What did you do to your WJ today? - Page 801 - JeepForum.com
 1092Likes
post #12001 of 45727 Old 07-09-2012, 09:05 AM
robby65
2007 XK Commander
Originally Posted by little_Jeep View Post
Yep..... replacing that Crank Postion Sensor on the WJ with a 4.0L is a "Fun" job... there are several threads on this forum that offer tricks and directions on making the job less "fun". I know, doesn't help you, but might help others .
For my first time doing this it really wasn't that bad.
I googled and followed post # 15 here:
http://jeepsunlimited.com/forums/sho...d.php?t=526885
post 20 has the pics.
The only thing i did to help me was to drop the driver side trans cross member.
Just loosened the 4 bolts enough to let it drop down a bit, then was able to put bolt and heat shield back on sensor by hand from the top of motor.then went through trans shifter cable hole as stated in post and tightened it back up.
robby65 is offline
post #12002 of 45727 Old 07-09-2012, 11:40 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Drove 778 miles to go visit the parents in Baltimore. Used... wait for it... 38.1 gallons of fuel for a true 20.42 MPG. EVIC said 23.1, but whatever. Also put a can of R134 in it because the air wasn't blowing as cold as it used to. All better now.
In the garage: M1 4bbl
McCloudsZJ is offline
post #12003 of 45727 Old 07-09-2012, 11:51 AM
liquidxit2
Wow you must have taken the looooooong way from elkton to Baltimore...
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #12004 of 45727 Old 07-09-2012, 11:57 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Oops... I haven't lived in etown since last November. Guess it's time to update that.
post #12005 of 45727 Old 07-09-2012, 12:16 PM
FULLJEEP
Originally Posted by PhantomWJ View Post
hey, looks like mine....mine is made out of electrical conduit...yes, that is what I said....hey, and guess what....it does its job....with a full spare, full ice chest loaded...bikes, everything...
FULLJEEP: you might need more vertical supports between the top and bottom frames...those 2-3 T fitting along the "long" side and 2 along the "narrow" side....why? cause you never now where that ratchet strap is going to end and you might break those little plates you screwed on there...they dont look very strong.
Is not finished yet, will put 2 vertical plates on each side, thd straps is for holdi g and keeping ig togethe thanks for the rec's
FULLJEEP is offline
post #12006 of 45727 Old 07-09-2012, 01:21 PM
FULLJEEP
FULLJEEP is offline
post #12007 of 45727 Old 07-09-2012, 01:50 PM
SwissWJ
New Heater core, nice not to have the coolant smell anymore. New WIX fuel filter, hoping to see a mpg increase but not holding my breath.
SwissWJ is offline
post #12008 of 45727 Old 07-09-2012, 02:38 PM
mattcofc
Replaced the oil sending unit. It was reading 0 oil pressure and a little bit of oil was leaking out around the unit. Checked the pressure with a manual gauge and it read just fine. Not too bad.
mattcofc is offline
post #12009 of 45727 Old 07-09-2012, 03:27 PM
peytonimor7
Originally Posted by buns_1 View Post
^^That is the Warn front receiver.
Just dropped it off to get aligned. Also decided to have them do the transmission fluid and filters while its there.
How many miles on your tranny since the last change? I'd really like to change mine at 91k but I've heard it's bad for it if you go a long time without changing the fluid. My fluid looks nice and pink though.
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #12010 of 45727 Old 07-09-2012, 03:31 PM
buns_1
I couldn't tell you. I got my WJ with 109,000 and now its getting close to 130,000. Didn't get the previous owners service records.
04 WJ Overland, 3" IRO Lift, Yakima Rack, 255/75/17 BFG KM's, ARB bumper and custom rear bumper.
buns_1 is offline
post #12011 of 45727 Old 07-09-2012, 04:22 PM
pincheburro956
Cut off a piece of the swaybar bracket on the axle side. Now my TRE doesn't contact the bracket at full lock.
Also, replaced a rear sway bar bushing and rotated my tires...
Slowly but surely getting rid of all the clunks....
http://i1139.photobucket.com/albums/...709_144640.jpg
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #12012 of 45727 Old 07-09-2012, 04:26 PM
cbailey_21
Installed my bds 2" springs with bilsteins and isolators. Netted 2 3/8" all the way around.
Before and after shot.
Originally Posted by smuggler View Post
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #12013 of 45727 Old 07-09-2012, 08:45 PM
4x4troy
1994 ZJ
i did this....
got bored and pulled out the sawzall and cutoff wheel......rear roof section gone....
96'zj 5.2 project
looking for a gift for your woman. check out
4x4troy is offline
post #12014 of 45727 Old 07-09-2012, 09:22 PM
mrJ
2002 KJ Liberty
Originally Posted by 4x4troy
i did this....
Looks like a Subaru outback
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #12015 of 45727 Old 07-09-2012, 09:27 PM
4x4Jeep
Originally Posted by 4x4troy View Post
i did this....
that looks pretty sweet...does look like an outback a bit.
Build -
SOLD
4x4Jeep is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
