What did you do to your WJ today? - Page 612 - JeepForum.com
 1086Likes
post #9166 of 45715 Old 03-13-2012, 06:02 PM
mckoolkid
X2 on where you got that trim. That looks good. Vacuumed and cleaned the interior today. Finally had a nice day and some time to do it.
mckoolkid is offline
post #9167 of 45715 Old 03-13-2012, 06:35 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by thisguyhasadd2 View Post
how would you score someone who could go up and over the rti ramp ha, just tell them they pass?
1500 when you max it out. Usually make you back up it after that.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #9168 of 45715 Old 03-13-2012, 06:57 PM
thisguyhasadd2
Worked on http://www.jeepforum.com/forum/f310/...build-1336339/
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #9169 of 45715 Old 03-13-2012, 07:03 PM
deathwobblez
2003 WJ
Originally Posted by JerzeyBoyWJ View Post
where did you get that trim?
Well, that's the trick. I had to make it, and I'm not so sure how it is going to work out in the long run. I wanted to get feedback on it before I said what it was, LOL.
**For Sale**2003 WJ Laredo 4.0 /JK Rubicon Wheels/4" Teraflex/MX6 Shocks/Flowmaster 40/Magnaflow Cat/OBX Header/Superchips Flashpaq**For Sale**
deathwobblez is offline
post #9170 of 45715 Old 03-13-2012, 07:08 PM
03overland03
2003 WJ
i still need to reassamble my jeeps engine. we've had nice weather recently, but i've had too much work and not enough time. always seems like i fix everyone else's vehicles before i fix mine
03overland03 is offline
post #9171 of 45715 Old 03-13-2012, 08:05 PM
mrJ
2002 KJ Liberty
Went and picked up the tc. Dude threw in what looks like a brand new driveshaft, and the one that is still connected to the tc, a pair of lca's, and shocks for 4.5" lift on an xj. Tried to take the yoke off...got 3 bolts off but the 4th is stripped. What should I do? Just cut the yoke?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #9172 of 45715 Old 03-13-2012, 08:25 PM
JerzeyBoyWJ
2003 WJ
cut in an X so you can get a Philips head on there
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #9173 of 45715 Old 03-13-2012, 08:26 PM
JerzeyBoyWJ
2003 WJ
I'm gonna guess its wood hah
post #9174 of 45715 Old 03-13-2012, 08:38 PM
mrJ
2002 KJ Liberty
not enough room. theres like 2 inches of space over the bolthead, maybe weld a nut on top of it and twist that off?
mrJ is offline
post #9175 of 45715 Old 03-13-2012, 08:40 PM
240impala
2003 WJ
Take a chisel and see if you can hit it around
"Don't Do It"
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #9176 of 45715 Old 03-13-2012, 11:20 PM
Cirruslydakota
Attempted to rebuild my alternator. Its the original factory installed unit which gave many years and miles of service but recently I developed a noise in the rear of it. Upon closer inspection after removing what was left of the brushes, a whole 1/8", I discovered the slip rings were worn out almost completely and the rear bearing was nearly trashed. So I already had all the parts with the exception of the new slip ring so I figured why not remove the rotor and replace the bearings? Nope, every single last screw holding everything together stripped out and I broke two snap on impact bits. So screw it, off to the rebuilder tomorrow along with my pride. I guess all the dirt, corrosion, heat, elements, etc just froze everything up. But I have to give it props, it still charged like a champ so maybe itll get a second life tomorrow. Lets see if the pros can do any better.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #9177 of 45715 Old 03-14-2012, 12:15 AM
compcrasher86
Took off the SS and death wobble ensued... badly... actually the play is in the pitman arm->drag link connection so it violently was steering left and right and not just toeing the tires in and out... so bad that I almost veered off the road into a ditch. WOW was my SS hiding something. Ordering new moog parts very soon.
Matt
compcrasher86 is offline
post #9178 of 45715 Old 03-14-2012, 01:41 AM
Relax_Jimmy24
went out and got some power steering fluid, transfer case fluid,
and antifreeze at the dealership.
they need to start giving people the right fluids.
first he wanted to give me ATF+4 for my power steering
then he wanted to give me ATF+4 for my transfercase
they wanna use ATF+4 for everything. grrr
Relax_Jimmy24 is offline
post #9179 of 45715 Old 03-14-2012, 06:43 AM
rickcricket
Exact thing went wrong with mine yesterday. I will also be swapping out with Moog.
rickcricket is offline
post #9180 of 45715 Old 03-14-2012, 11:45 AM
deathwobblez
2003 WJ
Not wood, but excellent guess. They make baseboards in a plastic material instead of wood (has a wood print finish though), and it was the only thing I could find that was exactly 2.5" wide, and about the right shape. I just don't know how this molded plastic will hold up to bumps and door dings and stuff. If I keep it on, I'll see if it can withstand the Phoenix summer.
The good thing is it's only $6 for an 8 foot piece, and only took an hour or so to cut with a dremel, prep and paint. Then another half hour to cut all the outdoor tape. It's still on after a whole day of driving, and didn't peel up at all.
wj
Loveland-WJ , Soem0
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
