What Diff?? - JeepForum.com
post #1 of 5 Old 01-04-2011, 09:03 AM Thread Starter
TomWJ
What Diff??
I have a 2000 4.7 with QDrive trans. My front diff is noisy and I want to change the whole axle out whilst I rebuild.
Will a front axle out of a Qtrac car work (assuming correct ratio)?
TomWJ is offline
post #2 of 5 Old 01-04-2011, 09:14 AM
FirefightinWJ
All V8 WJ's have the Dana 30 front and Dana 44a rear with 3.73 gears. Any axle would work, although some came equipped with a Vari-Lock LSD.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #3 of 5 Old 01-04-2011, 09:26 AM
rm2001wj
rm2001wj's Avatar
With QDrive you do have a Vari-Loc front differential. Although a Qtrac (actually it's Quadra-Trac II) front differential will work, you will lose the Vari-Loc LSD function.
rm2001wj is offline
post #4 of 5 Old 01-04-2011, 02:57 PM
MEinSoCal
if i want to add a LSD up front in my D30, which diff can i put into my stock D30?
MEinSoCal is offline
post #5 of 5 Old 01-04-2011, 03:24 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
quadradrive vehicles have the spicer hydralock(jeep varilock) lsd in them(requires different length axle shafts from the open diffs or other lsd types.
if you just want to add an lsd case there are many options available. the true track being one of the highest rated.
ratmonkey is offline
ARB diff covers WJwheelin WJ Grand Cherokee Forum 22 12-13-2010 04:29 AM
Diff overflow Apollo21 WJ Grand Cherokee Forum 8 11-05-2010 08:59 AM
rear diff ... browning WJ Grand Cherokee Forum 2 08-27-2010 05:23 PM
Diff of Yoke sicWJofNWA WJ Grand Cherokee Forum 2 04-26-2010 06:56 PM
Diff fluid- which to use? YJinMN WJ Grand Cherokee Forum 6 08-11-2007 08:27 PM
