03-01-2012, 06:16 AM
#8896
Originally Posted by wvracer821
just a replacement. never seen a high flow one. ive got a high flow cat on it down by the muffler though
yeah its the precats on the 4.0l this one came from rockauto.com
the exhaust looks much bigger than stock... is it?
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
03-01-2012, 07:43 AM
#8897
Washed it, and fixed the leaky fill plug on the rear diff cover with a little teflon tape.
04 Overland on 33's, Lift & tires= 8" over stock.
03-01-2012, 09:03 AM
#8898
Got my first oil change done, and had the tires rotated. Was also told my tc is leaking a little bit, most likely a seal. And there is a leak somewhere in my shocks, but I guess that doesn't matter because they are about to be replaced with the lift kit.
03-01-2012, 10:23 AM
#8899
Whoa you have a seriously clean undercarriage. Wish mine were that clean...
03-01-2012, 10:29 AM
#8900
thats ironic
you're in cali and he is in chicago
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
#8901
Replaced my teves up front with akebonos finally, so glad I got that over with. Also swapped in a new seat belt retainer so I don't close the door on my belt anymore...
03-01-2012, 10:32 AM
#8902
I was thinking the same thing, but I wasn't going to tell on myself.
03-01-2012, 10:43 AM
#8903
today is a good day !!
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 bfg all terrains
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
03-01-2012, 10:58 AM
#8904
putting big *** tires on
ok so i'm putting new tires on my 2004 grand cherakee wj they are 35s 12.50 wide. i have some body work done to the front and rear bumper so they dont get in the way but the wheel wells are the stock specs. it has a 4 in. lift and the rims have a 4.25 offset away from the body. I need to know if i will run into any problems after putting these on if the even fit in there.
some one on here has to know right???
#8905
I, Soldier.
Originally Posted by thisguyhasadd2
thats ironic
Nice catch!
03-01-2012, 11:00 AM
#8906
Your going to need to cut your fenders most likely, a lot...
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
http://www.jeepforum.com/forum/f197/mwyatts-wj-build-1180994/
"If you can't fix it with a hammer, then you have an electrical problem."
03-01-2012, 11:19 AM
#8907
I, Soldier.
I wanted larger tires so first swapped in 3.73 axles. Then I chose the best
tire size for gas mileage based the chart below and lifted to the lowest
height to accommodate those tires.
Check these charts out...
Tire Size vs Lift
Tire Size vs Gear Ratio
03-01-2012, 12:02 PM
#8908
Just ordered some quick discos from Kolak
"Don't Do It"
[url]http://www.jeepforum.com/forum/f22/wj-slow-but-getting-there-1153271/[/url]
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
03-01-2012, 12:03 PM
#8909
Mr. WJ
That chart is for a ZJ...
And this http://www.grimmjeeper.com/gears.html is an awesome site to calculate tire vs. gear ratio. This will give you actual results because you can input your transmission gear ratios.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 2.75" Lift | IRO Front Lower CA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors - Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 6000K Lows | SS Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Pure American Pride ~
~ Snobrdrkid's Build Thread ~ YouTube Channel ~ Fuelly ~ WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael
For Sale:
1. WJ Driver's Side Power Mirror
2. 242 Front Yoke, XJ
3. 242 Front Yoke, CV, WJ
03-01-2012, 12:11 PM
#8910
as far as I'm concerned shouldnt make a difference... ZJ and WJs both had 42res and both came with d35/d30 with 3.55s in basic form
01 WJ Ltd | i6 | QT2 | OME HD Lift | Bilstein 5100s | IRO Links | IRO A-Arm | Dueler AT RHS 255-70-18 (32") | JK Sahara rims | Moog HD steering | Upcountry Skids | Tow Package | KC Dayliters | Cobra 19 | Boston Acoustics Audio | Mopar subwoofer | RB1 | Lou's Catback | Stone White | Agate Interior
Build Thread
RIT Offroaders
Matt
