What did you do to your WJ today? - Page 595 - JeepForum.com
 866Likes
post #8911 of 45178 Old 03-01-2012, 12:25 PM
USFORCES
Originally Posted by Trevino View Post
Whoa you have a seriously clean undercarriage. Wish mine were that clean...
Thanks, I've heard that a couple of times, I try not to drive it in the salt to much and if I do I wash it down really good no matter how cold it is and pull it in the garage then turn the heat up a little so it drys out fast, anyhow I like to drive in the fresh stuff before the city plow takes away all the fun
Also any time I see a hint of rust I break out the anti rust paint and kill it!
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #8912 of 45178 Old 03-01-2012, 12:27 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Good god that looks amazing. I keep the Rubicon looking exactly like that. But when I drive the WJ in mud/salt etc I always always hose it off quickly too keep it from rusting! You have a beautiful Overland!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #8913 of 45178 Old 03-01-2012, 12:39 PM
Trevino
Wow... Once again amazingly clean man. I'd hold my head up high and proud if I could get my jeep that clean. Your tempting me to get down there and start degreasing and painting.
On another note, how are you liking the green stuff pads? Been thinking about picking em up once my brakes are due.
Trevino is offline
post #8914 of 45178 Old 03-01-2012, 12:50 PM
Terminator2
Originally Posted by bostonryda112 View Post
ok so i'm putting new tires on my 2004 grand cherakee wj they are 35s 12.50 wide. i have some body work done to the front and rear bumper so they dont get in the way but the wheel wells are the stock specs. it has a 4 in. lift and the rims have a 4.25 offset away from the body. I need to know if i will run into any problems after putting these on if the even fit in there.
some one on here has to know right???
You are going to have to do a ton more cutting, grinding, and hammering to get 35x12.50s to fit especially if those are 10" wide wheels you have. You are going to have to cut your fenders and inner fenders like I have done to mine. I have only a 2" BB and need new isolators so I really have only 1.5" of lift over stock and 3.25-3.5" of metal cut off the whole front fender down through the bumper, removed fog lights and cut the bezels down 3" washer bottle delete. Rear is cut 2.25" all the way around. Those are just little 31x10.50s needs 33x10.50s or 33x12.50s with the amount of cutting I have.
Terminator2 is offline
post #8915 of 45178 Old 03-01-2012, 01:15 PM
USFORCES
I really like them they stop good, just read the reviews on them. Reason I got them was to help stop the bigger 33" tires a little, they are expensive though $575 for pads and rotors all the way around.
But I got the two for one deal!!
Get this I took it in right after I put them on to discount tire to have tire pressure sensors installed and the guy took the wire grinder to the studs that were brand new? It's discount tires standard procedure well it took some of the black zinc finish off the rotors, so I complained to the manager and called EBC, they said the black zinc is there so they don't rust.
Long story short, Discount tire bought me a complete extra set of EBC green pads and rotors.
USFORCES is offline
post #8916 of 45178 Old 03-01-2012, 01:37 PM
mrJ
2002 KJ Liberty
yeah. ebc greens and ultimax rotors. they'll stop the dub real quick-like. been runnin em for years. even covered in mud they've thrown the dog forward pretty good
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #8917 of 45178 Old 03-01-2012, 02:31 PM
Trevino
Good to know. I'm running the baer decela drilled and slitted rotors for about 2 years but can't find em anywhere anymore so I've gotta find something else. Think I'm gonna go with your setup.
Trevino is offline
post #8918 of 45178 Old 03-01-2012, 03:13 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Filled my windshield washer fluid reservoir
I get to go home over spring break, so the Jeeps going to get some special attention for her 100K birthday. Ordered: spark plugs, oil, oil filter, TPS, IAC, differential fluid, brake pads, windshield wipers, and fog light bulbs... Everything I could think of/afford. I might finally paint the cladding, too.
What happened to that flat black paint job you did yourself? Did you ever get it waxed or prettied up some?
In the garage: M1 4bbl
McCloudsZJ is offline
post #8919 of 45178 Old 03-01-2012, 03:25 PM
fuzzy88
Re installed my CAI with an Injen Hydrashield.
( Originally thought that the CAI had caused the CEL to come on but after locating and trying to clean the IAT I know that it needs to be replaced now.) This forums is GREAT!!
fuzzy88 is offline
post #8920 of 45178 Old 03-01-2012, 04:55 PM
dtrkyman
2013 WK
installed some stillen/dba front rotors, rears going on tomorrow.
dtrkyman is offline
post #8921 of 45178 Old 03-01-2012, 07:38 PM
robbins12
Drove it to school and got a shot before the snow started hard
robbins12 is offline
post #8922 of 45178 Old 03-01-2012, 08:05 PM
56BelAir
What did I do with my jeep today
I shopped for new shocks. Any suggestions?
Paul
Parker, CO
2001 Jeep Grand Cherokee Limited
Red
Spectacular sterosystem
Pretty cool roof rack
4.7 V8
56BelAir is offline
post #8923 of 45178 Old 03-01-2012, 08:20 PM
Cnolenwj
Asked bushwacker about wj fender flairs and the said they are working on them and would post pics soon. If interested post something in this Facebook post to let them know we want to see them. http://m.facebook.com/?_rdr#!/story....00000454207551
Thanks.
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #8924 of 45178 Old 03-01-2012, 10:34 PM
grey03wj
2003 WJ
Got a lil mud on the jeep.
grey03wj is offline
post #8925 of 45178 Old 03-01-2012, 10:36 PM
98_TJ_1941
your jeep looks just like my friends
Pretty Stock for right now
98_TJ_1941 is offline
wj
Cerbere
