What did you do to your WJ today? - Page 941 - JeepForum.com
 738Likes
post #14101 of 44514 Old 10-15-2012, 08:07 PM
wvracer821
wvracer821's Avatar
Originally Posted by 99Limited View Post
Link?
http://www.ebay.com/itm/1999-2004-JE...a39011&vxp=mtr
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #14102 of 44514 Old 10-15-2012, 08:23 PM
Primm907
Bought it, changed the TPS, and washed it. Then promptly ordered OME 3" HD springs, Bilstein 5100's, JKS trackbar, Pro Comp 7069 wheels, and BFG KM2's tonight from Nick @ Kolak. Can't wait!
2001 4.7 Laredo, 100% stock
Loaded 1-owner w/60k original miles and dealer maintained
Primm907 is offline
post #14103 of 44514 Old 10-15-2012, 08:26 PM
04Overland47
04Overland47's Avatar
Originally Posted by MattND
Question.. why does the little bottle of Mopar friction modifier come in 4oz when you need 2.5oz per axle? They should make it a 5oz bottle so I only need one!
You actually need 2.5oz for the front and 4oz for the rear.
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is online now
post #14104 of 44514 Old 10-15-2012, 08:27 PM
mycreativename
Attempted to put on my new Flowmaster 50 and found out my entire life has been a lie up until this point... Alright so maybe I just found out that from my muffler forward everything is 2 1/4 inch instead of 2 1/2 as previously assumed, but still haha.
Is that how all the V8 WJ's are, or did my previous owner replace the exhaust with parts to a I6?
Wasting no time at all, I like it
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #14105 of 44514 Old 10-15-2012, 09:27 PM
Shaggs2Dope
Drained and refilled my transfer case (local repair shop topped it off with ATF after fixing a leak..after I told him to use the Mopar stuff) The fluid was quite dirty.. who knows when it was done last. Also drained and refilled both diffs.. front one looked like it had never been done 110k miles on the WJ. The rear looked as if it had been done at least once before. Hope I dont have any issues with that front diff.
So you have to buy two and they make more money.
Sent from my Rezound using JeepForum
juggalo
Shaggs2Dope is offline
post #14106 of 44514 Old 10-15-2012, 10:16 PM
sicWJofNWA
dubs been down for the past two months as i work like a dog to get enough money saved up so i could keep feeding the Jeep cash. ordered addco rear sway bay, new optima yellow top, IRO 242HD hack and tap sye, IRO brake lines, 285/75R16 BFG KM2's, and this is the one I'm most excited about, 4.11 gears for the 44A. next pay ill get 4.11's for the front as well as master install kits and brgs. also fried the hard drive in the jeep pc so no tunes
:SUSPENSION:
'99 4.7L V8, 45RFE with Trans-go Shift Kit, Kuhmo KL71 265/75R-16 on Cragar Soft 8's, Carolina front double cardon DS, 242HD TC Swap, Aussie Locked 44a, IRO 6.5" premiun lift kit with all arms adjustable, Kolak 5125 bilsteins. IRO adj track bar, IRO dual HD steering stabilizer (in the mail), IRO premium rocksliders (in the mail),
:AUDIO:
Optima Yellow Top. Infinity 475 and 1600a amps. Infinity 4 way 6x9's front, infinity 6" rears, 2 JL W3v3 4 ohm subs.
:CARPC:
Zotac GF9300-ITX mobo w/ wifi, Intel quad core @3.2 gHz, 1tb ssd, 250 Watt dc-dc carnetix power supply, Lilliput 10.2" tochscreen in the dash, Winders 7 home premium. An iTunes library w/ 370 gigs of music.
sicWJofNWA is offline
post #14107 of 44514 Old 10-15-2012, 11:02 PM
99WJ01TJ
Spent 143.00 on a battery then 20.00 on gas because my niece said the car broke down, went to get her. No codes no juice in the battery(she drained it trying to turn it over too many times) she said it had gas because she just put in 10.00. Only for me to put the new battery in, car won't start then i realize she ran out of gas.....I say thought you said you just put 10.00 in gas. She says " I did last night before i left Disneyland" she lives 40 miles away in Fontana. Kids, what can you do?
99WJ01TJ is offline
post #14108 of 44514 Old 10-16-2012, 01:04 AM
03azwj
2003 WJ
Same setup I got from Nick only different wheel and tire combo. Just waiting on the shocks and then time for install...only my problem is, I have NO idea what I'm doing.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #14109 of 44514 Old 10-16-2012, 01:47 AM
LilLuKe
There really ain't nothin to it...as long as you have the tools which really ain't that many either, and can follow directions then your good to go.
LilLuKe is offline
post #14110 of 44514 Old 10-16-2012, 07:04 AM
mrJ
2002 KJ Liberty
overheated. changed tstat. overheated again, CEL 1499 Hydraulic Fan Solenoid. Anyone know where to get one or how to solve this? I'm freaking out and can't find the part anywhere.
