What are fuses F32 F33 in the fuse block for? - JeepForum.com
post #1 of 6 Old 10-05-2013, 05:51 PM Thread Starter
grussell
Wj What are fuses F32 F33 in the fuse block for?
F32 - Ignition Run / Start - Airbag
F33 - Ignition Run / Only - Airbag
I do not have fuses in either slot and I checked each slot with my volt meter and both circuits are hot.
Should they have fuses?
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #2 of 6 Old 10-05-2013, 06:26 PM
rm2001wj
rm2001wj's Avatar
The attached diagram (from the 01 FSM) shows that power to the airbag module goes through them. I would guess that without those two fuses the airbags won't work. That the fuses are missing is sort of suspicious.
rm2001wj is offline
post #3 of 6 Old 10-05-2013, 10:36 PM Thread Starter
grussell
I guess tomorrow I will stick a couple of fuses in and see what happens. Thanks for the wiring diagram. Where did your
Get your FSM?
grussell is offline
post #4 of 6 Old 10-06-2013, 10:44 AM
rm2001wj
rm2001wj's Avatar
PM sent.
rm2001wj is offline
post #5 of 6 Old 10-06-2013, 12:34 PM
rdkendrick
2003 WJ
Originally Posted by grussell View Post
I guess tomorrow I will stick a couple of fuses in and see what happens. Thanks for the wiring diagram. Where did your Get your FSM?
Don't be sitting in front of the steering wheel when you do that, or at least, disconnect your negative cable. You can buy FSM's off of eBay and websites. Some, you can download, free.
Sent from my iPad using my fingers
rdkendrick is offline
post #6 of 6 Old 10-06-2013, 06:13 PM Thread Starter
grussell
Yea, I put the fuses in while I had the battery cable unhooked cleaning the connection. Fuses are in and no lights are on on the cluster. It is odd that they were missing. I have been all in and around the Jeep and there are no signs off prior collision damage.
Thanks for the diagram rm2001WJ.
grussell is offline
