What did you do to your WJ today? - Page 531 - JeepForum.com
 605Likes
post #7951 of 43896 Old 01-25-2012, 09:27 PM
compcrasher86
Originally Posted by AustinTexasXJ
Changed my fuel filter the other day, freaking pain in the ***
Lemme guess, quick connectors weren't so "quick"
On topic, got my bilsteins in!
Matt
compcrasher86 is offline
post #7952 of 43896 Old 01-25-2012, 10:39 PM
liquidxit2
Drove my newborn baby boy home in it for the first time! As soon as he got in no fuss almost as if he remembered all the rides in it.
it aint that bad.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #7953 of 43896 Old 01-25-2012, 11:13 PM
compcrasher86
Originally Posted by 206wj View Post
It's a Custom Drop down that myself and a local shop (Perkins Performance) designed (Mostly him) and made.
We used the base that he had, and made it a bit different. http://www.perkinsperformance.com/ph...3-a6fc40ada4e0
I really like the bumper design, but the swing down looks like it would be a royal pain in the butt to lift back up, especially with a heavy tire
Matt
post #7954 of 43896 Old 01-26-2012, 12:39 AM
lestatsghost
installed a trailer hitch today on mine, don't like how low it is but it will get the job done.
lestatsghost is offline
post #7955 of 43896 Old 01-26-2012, 12:41 AM
compcrasher86
Its an aftermarket one isnt it? I dont like those either, the factory one where it sits up in the bumper is where its at.
Matt
post #7956 of 43896 Old 01-26-2012, 12:59 AM
thestig_wj
this was awhile ago but i just came across the pic....i had a squeaking noise coming from the rear any guesses as to what it was
old.............................new
thestig_wj is offline
post #7957 of 43896 Old 01-26-2012, 01:13 AM
dizzle247
I'm new here but I will play.
Installed adj trackbar, and license plate on rear bumper... It was on with double side tape!
Heres a pic so it makes sense.
I think i've seen you around the kirkland/bellevue areas .. iirc, I pulled up next to you and started yelling at you to turn to channel 5 on the CB through my PA system, but I don't think you heard me lol.
dizzle247 is offline
post #7958 of 43896 Old 01-26-2012, 06:20 AM
Dasko
Originally Posted by pinky2252s
Yeah, I was thinking of peeling my plastic crap off and then painting them.
Is there a particular type of paint you should use? Like one made better for plastic?
On another note gonna sit down with my machinest today and start working on one of my four projects. 1. Swing out tire carrier.
2. Recessed winch plate.
3. Roof rack
4. Rock rails. (He wants to use me as a guinie pig)
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #7959 of 43896 Old 01-26-2012, 06:30 AM
Collin89Sahara
3. Roof rack
I used Rustoleum Satin Black, looks greats and easy application on any surface.
Collin89Sahara is offline
post #7960 of 43896 Old 01-26-2012, 09:12 AM
03overland03
2003 WJ
called and got prices for resurfacing and valve job on the heads for my jeep. best price from a shop i've dealt with before is $285 for both including pressure testing and cleaning. not a bad deal.
other than that, jeep is still untouched though. i'm considering a 3" lift after the head gasket replacement is finished
03overland03 is offline
post #7961 of 43896 Old 01-26-2012, 10:10 AM
Chris00WJ
Finally got my Rusty's Offroad A-arm from UPS after a bit of a fight with them. It all worked out in the end tho.
This thing is pure BEEF! Im very very very impressed with the quality of workmanship and parts used. I was going to try to wait until sunday to install it because the weather is supposed to be 10 degrees warmer, but I might suck it up and dive into it today.
Chris00WJ is offline
post #7962 of 43896 Old 01-26-2012, 11:22 AM
pinky2252s
3. Roof rack
I'm most likely going to use plasti dip
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #7963 of 43896 Old 01-26-2012, 11:31 AM
206wj
I am in the bell/kirk area a lot. Used to work there. Sorry, wasn't ignoring, just probably in my music zone.
Back OT: I ordeded the ends to finnish building the front LA's.
206wj is offline
post #7964 of 43896 Old 01-26-2012, 11:34 AM
206wj
Thanks! It's not that bad to lift. It was designed to add some 100lb gas struts to aid in the lifting, but I didn't end up using them. Just isn't bad to lift at all.
206wj is offline
post #7965 of 43896 Old 01-26-2012, 12:22 PM
Terminator2
Good workout. Just have to use some man strength. On a pivot arm like that I could lift a 200 lb wheel and tire without too much trouble.
Terminator2 is offline
steve_80
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
