What did you do to your WJ today? - Page 765 - JeepForum.com
 866Likes
post #11461 of 45178 Old 06-18-2012, 12:56 PM
ZB_WJ
I only use ethanol free premium. In Missouri they have to put right on the pimp if it has ethanol or ethanol free. I ran the mid grade ethanol free and didn't like it, now stick with premium.
Pump not pimp. Lol
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #11462 of 45178 Old 06-18-2012, 02:38 PM
rickcricket
Pump not pimp. Lol
Where you from in the great state of "misery"?
rickcricket is offline
post #11463 of 45178 Old 06-18-2012, 02:46 PM
narnwv
narnwv's Avatar
Pump not pimp. Lol
There's only 1 pump within 50-70 miles of me that has ethanol free, and all they have is 90.
For anyone else that cares to look: http://pure-gas.org/
~Aaron
narnwv is offline
post #11464 of 45178 Old 06-18-2012, 03:19 PM
mrJ
2002 KJ Liberty
got the cross-pin out of the carrier in my 44a. It looks kinda haggard....should i be worried? a co-worker suggested a bent shaft or bad bearing(s) bc of the wear. another suggested it was normal wear for wheeling...
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #11465 of 45178 Old 06-18-2012, 03:23 PM
ablaydes
2003 WJ
Installed my new Zone Offroad front sway bar links, took 20 min
Pics in my build thread
03' Jeep WJ|4x4 select-trac|Kolaks "Magic Setup"|OME HDS|Bilsteins 5100's|3/4 spacers front|Moog STB SS|Zone 3" sway links|Homebrewed quick Disco's|17" Moabs|32" BFG's KM's|Hella 500ff's|Rear Oem receiver|Front custom tow Points|Smittybilt receiver 3/4 D-ring|Limited headlights and Grille|
My Build thread
ROLL TIDE ROLL ! ! !
Well let me just quote the late-great Colonel Sanders, who said...I'm too drunk to taste this chicken !
ablaydes is offline
post #11466 of 45178 Old 06-18-2012, 03:27 PM
luckychase5
First part of my lift has arrived!
Current Jeep: 2002 WJ Overland
Past Jeeps:93 ZJ, 96 XJ, 81 J10
luckychase5 is offline
post #11467 of 45178 Old 06-18-2012, 03:47 PM
PhantomWJ
2003 WJ
Wow, good thing you bought a new one to go with that locker.
Yes, a bent axle shaft can cause premature wear or complete failure of the crosspin; breakage. Once it breaks it can chew up things like, pinion gear, ring, gear, locker, carrier, bearing, etc....
The pinion shaft can cause the locker to wear, too.
By the looks of your picture, it looks like the spider gears wore out that cross pin. I read it is normal, somewhat normal, during off road use because the of the high revolutions the spider gears encounter, like when trying to get unstuck, that the gears fling the oil away from where it is needed. And, since the crosspin kinda holds the internal together, it made sense and I couldn't disprove it. :idunno:
Did the spider gears look worn?
Here I found something similar to what I had read a while back....http://www.ringpinion.com/TechnicalHelp/FAQ.aspx 2/3 of the way down
http://jeepdex.com/Commander/DOCS1/R...ediagnosis.pdf
PhantomWJ is offline
post #11468 of 45178 Old 06-18-2012, 04:19 PM
fumblefingers
2014 WK
Originally Posted by MWyatt View Post
Regular just dropped to $3.99 where I live in Cali..... you guys are lucky!
paid 3.22 in Florida last night
fumblefingers is offline
post #11469 of 45178 Old 06-18-2012, 04:46 PM
mrJ
2002 KJ Liberty
That's basically how my brother in-law explained it. Makes sense. Like stressing your u-joints when a spinning wheel catches. The spiders were a little chipped here and there, but ring and pinion are fine. I got the one spider out and had to go go. Might go back in a little bit to loosen axle shaft, get other spider out, and spray down one final time with brakleen
mrJ is offline
post #11470 of 45178 Old 06-18-2012, 04:50 PM
bigredhawkeye
Just purchased a Monstaliner 1 gallon black kit to paint over my bumpers and rocker panels. Used Herculiner on them last year but it is already almost all faded and looks awful, so I figured I'd give Monstaliner a try.
bigredhawkeye is offline
post #11471 of 45178 Old 06-18-2012, 06:32 PM
USMCBehrensDVLD
finally got my new IRO track bar installed, alignment tomorrow and hopefully then end of the vibrations I've been having for the last couple weeks
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
post #11472 of 45178 Old 06-18-2012, 07:01 PM
roadcrew
Originally Posted by roadcrew View Post
Went to the cliffs today and got to play a little bit. Met two stock yotas and had a good time. It was mostly quads and bikes and trailer queens out there. Then went zip lining with the wife.
All you get is a parking lot pic till I DL the pics from the camera.
as promised..
I should have discoed my sway bar, was a little stiff with the addco rear and kept stopping everytime a front and rear got air. man do i want lockers.
wishing for some air( sorry for blurry pics)
this guy was catching air but his suspention was a little better. sorry no action shot
we went and played in the river after this but i lost my photographer.
here is the the zip line over the parking lot
http://s49.photobucket.com/albums/f2...t=M4H03254.mp4
had a great weekend in the dub.
roadcrew is offline
post #11473 of 45178 Old 06-18-2012, 08:30 PM
mrJ
2002 KJ Liberty
let my buddy borrow the dub to be the test subject for HDR with his new D7000. This is his first attempt so far. Check out his site 4lowphoto.com for more offroad/jeep pics!
mrJ is offline
post #11474 of 45178 Old 06-18-2012, 08:31 PM
PhantomWJ
2003 WJ
JEEP PORN
post #11475 of 45178 Old 06-18-2012, 08:55 PM
MadMonk
FINALLY got my Jeep back out of the shop (18 days), with a brand, spankin-new engine rebuild completed. I had to take a picture, it hasn't been this clean since it left the showroom.
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
wj
Frambo , Kxf327
