What did you do to your WJ today? - Page 566 - JeepForum.com
 826Likes
post #8476 of 45006 Old 02-15-2012, 09:42 AM
4x2WJ
Originally Posted by BLACK04WJ
I have 6000k and if I went any higher they would be blue.. but I guess some different companies might be different.
They are made by xenon. They have a blue tint to them but their classified as iceberg blue. My friend has 6000k on his wrangler and my old jeeps 8000k were way brighter and looked about the same just a small trace of blue
4x2WJ is offline
post #8477 of 45006 Old 02-15-2012, 09:54 AM
compcrasher86
6000k is brighter than 8000k. 4300k is brighter than 6000k. 4300 is the sweet spot but doesn't have that flashy luxury car HID hey look at me look. Priorities
Matt
compcrasher86 is offline
post #8478 of 45006 Old 02-15-2012, 12:20 PM
maloj2003wj
2006 WK
Where do you get this information? Can you link us to some rype of a spreadsheet or a cmparison table. Thx
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #8479 of 45006 Old 02-15-2012, 12:35 PM
Dusk53
Mah build
East Carolina University
Dusk53 is offline
post #8480 of 45006 Old 02-15-2012, 12:47 PM
maloj2003wj
2006 WK
Originally Posted by Dusk53
Thx
post #8481 of 45006 Old 02-15-2012, 12:51 PM
IRFilter
added new tail lights today....i like them. They are much brighter, and the OEM tail lights are a little plain. Was considering blacking OEM out, but decided to upgrade. very happy. let me know what you guys think
IRFilter is offline
post #8482 of 45006 Old 02-15-2012, 01:44 PM
Jaredride
Originally Posted by imaguy3 View Post
were you trying to loosen the nut or the bolt. If I remember right from doing mine, the nut is tackwelded, so if you hold the nut and loosen the bolt like I did no problems
Yeah... I held both... it's the only way to get it off, otherwise it would just spin.. my problem was the not was rusted pretty good, and the bolt had been bent a little... She sure feels great now with the new SS though!!!
02 WJ 4.7L HO w/ Mods
Jaredride is offline
post #8483 of 45006 Old 02-15-2012, 02:05 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Those are awesome! Need pictures at night!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #8484 of 45006 Old 02-15-2012, 02:31 PM
thisguyhasadd2
Well the death wobble has to end before 2-24-12. pops is coming to go on a ski trip and is taking the wj. 4" stock arms and dw go figure. Ball joints, tie rods ends, ss are all good. some play in the tb bushings and need to check the control arm bushings. Going to get this solved in the week. Also tomorrow ill be lengthening the front sway bar links.
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #8485 of 45006 Old 02-15-2012, 02:42 PM
JerzeyBoyWJ
2003 WJ
video ..even better
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #8486 of 45006 Old 02-15-2012, 05:43 PM
amremt408
Why not lose some lift? I'm assuming you have spacers of some kind... Isn't 4" on stock arms kinda pushing it? And my money is on the track bar bushings, I thought there wasn't supposed to be ANY, even the slightest there...
5.9 ZJ... 4.5" Rubicon Express short arms. Bridgetone REVO 2's... 265/75/16.
2004 WJ... OME HD coils, Bilsteins shocks, JKS adj track bar, MOOG SS, ADDCO rear sway bar with ext., Bridgestone REVO 265/70/17.
amremt408 is offline
post #8487 of 45006 Old 02-15-2012, 05:47 PM
thisguyhasadd2
Can't loose lift, i have coils. I found some wallowed out holes, 1/2" bolts fit perfectly. Although i can't decide if i should weld on a washer and keep original bolts, or drill out the bushing sleeves on my jks tb. Any opinions?
post #8488 of 45006 Old 02-15-2012, 05:49 PM
amremt408
I would not drill out the bushings unless you plan on getting new ones... I would lube and press the bolts through before I did that. I just feel like you'd still have play if you files them out...
post #8489 of 45006 Old 02-15-2012, 05:52 PM
thisguyhasadd2
just the metal sleeve
post #8490 of 45006 Old 02-15-2012, 05:58 PM
amremt408
Idk, that metal sleeve isn't very wide from what I recall. seems like it'd hard to drill out perfectly, but if you have the means. if you take the sleeve out, maybe you can find a bolt that fits perfectly at the hardware store... Is the sleeve worn? Or is the original bolt worn? Which is causing the play? That's the one you should replace IMO, or both... Should be pretty cheap, and you could move on to check other parts
wj
