What did you do to your WJ today? - Page 81 - JeepForum.com
 866Likes
post #1201 of 45177 Old 01-15-2011, 09:22 PM
roach68
Installed a new radio, JVC KD-A615 with SWI-jack. Works great and looks good. Also bought new rear brake pads and rotors, stuff to do a rear diff fluid change, new axle shaft bearing and seal. Now i just need a warm snow free day
roach68 is offline
post #1202 of 45177 Old 01-15-2011, 09:43 PM
rfjeeper
Drove it home from work and listened to my Green Bay Packers whoop but on the Falcons,Life is good!!
rfjeeper is offline
post #1203 of 45177 Old 01-16-2011, 06:42 AM
huntandfish
Originally Posted by huntandfish View Post
pulled a guy out of a water hole that swamped his nissan. then towed him on base. good times. new tow strap worked like a charm.
pics from said event.
1992 YJ 2.5 SOLD
2004 Grand Cherokee Special Edition 4.0
IRO 3",JKS BPE's,DoetschTech8000's,Tenneco SS,Cooper Discoverer STT's 245-75R16,RC wheel spacers,SSBC Slotted Rotors, IRO Prem-sliders...
A great place for outdoorsmen in the NW.
Member Screen name- addicted
huntandfish is offline
post #1204 of 45177 Old 01-16-2011, 10:52 AM
4X4COWBOY
Originally Posted by Akrobatiks View Post
Thanks sooo much!!! I'm really happy with how everything is turning out and Im loving the HID's!!! They were really easy to install bro...!! Basically plug and play for the HID's... The halos and LED's were as simple as hooking them up to the parking lights... Took about an hour because I took my time and taped off all the connections and wrapped them up all nice...
Did you put a xenon bulbs in the high and low beams or just low?
2001 WJ 4.7L V8, 6.5" IRO Critical Path Long Arms, 255/75/17 Firestone Destination M/T's, 17" JK Moabs, Flowmaster Super 40, SpiderTrax 1.25" Spacers, Hunter Bull Bar w/ Fawkes Fab Relocation Brackets, 5/8" ARB Shackles, JCR Stage 2 Sliders
4X4COWBOY is offline
post #1205 of 45177 Old 01-16-2011, 12:13 PM
wj4play
New window regulator today.... cheapo cable fix finally failed, you know the MOD that you groove the metal cuz the plastic broke......
Oh well fixed for good now guess its time to get new speakers to make it worth while HAHA
Failed
Re attach from broken plastic piece
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is online now
post #1206 of 45177 Old 01-16-2011, 12:22 PM
85IrocZ-28
Do you have any pics of how it failed? I did that fix to my pass side front last spring, and it has held ever since. I keep wondering how long it will last though.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #1207 of 45177 Old 01-16-2011, 12:43 PM
wj4play
Yea, I will get some posted. What is failing on it is the cable jumps the pullywheel at the top, then binds up the cable against the frame. I will update my post with the pics shortly or tonight
post #1208 of 45177 Old 01-16-2011, 04:03 PM
ARFuniN
Changed the oil and installed a Fleetguard - LF3487 oil filter.
ARFuniN is offline
post #1209 of 45177 Old 01-16-2011, 05:53 PM
wj4play
is that for the 4.0 I6 ?
post #1210 of 45177 Old 01-16-2011, 06:16 PM
little_Jeep
Tomorrow, I get to change the Crankshaft Postion Sensor, & fuel filter in my 2000 WJ.
little_Jeep is offline
post #1211 of 45177 Old 01-16-2011, 06:25 PM Thread Starter
SplitNail
Have a great amount of fun with the fuel filter!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #1212 of 45177 Old 01-16-2011, 06:32 PM
mrJ
2002 KJ Liberty
see, if you cut out your spare well and do the gas tank lift, the filter's right there. no problemo. bam. problem solved. i put a piece of metal over the hole with duct sponge tape stuff around it and held with self tapping screws so i can take it off for maint whenever i need
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #1213 of 45177 Old 01-16-2011, 06:45 PM
88yjproject
Originally Posted by Scibbyz99WJ View Post
is your tire rubbing against your rubber shock boot? i noticed the same rubber smell from mine and couldnt figure it out. until i put new pads on the back and my shock boot was tore up from the tire
I checked that. Nothing rubbing. I took apart the brakes and cleaned off the mud and leaves. Still does it. I wonder if the new pads are making smell. They are mopar pads. I know that doesn't mean much. It could be all the gear lube that did leak out, but I cleaned that all off good when I replaced my seals. That is when I did my pads too. I will look into it more this week at work.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #1214 of 45177 Old 01-16-2011, 07:40 PM
ARFuniN
4.0 & 4.7 non-HO both use the same filter. See wjjeeps for the Puralator longer option and cross recerence it to the Fleetguard.
ARFuniN is offline
post #1215 of 45177 Old 01-16-2011, 07:43 PM
little_Jeep
I'm doing the fuel filter (inline canister), not the fuel pump assembly... It doesn't look like more than a 10 minute job. Am I in for a surprise? Only reason for changing it is I still have the OEM, 11 years and 165K miles later.
The CPS looks like a "fun" little job considering I can't even see it from up top, until I remove some stuff.
wj
MrAb3z , NMalinov
