What did you do to your WJ today? - Page 535 - JeepForum.com
 865Likes
post #8011 of 45173 Old 01-28-2012, 05:42 PM
joze
I've decided that while I'll be changing out the low beam light, I'll also tap into the high beam wiring to pick up the + just for the signal to the relay so I'm ready to put on extra lights when I get them.
Does anybody know what's the best way to get a couple of wires from engine bay to dash? I'll be fitting a switch for the extra lights.
Originally Posted by Ljohn221 View Post
You can't start a new civilization without jeeps
Originally Posted by dukie564 View Post
Epic boobs saving threads since 1978
joze is offline
post #8012 of 45173 Old 01-28-2012, 06:02 PM
4x4Jeep
i've been out wheeling since thursday...no damage (scratches don't count), pull into a gas station on my way home, and ran over a nail. now i have a flat and i think my spare has a small leak. see what the pavement does.
Build -
SOLD
4x4Jeep is offline
post #8013 of 45173 Old 01-28-2012, 06:07 PM
mrJ
2002 KJ Liberty
Went and checked out the offroad park. More pics in build
ForumRunner_20120128_200620.jpg   ForumRunner_20120128_200644.jpg   ForumRunner_20120128_200703.jpg
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #8014 of 45173 Old 01-28-2012, 06:29 PM
EisBlade
EisBlade's Avatar
I'm closer to ditching the 30's on factory rims for 32's on JK's. Today I noticed leaks so bought rear axle seals and bearings and on Monday will finish the suspension tweaks and install the adj. rear CA's.
JT
Harley-Davidson Touring Bikes (60K members strong)
EisBlade is offline
post #8015 of 45173 Old 01-28-2012, 06:33 PM
USMCBehrensDVLD
Went to Rausch Creek Off Road Park today.
2004 Jeep Grand Cherokee WJ
2008 Toyota FJ Cruiser
2003 Dodge Dakota- Bone Stock
USMCBehrensDVLD is offline
post #8016 of 45173 Old 01-28-2012, 09:39 PM
Cowboyup94
Finally checked my odd rumbling noise that I get. Figure U joint, wheel bearing, balljoint, engine mount or bushing. After check all of them i took the front diff cover off. the ring pinion and spider gears looked great. No play at all. But while spinning the wheels to check the gears i noticed something odd with the drive shaft. after further inspection it actually was the U joint But atleast I now know every things good on the jeep. And i actually had luckily my uncle had the right one. so now i have a new U joint and changed diff fluid! Total Win!
Cowboyup94 is offline
post #8017 of 45173 Old 01-28-2012, 09:45 PM
Cowboyup94
O I also changed my low beam bulbs since one died. Got some BA sylvanias. was worth all 34 doll hairs!
post #8018 of 45173 Old 01-28-2012, 09:48 PM
03overland03
2003 WJ
placed a bid on a wrecked overland to pull the engine out of since i'm sure my heads are warped and a few users here and further research says that these heads shouldn't be resurfaced.
03overland03 is offline
post #8019 of 45173 Old 01-28-2012, 10:30 PM
gtg413i
2003 WJ
I just did that, but I measured the JK's at 31". They do have wear, but let me know what diamater yours come up with if you get new.
Brian's Black Betty Build:
gtg413i is offline
post #8020 of 45173 Old 01-29-2012, 07:26 AM
mudtrackerinc
mudtrackerinc's Avatar
Bought mine some new rubbers
02WJ Rough Country 4" Long Arm,3/4 spacers added to front,265x70x17C BFG All-Terrain T/A KO 31.8x10.7,super 44 flowmaster,K&N air filter,JKS adj track bar,JKS HD tie rod,JKS HD draglink,RCX dual stabilzer,Mickey Thompson Sidebiter wheels 17x9 4.5"BS,Saguaro4x D-Ring Mounts
06tj RC 4" X-series ,RC Dual Steering Stabilizer, 32x11.50x15 BFG All-Terrain T/A KO, 15x8 Ultra Motorsports Rogue
Model:175 Wheels, K&N CAI & Filter,super 44 flowmaster
mudtrackerinc is offline
post #8021 of 45173 Old 01-29-2012, 10:23 AM
joze
Swapped tires front to back and vice versa on mine. I can't rotate them, because they must turn in a certain direction... anyway, I've had some problems with sharp turns (left or right), it felt like jeep was in 4wd. After some research and measurements, I found that my front tires are wearing out much faster than rear, causing different diameters and that's why VC was engaging on sharp turns. Feels much better now, I'll see tomorrow when I'll have another 100 mile trip.
joze is offline
post #8022 of 45173 Old 01-29-2012, 10:31 AM
joze
And I just remembered that it's 1 year and 3 days since I own the jeep
joze is offline
post #8023 of 45173 Old 01-29-2012, 11:17 AM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
It has been 7 years and 229 days since I have owned my Jeep! Bought her Brand New in middle/late 04
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #8024 of 45173 Old 01-29-2012, 11:45 AM
CantFocus
2003 WJ
So you bought your jeep when you were 10-11?
Zombie Outbreak Response Unit #338
2003 WJ Laredo 4.7 Loaded including Upcountry Package - 2" BB - Rola rack - V3 Black Projectors - 55W 5000k HIDs - Yellow 9005 fogs - JKS Discos.... More to come
CantFocus is offline
post #8025 of 45173 Old 01-29-2012, 11:52 AM
little_Jeep
Check your front driveshaft... if you have the shaft with CV style joints, not u-joints, this maybe your problem, not your TC. When these joints fail, they slip causing you to lose your front wheel drive... People say these joints will make noise, but mine didn't make a peep until they were so bad they were ready to explode.
little_Jeep is offline
wj
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
GhostJeepWJ , Kxf327 , Ravenbar , Soem0
