What did you do to your WJ today? - Page 950 - JeepForum.com
 1099Likes
post #14236 of 45734 Old 10-21-2012, 08:32 AM
lord-steezus
Yeah I was looking on their page, everything is hella expensive. The cb radio antenna holder is $25. Do you guys have any suggestions for what to use/do if I want mount an antenna that way
-Chris
02 wj
my build thread
lord-steezus is offline
post #14237 of 45734 Old 10-21-2012, 08:43 AM
roadcrew
I have used my shackles and I feel for what I paid they are worth it. And the antenna mount is a simple DIY. I used a scrap piece of metal I had and cut it to fit and drilled a few holes.
roadcrew is offline
post #14238 of 45734 Old 10-21-2012, 09:04 AM
rickcricket
Trying to figure out how this happened. Maybe a little too much change in my ashtray?
If anyone has a black one with heated seat controls, let me know!
rickcricket is offline
post #14239 of 45734 Old 10-21-2012, 09:06 AM
lord-steezus
How much and how big is your whip? Did you bolt it on inside the light?
-Chris
02 wj
my build thread
post #14240 of 45734 Old 10-21-2012, 09:50 AM
roadcrew
5' fire stick. When you take out the tail light assembly the top edge of the body is nice and flat. My DIY mount is about 5 or 6" long by about 3" wide. Tapered the outer side to contour around the antenna and so not to snag your arm of you were to get close. I used 6 self tapping screws up in to the body. Pretty easy really.
I did notice the store bought mounts have a bend in them and my flat one makes my antenna point foward just little. It doesn't bother me, so I left it but I'm sure you could bend it to sit straight.
roadcrew is offline
post #14241 of 45734 Old 10-21-2012, 10:24 AM
lord-steezus
Definitely going to look into that! Thanks man
-Chris
02 wj
my build thread
post #14242 of 45734 Old 10-21-2012, 11:46 AM
Timbo24
I think you can just push that back ^in. Just line up the black tabs with the red holes.
Timbo24 is offline
post #14243 of 45734 Old 10-21-2012, 11:50 AM
MacsWJ
Spend about a week removing the Gold.
Went from this
to this
MacsWJ is offline
post #14244 of 45734 Old 10-21-2012, 11:57 AM
twinscrews
2003 WJ
Found out that I was the the first person to show my t/c any love.. Opened it up and black fluid came out with surprisingly large flakes of metal in it grrr.. also on a bright note installed a fumoto engine oil drain valve
twinscrews is offline
post #14245 of 45734 Old 10-21-2012, 12:49 PM
pinky2252s
Mine pops out every once and a while. Just pop it back in.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #14246 of 45734 Old 10-21-2012, 01:06 PM
Dasko
beginning to think i need a new alternator. no power to anything unless i jump it. has anyone done the Durango alt swap?
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #14247 of 45734 Old 10-21-2012, 01:42 PM
mrJ
2002 KJ Liberty
re-did the sliders and a little of the body with duplicolor spray-on bedliner. not bad...comes out a little thick and left a few drip marks, but from the top it looks fine. might sand the drips down this week and put on another coat. going to try and do fender lines and wheel wells before next weekend. also got my tantrum rock lights laid out/mocked up. going to have the main wire come in the trunk where i cut out spare tire, and run to junction box under my rear seat. i ran the wire along the e-brake line, and up into my center console so the control box will be in the CC. ran the power wire under center console up to power wire. going to re-install CC and back seat this week. still have them out from lizard-skinning the floor a couple weeks back.
Build In Progress...
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #14248 of 45734 Old 10-21-2012, 01:44 PM
03azwj
2003 WJ
Originally Posted by mixahjones
Thought about what i wanted to do next to the wj.
Used a ledge to my advantage...
What grill is that?
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #14249 of 45734 Old 10-21-2012, 02:14 PM
ZB_WJ
Originally Posted by 03azwj
What grill is that?
That's an 04 grille with plastidip'd insert IIRC
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #14250 of 45734 Old 10-21-2012, 02:18 PM
rickcricket
I wish. The tab on the right side broke off and stuck in the hole.
BOT. Drove it to my new hunting spot and she performed admirably. Heater core will be getting done next weekend so I don't have to smell those fumes all winter.
wj
jamesrw30
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
