil when you did your Oil Change (Mobil 1, GTX, Amsoil, etc)
Look into Replacing wheel hub bearings. When they start to go bad it feels like you are dragging a Cinder block with your front axle.
Grease the heck out of everything, Kunkles, Driveshafts U Joints.
Summer = Hot = Refill your AC if you have to.
Always good to check on your spare tire pressure. Boy does it suck when you need it and its flat.
Check: Steering Fluid Level, Engine Belt, Tire Pressure, Brake Pads, rotors,
Blah blah blah.
Is this your DD, cause it sounds like you might be taking it out of storage.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
did they ever make a ZJ like this? sean87xj ZJ Grand Cherokee Forum 26 06-07-2011 01:20 PM
TSL BOGGERS help me make them fit right jeepheller98 ZJ Grand Cherokee Forum 2 06-26-2008 11:34 AM
What Do I Need To Do To Make My Jeep Look Like This? nickk382 WK Grand Cherokee & XK Commander Forum 7 03-13-2008 12:20 AM
Things that make you go.. HUH?? Niles ZJ Grand Cherokee Forum 5 02-28-2006 01:30 PM
