What did you do to your WJ today? - Page 744 - JeepForum.com
 681Likes
post #11146 of 44162 Old 06-05-2012, 06:06 PM
Cnolenwj
Finally got that sob fan/clutch off (boy was that a pain) put a new clutch on and still have the same problem.
Jeep runs at the right temp at slow speeds, even on a 3hr trail run I did the other weekend in 90 degree heat.
Get on the road running 50mph temp will go about 1/8 past 210 and at 70mph will go just over 1/4 past.
Have never seen this problem. The clutch had play so figured simple fix, of course not.
May try water pump next.
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #11147 of 44162 Old 06-05-2012, 06:37 PM
Scurv14
Wj
check radiator hoses and all. make sure you dont have coolant leaking. busted upper hose on mine after i got it. check before it way over heats.made that mistake already.
Scurv14 is offline
post #11148 of 44162 Old 06-05-2012, 07:29 PM
C5_WJ
Took the WJ out on the beach in Corolla, NC. went through some pretty deep stuff as well, good times...
02' WJ Special Edition; stock on BFG AT's (Workhorse)
C5 Corvette; full bolt ons (track car)
1966 Mustang Coupe (project vehicle)
BMW E36 3 series (beater)
C5_WJ is offline
post #11149 of 44162 Old 06-05-2012, 08:28 PM
MWyatt
Cut my fenders a little...
Time for 33s!
Also noticed my e-fan isn't turning on. Did the full blast AC check and no fan. Time to replace the relay
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #11150 of 44162 Old 06-05-2012, 08:43 PM
SBWJ
So just like many others im sure i had an overheating issue for a while and if the wj sat still in one place for too long it would slowly heat up becuase the electric fan wouldnt work, i finally went and bought a new electric fan and relay and it started to work.... once in a while. I was completly lost after tons of research on this! so im just staring at the set up and i notice that the plug that goes from the jeep directly into the fan (the plastic connector) was messed up on the inside! so i get a new connector, rewire it and bam! a stupid little $20 peice of plastic is all it took, i suggest anyone with an overheating problem CHECKS THIS. a simple fix. so happy now
SBWJ is offline
post #11151 of 44162 Old 06-05-2012, 09:31 PM
FULLJEEP
Just bought front a rear control arms from JKS, just receive them, goijng to install tomorrow.
Any special sugestion, thinking of just using standad length, for now.
Need some advice cause, jks are expandable.
FULLJEEP is offline
post #11152 of 44162 Old 06-06-2012, 08:01 AM
Bretthn
Originally Posted by liquidxit2 View Post
Front and rear service with new covers.
Attachment 409785
Attachment 409786
What covers are these? I am looking for stockish options with solid fill plugs.
Bretthn is offline
post #11153 of 44162 Old 06-06-2012, 09:45 AM
liquidxit2
Stock d30 and an SRT8 d44a both painted hemi orange. I used high temp rattle cans from advanced auto.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #11154 of 44162 Old 06-06-2012, 09:50 AM
USMCBehrensDVLD
Got a few things done this weekend. Painted my front grill and finally got my JCR stage II rock sliders, painted and installed, still iffy on them though.
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
post #11155 of 44162 Old 06-06-2012, 10:05 AM
mrJ
2002 KJ Liberty
ive had my stage 2's for a while. they're solid. i've dropped onto rocks/concrete quite a few times
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #11156 of 44162 Old 06-06-2012, 10:05 AM
aleet25
2003 WJ
I'd be happy to take those sliders off of your hands.
aleet25 is offline
post #11157 of 44162 Old 06-06-2012, 10:15 AM
wj4play
make sure radiator tubes are not plugged with the stop leak crap if it was PO jeep. or water pump is not circulating fluid
wj4play is offline
post #11158 of 44162 Old 06-06-2012, 11:23 AM
holder14
What about those sliders are you not sure on? What dont you like about them?
2001 Grand Cherokee Laredo 4.0L Patriot Blue (Named ATOM)
Interior: Pioneer DEH-P4900IB Head unit, Eclipse SE6900 6x9 Front speaker, Alpine Type-R 5 1/4 Component Rears, Alpine PDX-F4 Amp.
Exterior: IRO 3 inch Lift, 265/75-R16 General Grabber AT2's, 40' Rigid Industries SR SERIES LED Light Bar, Saguaro 3/4in Shackle mounts, Rola Roof Rack, Kolak Stillen Rotors, EBC green stuff pads, Addco Rear Sway, KOR 1.5" Wheel Spacers
holder14 is offline
post #11159 of 44162 Old 06-06-2012, 12:03 PM
victor_927
Originally Posted by aleet25
i'd be happy to take those sliders off of your hands.
x2
victor_927 is offline
post #11160 of 44162 Old 06-06-2012, 01:48 PM
shannonb
2003 WJ
Washed it earlier this afternoon, only to find out that we have an 85% chance of storms tonight... Tomorrow, its an oil change, possibly new breaks and new air filter.
shannonb is offline
no start , sentry
fayceoff
Died today... jimbo141 WJ Grand Cherokee Forum 29 Yesterday 10:41 AM
