What did you do to your WJ today? - Page 549 - JeepForum.com
 998Likes
post #8221 of 45537 Old 02-04-2012, 02:55 PM
joze
Had 2 minutes of snow fun with mine today on a parking lot
BTW, anyone else noticed that the engine starts up a lot smoother if you press the gas pedal once (about halfway) before you start it up (w/o key in ingition and not touching gas pedal while starting up)?
Originally Posted by Ljohn221 View Post
You can't start a new civilization without jeeps
Originally Posted by dukie564 View Post
Epic boobs saving threads since 1978
joze is offline
post #8222 of 45537 Old 02-04-2012, 03:13 PM
compcrasher86
I'll go try that out but in theory if your IAC and everything else is in good shape it shouldnt make a difference. Also when I start my Jeep I turn it to on and give it 3-5 seconds before cranking I guess in theory if you jump right to start and the IAC doesnt have enough time to move around it could act up
Matt
compcrasher86 is offline
post #8223 of 45537 Old 02-04-2012, 03:32 PM
joze
Well, TPS is about 6 months old, but I only cleaned the IAC when I changed the TPS. Maybe it's time to get a new IAC. I'm also planning on doing spark plugs & fuel filter some time in the spring.
Oh, and I generally wait about 3 seconds before cranking it. It's a habit from diesels I owned before (had to wait even longer in the winter so the glow plugs would heat up and even then I had enormous trouble starting up in the morning).
joze is offline
post #8224 of 45537 Old 02-04-2012, 03:59 PM
jtcnj
I waited the couple seconds between run and start for the ecu to wake up like always, I then backed it into my mailbox.
Bent the fuel door a little, scratched a little paint but no dents and looks like mainly just grey paint from the mailbox.
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #8225 of 45537 Old 02-04-2012, 04:57 PM
asatxj
asatxj's Avatar
Washed it and the WK,
Pulled instrument cluster and replaced burned out bulbs.
Removed driver's seat and added foam so my posterior doesn't ride on the seat frame
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #8226 of 45537 Old 02-04-2012, 05:16 PM
rboots
Really I've been workin on this for a couple days but finally finished it up. Finally secured homemade roof rack, with 4 100watt HF lights up front and 2 55watt HF lights in the back, And installed a factory hitch that I got off craigslist for $20. Didn't wanna spend the money on the bezel so I went the cheap trim route. Next weekend will be 2" BB, new tires, brakes, cv shafts, and hopefully test it all out.
2012-01-23_17-42-06_234.jpg   2012-01-30_22-09-50_492.jpg   2012-01-30_22-29-32_906.jpg   photo 3(1).JPG   photo 5.JPG
rboots is offline
post #8227 of 45537 Old 02-04-2012, 05:42 PM
compcrasher86
WOW! How did I not think of doing that cheap trim thing when I did my hitch. Looks good man!
Matt
post #8228 of 45537 Old 02-04-2012, 06:37 PM
Cnolenwj
Installed my coil spring retainers some swaybar straps for when I disco and a few other things.
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #8229 of 45537 Old 02-04-2012, 09:57 PM
mrJ
2002 KJ Liberty
Nice swaybar dealie. Can I get more pics? I need to do the same. I was just thinking self tappers and bungee tho. What'd you use? Wire?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #8230 of 45537 Old 02-04-2012, 11:07 PM
Timbo24
Originally Posted by TheBoss
Found the source of a "clunk" in the rear. It turned out the lower shock bolt was worn from a previous shock sleeve rubbing it. Replaced it with new 8.8 bolts left and right. the Jk shocks ride smooth and noise free now.
<img src="http://www.jeepforum.com/forum/attachment.php?attachmentid=340718"/>
What size lift do you run with jk shocks?
Timbo24 is offline
post #8231 of 45537 Old 02-04-2012, 11:10 PM
Timbo24
My Wjs driveshaft decided to break while I was driving 55 mph. It also thought that it would destroy my transfer case to. This sucks. I am going to need a new driveshaft and transfer case.
Timbo24 is offline
post #8232 of 45537 Old 02-05-2012, 12:01 AM
compcrasher86
Great excuse for a 242 swap!
Today I took my Jeep for a short drive, played around with the kickdown cable some more, still isnt exactly where I want it but better.
Matt
post #8233 of 45537 Old 02-05-2012, 12:47 AM
MWyatt
took it offroad. dropped a front coil and snapped my tie rod.
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #8234 of 45537 Old 02-05-2012, 12:51 AM
BLACK04WJ
drive mine a couple hours to sell my bike. it was the first time pulling anything since I put the new lift on and I had to run to the store and buy a drop down bracket for my hitch to make the trailer level.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #8235 of 45537 Old 02-05-2012, 12:59 AM
USFORCES
Sold the bike
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
