What did you do to your WJ today? - Page 614 - JeepForum.com
 1086Likes
post #9196 of 45716 Old 03-15-2012, 05:36 AM
Dasko
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #9197 of 45716 Old 03-15-2012, 06:32 AM
speedyjeep
Originally Posted by li'l jeep View Post
just got the royal purple for the diffs and my e3 spark plugs. i need additive for the rear right?
i believe if you get the 75w/140 synthetic you dont need any additive for either diff
'00 Jeep Grand Cherokee Limited 4.7L V8 4x4,
-Shocks = Edelbrock 3321(Front)/34404(Rear)
-Direct fit high-flow magnaflow catalytic converter
speedyjeep is offline
post #9198 of 45716 Old 03-15-2012, 06:44 AM
little_Jeep
His profile says he has a 97 ZJ with the D44a.... is this correct? Is there a limited slip in the d44a, or is it open?
little_Jeep is offline
post #9199 of 45716 Old 03-15-2012, 06:56 AM
malibubts
Originally Posted by Dasko View Post
Took the front doors off on Tuesday so I could start my tube door project. You should see the looks on peoples faces. All I need now is a second set of speakers and I can take the backs off. Also picked up a set of 4 7" 24v led lights hehe my future is getting brighter..now just how to wire up those pesky things....
Are you going through the process in your build thread or another thread? I'd love to see what you end up doing on those tube doors.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #9200 of 45716 Old 03-15-2012, 07:14 AM
mrJ
2002 KJ Liberty
varilok has to have additive. period. or you can use redline that has it pre-added.
Build In Progress...
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #9201 of 45716 Old 03-15-2012, 07:36 AM
little_Jeep
This is my question.... does a 97 ZJ even have Vari loc? I wasn't even sure about the D44a .... did he pull this axle from a WJ, or is his profile wrong?
post #9202 of 45716 Old 03-15-2012, 07:42 AM
little_Jeep
I have a question, 2000 WJ (totally stock) with I6 and Quadra Drive system.. front driveshaft (cv joint at each end) was recently replaced... rear driveshaft, does it have normal u-joints that are replaceable?
I'm not where I can go look....
post #9203 of 45716 Old 03-15-2012, 07:44 AM
asatxj
asatxj's Avatar
Replaced driver's door latch assembly. No more geese in my Jeep!
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #9204 of 45716 Old 03-15-2012, 07:46 AM
rickcricket
Geese in jeep...finally a problem I don't have!
rickcricket is offline
post #9205 of 45716 Old 03-15-2012, 09:55 AM
iDrum85
Wj
New boots on the Jeep today. Firestone Destination A/T tires in the 245/70R16 variety. Not too shabby.
iDrum85 is offline
post #9206 of 45716 Old 03-15-2012, 10:05 AM
roadcrew
I think all rear ds were u joint.
roadcrew is offline
post #9207 of 45716 Old 03-15-2012, 11:29 AM
JerzeyBoyWJ
2003 WJ
when ever i see a stock wj ..it just looks more and more like a minivan ...they shoulda been higher outta the production line
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #9208 of 45716 Old 03-15-2012, 11:56 AM
Jakes04WJ
If you're gonna run a stock Wj atleast throw the largest size tire you can fit without having to trim too much
Jakes04WJ is offline
post #9209 of 45716 Old 03-15-2012, 01:18 PM
compcrasher86
Nahhh I'm pretty sure a 97 would have trac-lok
Matt
compcrasher86 is offline
post #9210 of 45716 Old 03-15-2012, 02:11 PM
mycreativename
You do realize that he is probably talking about the 2003 Limited WJ 4.7 he has listed in his signature, not the ZJ right?
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
wj
OldGreyV8
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
