What did you do to your WJ today? - Page 584 - JeepForum.com
 827Likes
post #8746 of 45017 Old 02-22-2012, 06:36 PM
wvracer821
wvracer821's Avatar
Originally Posted by WJ2000 View Post
Hey Man did you buy , the main from the header with two cats, and it turns
around the Trany '' .
yeah and 4 O2 sensor bungs lol
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #8747 of 45017 Old 02-22-2012, 07:20 PM
JerzeyBoyWJ
2003 WJ
wash and waxed ..i hate road salt
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #8748 of 45017 Old 02-22-2012, 07:24 PM
thatoneguyaz
Nice rig Jerzey boy. How are you liking the 4 inch rough country lift, and is it the x series?
thatoneguyaz is offline
post #8749 of 45017 Old 02-22-2012, 07:37 PM
JerzeyBoyWJ
2003 WJ
thanks ..im actually upgrading to and IRO lift ..i dont have the x series but i have everything that comes with the x series minus the adj. control arms ...when i got my lift the x series wasnt even an option
if you really want the rough country i would upgrade to better control arms and order sway bar links for a 4 inch lift ...rough country just uses a block to extend you stock rear sway bar very unprofessional if you ask me ..ride quality is OK but your gonna need more parts to make it ride better
post #8750 of 45017 Old 02-22-2012, 08:56 PM
BLACK04WJ
I drove my wj to buy another wj!! the wife said she wanted one so she gets one.. its a 2004 Laredo with only 83000 and I have never seen a cleaner wj! right now it is at my brother in laws shop getting all the fluids changed and new brakes and tires so when it is done it will look like new!!! I'm actually kinda jealous of how clean it is.. oh well mine has the HO v8!!
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #8751 of 45017 Old 02-22-2012, 09:32 PM
thatoneguyaz
Damn yeah. I'm just not sure what to do. I'm kind of scared by the whole driveshaft thing. Having my Jeep go into 2wd mode when I'm out and about exploring sounds like a nightmare lol!
I'm trying to compare these two lifts and its a hypothetical at this point because I'm not sure I want to spend that much -ultimately I may be sticking with a 3 inch iro lift with jk discos and an adjustable trackbar.
http://www.xtremeterrain.com/35xfact...ckkrawler.aspx
vs
http://www.ironrockoffroad.com/Merch..._Code=IR-W4CPK
Sorry for the thread jack lolllz
post #8752 of 45017 Old 02-22-2012, 09:48 PM
JerzeyBoyWJ
2003 WJ
vs
id go with IRO ..very well known ran lift around here on JF ..and the drive shaft thing your just gonna have to deal with(its a WJ thing).. but once you get a new one your set and have no worries ..lifting a WJ is pricey and if you go the cheaper route your actually spending more money down the road on repairs/replacement parts ...thats just my viewpoint ..im sure alot of others have something different to say
post #8753 of 45017 Old 02-22-2012, 11:34 PM
USFORCES
Nice looking wj JerzeyBoyWJ, you ever get any slack having that wide of tires on the street?
If you can get the IRO adjustable a-arm along with the rear WJ 0-6.5" straight lower adjustable control arms so you can center your rear tires where you want them, just tell them to keep the $99.99 A-Arm Spacer Kit and use that money twards the adjustable a-arm
http://ironrockoffroad.com/Merchant2...egory_Code=PFW
http://www.ironrockoffroad.com/Merch...egory_Code=PFW
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #8754 of 45017 Old 02-23-2012, 08:46 AM
mrJ
2002 KJ Liberty
ordered new bushings and mounting hardware for rear sway links from IRO. Once those get here it's new coil isolators, KOR's shock mounting bolt sleeves, and the new bushings in the rear links.
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #8755 of 45017 Old 02-23-2012, 09:33 AM
thisguyhasadd2
driving to bk to get the mocha joe ( omg so freakin good) then extending my sway links with some steel stock from the shop in town, total cost will be $5.34 , thats including my drink from bk
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #8756 of 45017 Old 02-23-2012, 10:11 AM
somabva
finally broke down and took her into the shop today to get the passenger window fixed. Turns out it's a regulator, gonna run me about $150. Not as bad as it could be, I'm sure, but I miss the days when power windows just came off the track instead of breaking all that plastic crap
Guess I learned my lesson, don't try to roll the window down when it might be frozen shut with ice.
somabva is offline
post #8757 of 45017 Old 02-23-2012, 10:35 AM
thisguyhasadd2
^ i catch myself doing this all the time! I have replaced 3 of them, 150$ isn't to bad to fix it but i would really just learn to do it your self its not hard work by any means
post #8758 of 45017 Old 02-23-2012, 12:35 PM
GCDenver
Took the 2000 WJ 4.7 in to the shop to have outer tie rods replaced, still had the original tie rods, with the Moog brand, my mechanic said the Moog have Brass innards and are much better quality than the other brands. Also, finally took the advice of many others and had my green coolant flushed out and replaced with Zerex G-05 (mixed w/ distilled water) . Grand total of $300. Taking into Goodyear auto today to have an alignment. BTW, Goodyear takes competitor coupons so I took in a $58 Brakes Plus alignment coupon and they match the $.
GCDenver is offline
post #8759 of 45017 Old 02-23-2012, 01:06 PM
crabass28
swapped in a 242 transfer case, replaced both wheel hubs, new axel shafts, brakes al the way around...well that was last week.
this week i mounted 4 lights on the croos bar and ran the wires, replaced the blower motor and tonight im gonna do the internal wires and switches for the lights.
hopefuly next weekend i start fabing up a new front bumper.
crabass28 is offline
post #8760 of 45017 Old 02-23-2012, 02:29 PM
adavis39
UTwj
Lifted it....finally
adavis39 is offline
wj
alferro
