what do I need to know before I swap a rear JK D44? - JeepForum.com
post #1 of 2 Old 02-06-2014, 10:43 PM Thread Starter
MEinSoCal
Wj what do I need to know before I swap a rear JK D44?
do i need extended or different brake lines?
what about emergency brake, what do i have to do for this?
i have the rear drive shaft from the 4.0L V8, that was mated to a 242HD, will this be a direct bolt on to the JK D44?
since i have the non-Rubicon axle, i don't have the e-locker, so no need to worry about any wiring for that.
not really worried about the spring, shock and sway bar mounts, as those will all be custom done.
anything else I didn't cover and should know about before i get started?
MEinSoCal is offline
post #2 of 2 Old 02-07-2014, 09:38 AM
3JsWJ
I think you're good for the most part. Your single brake line should mount to the JK brake line at the T on the axle. You stock e-brake cables will attach to the new JK system.
Don't know about driveshaft as that would be custom to your setup.
04 WJ-4.7, 242HD, JK D44, JK HP30, 4" IRO, LSR Bumper, Warn M8000, 33" MTZ
03 WJ-SOLD
3JsWJ is offline