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #14111 of 44514 Old 10-16-2012, 07:20 AM
little_Jeep
Man you got a problem....... Most WJ's have an electric and/or a mechanical fan. I've never seen a WJ with a hydraulic fan. I'd have to look at that CEL, but if your electric fan isn't working, you may have a bad relay (under pass headlight).
little_Jeep is offline
post #14112 of 44514 Old 10-16-2012, 07:30 AM
mrJ
2002 KJ Liberty
CEL p1499
mrJ is offline
post #14113 of 44514 Old 10-16-2012, 07:36 AM
dpshoup
2011 WK
CEL p1499
Symptom:
P1499 - HYDRAULIC FAN SOLENOID CIRCUIT
POSSIBLE CAUSES
INTERMITTENT CONDITION
FUSED ASD RELAY OUTPUT
HYDRAULIC FAN SOLENOID PWM CIRCUIT SHORT TO GROUND
HYDRAULIC FAN SOLENOID PWM CIRCUIT OPEN
PCM
TEST ACTION APPLICABILITY
1 Ignition on, engine not running.
With the DRBIIIt, perform the Hydraulic Fan Solenoid Test found under Engine Test
and Systems Test.
Does the Radiator Fan operate properly?
All
Yes ! Go To 2
No ! Go To 3
2 At this time, the conditions required to set the DTC are not present.
NOTE: Use the Freeze Frame Data to help you duplicate the conditions that
set the DTC. Pay particular attention to the DTC set conditions, such as,
VSS, MAP, ECT, and Load.
NOTE: Visually inspect the related wire harness. Look for any chafed,
pierced, pinched, or partially broken wires.
NOTE: Visually inspect the related wire harness connectors. Look for
broken, bent, pushed out, or corroded terminals.
NOTE: Refer to any Technical Service Bulletins (TSB’s) that may apply.
Perform a wiggle test of the Hydraulic Fan Solenoid wiring while actuating the Fan
with the DRBIIIt.
Watch the Fan to see if it quits working, also watch for the Good Trip Counter to
change to 0.
Did the Hydraulic Fan ever stop or start moving during the wiggle test?
All
Yes ! Repair as necessary where wiggling caused problem to appear.
Perform POWERTRAIN VERIFICATION TEST VER - 2.
No ! Test Complete.
3 Ignition on, engine not running.
Using a 12-volt test light connect to ground, probe the Fused ASD Relay Output
circuit at the fan solenoid.
With the DRBIIIt, actuate the ASD Relay.
Does the test light illuminate brightly when the ASD Relay is actuated?
All
Yes ! Go To 4
No ! Repair the open in the Fused ASD Relay Output circuit. Inspect
the related fuse and repair as necessary.
214
DRIVEABILITY - GAS
4 Turn the ignition off.
Disconnect the Radiator Fan harness connector.
Disconnect the PCM harness connector(s).
Measure the resistance between ground and the Hydraulic Fan Solenoid PWM
circuit.
Is the resistance below 100 ohms?
All
Yes ! Repair the short to ground in the Hydraulic Fan PWM circuit.
No ! Go To 5
5 Turn the ignition off.
Disconnect the Hydraulic Fan Solenoid harness connector.
Measure the resistance of the Hydraulic Fan Solenoid PWM circuit from the fan
harness connector to the PCM harness connector.
Is the resistance below 5.0 ohms?
All
Yes ! Go To 6
No ! Repair the open in the Hydraulic Fan Solenoid PWM circuit.
6 Turn the ignition off.
Backprobe the Hydraulic Fan Solenoid PWM circuit at the PCM harness connector.
Remove the ASD Relay and use a jumper wire to keep the ASD Output circuit
powered up for this step only.
Connect a jumper wire to the Hydraulic Fan Solenoid PWM circuit in the PCM
harness connector.
Momentarily connect the other end of the jumper wire to ground.
Did the Radiator Fan actuate?
All
Yes ! Go To 7
No ! Replace the Hydraulid Radiator Fan Solenoid.
7 If there are no possible causes remaining, view repair. All
Repair
Replace and program the Powertrain Control Module in accordance
with the Service Information.
215
DRIVEABILITY - GAS
P1499 - HYDRAULIC FAN SOLENOID CIRCUIT — C
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
02 WJ-4.7 My DD [04 WJ-4.0, 00 XJ-4.0 Gone]
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #14114 of 44514 Old 10-16-2012, 08:15 AM
USMCBehrensDVLD
Originally Posted by cbailey_21 View Post
I installed my eBay led tail lights, they look great IMO
Attachment 490402
Attachment 490403
as much as people hate the eBay head lights/ tail lights they still look good for the price
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
post #14115 of 44514 Old 10-16-2012, 08:23 AM
little_Jeep
Here is a thread on that Hydraulic Fan Solenoid.
http://**********.org/f203/p1499-code-11211.html
I have no idea why this forum won't let me post a link to a thread about this subject that is hoisted on another forum.
The first half of the above link is:
jeep garage dot org (without the spaces)
wj
HarryH3
