What did you do to your WJ today? - Page 502 - JeepForum.com
 1000Likes
post #7516 of 45539 Old 01-09-2012, 07:26 AM
Rubes
Finally got around to determining why the brakes felt spongy after new rotors and pads. Took a while, but I managed to remove the pins.
Rubes is offline
post #7517 of 45539 Old 01-09-2012, 07:38 AM
TheBoss
PM'd Kolak and ordered my cat back exhaust.
TheBoss is offline
post #7518 of 45539 Old 01-09-2012, 07:45 AM
Terminator2
Originally Posted by little_Jeep View Post
Take pics of the entire process, then post link to album.
Ok will do.
Terminator2 is offline
post #7519 of 45539 Old 01-09-2012, 07:47 AM
little_Jeep
Anytime I pull my brakes apart, I put a thin coat of brake grease on these pins.
little_Jeep is offline
post #7520 of 45539 Old 01-09-2012, 08:18 AM
Rubes
When I initially gave it a brake job last year (the first since buying the WJ in 2009), I couldn't remove the pins with the 7mm (or 9mm, not sure) hex socket -- they were stripped round. No heat or vice grips could remove it. Finally got fed up with the spongyness and banged away at the sliding piece of the caliper (not sure the name of the part) and it slid off allowing me to remove the pins with a pipe wrench. Replaced the rubber boots as well.
Rubes is offline
post #7521 of 45539 Old 01-09-2012, 10:06 AM
9toewj
Ordered new half shafts for the front 30... CV's making popcorn in there right now...
9toewj is offline
post #7522 of 45539 Old 01-09-2012, 11:09 AM
wj4play
Originally Posted by thisguyhasadd2 View Post
Quad mod! for just under twenty bucks.
1 pack of 1157 bulbs
2 twist lock sockets autozone (#85822)
NICE
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #7523 of 45539 Old 01-09-2012, 11:18 AM
little_Jeep
If you have CV joints, you can't order half shafts because the CV joint is non serviceable... you just replace the entire axle shaft, CV joint and all.
post #7524 of 45539 Old 01-09-2012, 11:57 AM
mrJ
2002 KJ Liberty
Parked next to brother in-law's tj. I think its a couple inch body, couple inch suspension, and 35" kevlars
Also cut off my shock and ss boots...quite a build up of crap underneath
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #7525 of 45539 Old 01-09-2012, 12:02 PM
Holland18
New headlights came in and installed within 15 minutes of hittng the doorstep.
A couple before and after pics.
Holland18 is offline
post #7526 of 45539 Old 01-09-2012, 12:38 PM
Texas_Heat
Originally Posted by mtnmarc View Post
a steering stabilizer will not cure death wobble. this is a known fact beaten with a piece of wood. over. and over. and over. and over.
it just masks it. something else is causing the death wobble.
Could of fooled me, it sure did fix the issue.
2000 WJ.6 inch lift Rough Country 4" Lift, BB 2" lift, Pro Comp Steering Stabilizer, Rough Country Adjustable Trackbar, Rough Country Swaybar Quick Disconnects, Spidertrax 1.25 Wheelspacers, 265/75R16 AT's, K&N Filter
Soon to come: 35's, Longarms, Lockers and Gears
Texas_Heat is offline
post #7527 of 45539 Old 01-09-2012, 12:56 PM
Terminator2
What he meant was even without a stabilizer you should not have death wobble if there is no issues with the suspension components, geometry, alignment, etc. If the case of death wobble is mild however a steering stabilizer will cure the issue but it is kinda a band-aid so to speak.
post #7528 of 45539 Old 01-09-2012, 01:08 PM
liquidxit2
Yeah its a pretty easy process and sadly the drivers side is always the faded one. Oh well best $75 I spent on cosmetics for the WJ.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #7529 of 45539 Old 01-09-2012, 01:24 PM
bgohsman
I spent $2,700 at the stealership replacing virtually everything in the rear end except for the wheel hubs themselves. Swaybars, linkages, half-shaft...the list just went on and on. So that's the bad news.
The good news is that it doesn't make a sound now when going down the road and is a WHOLE lot more stable turning corners. lol
But, seriously...ouchies.
Brandon Gohsman
bgohsman is offline
post #7530 of 45539 Old 01-09-2012, 01:30 PM
liquidxit2
Drovbe it to work with the soothing sounds of a 4.7l for my listening pleasure.
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
