What did you do to your WJ today? - Page 730 - JeepForum.com
 925Likes
post #10936 of 45357 Old 05-27-2012, 08:37 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Originally Posted by ArmedJustice View Post
Removed 2'' spacer lift and installed 3'' OME spring lift with Bilsteins and JKS Track Bar. Had an alignment. Installed 2 of the 4 roof rack lights. Now I am getting ready to give it a wash. Eventually when I am not broke, I will put some 30'' tires on it.
Looks awesome man. I put on my OME HD lift last week and have been really happy. Even with the crappy shocks on it. Bilsteins will be here soon and then it is going to be AMAZING! I have not put on my JKS TB because I am only at 2 inches of lift over stock in all 4 corners.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #10937 of 45357 Old 05-27-2012, 10:17 PM
liquidxit2
Yeah the OME HD and bilsteins are great on our WJs. As for the track bar might as well put it on as its a super easy install.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #10938 of 45357 Old 05-28-2012, 07:17 AM
Pokes_WJ
Wj
Made custom plate under the bumper and mounted 4 Hella 500's on the front.
Pokes_WJ is offline
post #10939 of 45357 Old 05-28-2012, 12:18 PM
fosterjd79
Replaced my high pressure ps hose. What a PITA for something that looks so simple. Thanks Chrysler.
fosterjd79 is offline
post #10940 of 45357 Old 05-28-2012, 12:20 PM
Laidback
Replaced the Camshaft Position Sensor after it didn't want to start again.
Laidback
Laidback is offline
post #10941 of 45357 Old 05-28-2012, 01:06 PM
Sverdrup
Over the last week I painted all the plastic, skids, and the roof rack with black spray on bed liner.
Sverdrup is offline
post #10942 of 45357 Old 05-28-2012, 01:44 PM
snobrdrkid07
WJ for Life
Dropped 70 bucks into the gas tank today. woohoo. It is about 90 degrees here today and the AC was having a hard time keeping up. Granted I like it freezing cold. But, I may need to check the system and see if it needs recharged. Or have the dealer empty it and put new refrigerant in it.
-Michael-
post #10943 of 45357 Old 05-28-2012, 01:47 PM
peytonimor7
How can you tell if it needs recharging? My AC doesn't feel as cold as it should be, but it may just be so damn hot my brain thinks it's not working right lol. With dual climate control will it pull a code if it needs recharging?
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #10944 of 45357 Old 05-28-2012, 01:55 PM
snobrdrkid07
WJ for Life
It may be in my head too. But you can get those little recharge kits from wal-mart and autzone with a little gauge on it that tells you if it low or not. I am not 100% on how accurate those little things are. But, I have on in my garage and I will hook it up at somepoint and see if its low. And to answer your question, no I do not believe it would throw a code for low refrigerant. I do not know if it is freeon (spelling) or not. But I am pretty sure it is 134a is the type of stuff that goes in there.
-Michael-
post #10945 of 45357 Old 05-28-2012, 01:57 PM
narnwv
narnwv's Avatar
It won't throw an AZC code.
Your A/C will only produce air that's about 20-30 cooler than outside ambient temp, and that will vary with system component condition, as well as humidity, and air flow across the condenser. On my house's unit, I have a sprinkler setup to spray directly on the condenser outside, with the hose over running to a spigot near my door. I can turn the sprinkler on, and within a few minutes, the air from the house's vents is coming out a good 10 degrees cooler.
~Aaron
narnwv is offline
post #10946 of 45357 Old 05-28-2012, 02:04 PM
snobrdrkid07
WJ for Life
Okay, i didnt think it would throw a code.
You are right, it can only cool down the warm air so much. Thats why when you put the jeep on recirc it comes out cooler, right?
That is a nifty little trick, cool down the coils more to cool down the freeon. We have three large units on our house, haha. I may need another hose! But, they keep the house at 68 to 70 degrees w/o much problem
narnwv - whats the refrigerant called in our jeeps 134a? Is 134a a type of freeon?
-Michael-
post #10947 of 45357 Old 05-28-2012, 02:11 PM
narnwv
narnwv's Avatar
That's how the recycle button helps, but outside temp plays a bigger role.
R134a is what's used in our Jeeps. It's a refrigerant, but not freon.
https://en.wikipedia.org/wiki/Freon
https://en.wikipedia.org/wiki/1,1,1,2-Tetrafluoroethane
There are other products that have a lower boiling point than R134a, and cool way faster, but we'll not discuss those on here, as I'm unsure of the legality of using them in everyone's areas.
~Aaron
narnwv is offline
post #10948 of 45357 Old 05-28-2012, 02:22 PM
JRobes
picked up a new fishing 'yak and mounted her up and took her down a local river
2004 WJ Overland, 4.7HO, Quadradrive, 3" OME HD/Bilstein lift
1999 Honda Magna VF750C
JRobes is offline
post #10949 of 45357 Old 05-28-2012, 02:49 PM
rickcricket
Looks pretty similar to my Jackson Coosa. Hit some smallies? I caught this today.
rickcricket is offline
post #10950 of 45357 Old 05-28-2012, 03:28 PM
USMCBehrensDVLD
Out with the crap in with the new. New radiator after the last one blew out. surprisingly easy to do though.
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
wj
skennedy843
