What kind of 4x4 system is this? - JeepForum.com
post #1 of 4 Old 03-30-2010, 07:13 AM Thread Starter
WoodiE55
The Jeep is a 2000-2001 Grand Cherokee, the owners manual is missing but the center console has the following setup:
2WD
4WD Part Time
4WD Full Time
4WD Low
What 4x4 system is this?
Also, is 4WD Part Time safe to drive on the road - wet or dry or should it only be used off road?
04 Grand Cherokee Special Edition, 4.7 V8, QTII
WoodiE55 is offline
post #2 of 4 Old 03-30-2010, 07:26 AM
charlesshoults
Selec-Trac
This sounds like the Selec-Trac system in the NP242 transfer case.
NP242 - JeepForum.com Community Jeep Wiki
* 2WD or 4WD Full Time (2WD or 4 FULLTIME) - In either position, the vehicle may be operated on all road surfaces. In 4WD Full Time, Select Trac offers better traction when roads are wet, snow covered or icy. Use Selec-Trac 4WD Fulltime year-round (full time) if you wish. Comparable to what other vehicles call "all wheel drive."
* N Position (Neutral)- In this position the axles are disengaged from the powertrain. The vehicle may be towed without removing the propeller shafts. Place an automatic transmission in Park or a manual transmission in gear after the N position is engaged.
* 4WD Part Time High Position (4 PARTTIME) - This position provides 4WD for occasional use in low traction driving conditions such as snow, dirt etc. NOT FOR USE ON DRY PAVEMENT as transfer case damage may result.
* 4WD Lo Position (4 LO) - This position provides 4WD for occasional use when *OFF-ROAD* driving conditions require low speed pulling power. NOT FOR USE ON DRY PAVEMENT as transfer case damage may result.
charlesshoults is offline
post #3 of 4 Old 03-30-2010, 07:39 AM Thread Starter
WoodiE55
Thanks so much for the quick and detailed response.
WoodiE55 is offline
post #4 of 4 Old 03-30-2010, 07:42 AM
EisBlade
EisBlade's Avatar
2WD
4WD Part Time
4WD Full Time
4WD Low
edit: Nice and quick reply, charlesshoults. lol I was off in Google land pulling down all this for him.
It looks like its a Selec-Trac, possibly with the NP242 transfer case.... You can find the gearing on the differential bolt tabs. In 4WD Full Time mode you can drive it any time on any surface like all-wheel drive...rain, sleet, mud, etc. For 4WD Part Time mode you'll find that when selected, there is an indicator light that comes on on the dash. This is because this mode is important and that indicator light should be considered as a WARNING....in that, Part Time should only be used for that - part of the time, those times when you are only on a slippery surface such as off-roading in mud, snow, etc. The TC locks front and back as one and the wheels will hop or lock up if on the highway. Being on a slippery surface allows driveline stresses to relieve themselves as is needed.
Selec-Trac, look it up:
1) Jeep four wheel drive systems - Wikipedia, the free encyclopedia
Though you'll read that the Selec-Trac was discontinued in favor of the Quadra-Drive II, the NV242 transfer case offers more gear modes and is the preferred. The Quadra-Drive II WJ's came equipped with axles having vari-lok differentials, a type of locker activated by the buildup of pressure from a spinning tire. I upgraded my axles to this and find them to be...not worth the money, and would put Aussie's in if I had to do it all over again.
2) Jeep - 4x4 Basics - 4x4 Systems by Vehicle - 4WD SUVs
Not a bad read, and helps explain a lot.
3) Jeep Select Trac NP 242 Transfer Case Information
Great article. Poke around for more info...
Hope that helps!
JT
Harley-Davidson Touring Group
EisBlade is offline
Service 4x4 System AND Service Electonic Brake System...? TatorTodd WK Grand Cherokee & XK Commander Forum 0 12-25-2009 09:49 PM
What kind of starter to buy go4x4it ZJ Grand Cherokee Forum 5 03-17-2009 03:12 AM
How do I get Vehicle Entertainment System turned on in my Nav system? JeepSam ZJ Grand Cherokee Forum 10 06-03-2005 04:46 PM
What Kind Of Gas? illz302 ZJ Grand Cherokee Forum 10 05-18-2005 10:27 AM
Kind of want to get a GC kairo ZJ Grand Cherokee Forum 12 07-01-2004 12:23 PM
