What did you do to your WJ today? - Page 496 - JeepForum.com
 866Likes
post #7426 of 45178 Old 01-05-2012, 11:24 AM
Terminator2
Replaced my PCV valve today. NAPA had one in stock and it was $6 and made in the USA so I thought that was a good deal. Changing it was easy except those AC lines that run right there and the fact my engine was super hot still LOL. Old PCV was original and had some sludge built up inside of it but seemed to still work properly. I like the piece of mind of changing things before they actually fail.
Next up: My new hood goes on, prep for paint, evil looking flat black paint job by me and then the new headlights, taillights, 3rd brake light to complete the sinister look.
Hopefully I will get new mirrors for my birthday (January 19th) as my passenger one cracked where it sits against the A-pillar and my driver's motor works only up and down not in and out LOL.
Before summer I am going to flush the coolant system one more time (2nd time because lots of sludge buildup from 10 year old coolant that was in there when I bought it) and I think I will replace my upper and lower radiator hoses and clamps while I am at it.
Terminator2 is offline
post #7427 of 45178 Old 01-05-2012, 11:24 AM
liquidxit2
Be thankful yall dont have the hydro fan. While everyone says they cool much better I hate that SOB.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #7428 of 45178 Old 01-05-2012, 12:22 PM
Terminator2
Originally Posted by theskier74 View Post
yesterday: i changed the oil. couldnt convince myself to switch to synthetic so i stayed with conv. i put in castrol gtx 5w-30 for the winter...but when i drained my old oil, barely any came out. maybe 1/4 or so of a normal oil change
Wow you don't check your oil level from time to time? I check mine at least once a month sometimes once every 2 weeks. Unless you have a external leak where there is dripping oil under your rig you likely have an internal leak (possible blow by the oil ring on the pistons. You lost 4-4.5 quarts or so which is a lot of oil.
post #7429 of 45178 Old 01-05-2012, 01:04 PM
cbailey_21
Originally Posted by little_Jeep
(LOL).... I have done simple little repairs like this.. (LOL). They seem to grow larger and larger as I work I have the 4.0L with the Up Country skid on the front and have been told, that anytime I have access to that lower radiator hose, I need to replace it because it is a bear to get to.. (not something that can be done on the side of the highway).... Like I said, I haven't personally messed with this, but no repair is simple, quick, or easy on a WJ, so I'll assume what I was told is correct.
That hose was absolutely horrible. It took an air ratchet, 20 minutes and a lot of cussing just to get the freaking skid plate off
Originally Posted by smuggler View Post
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #7430 of 45178 Old 01-05-2012, 01:26 PM
little_Jeep
I don't wheel my WJ..... I have thought about just removing this skid plate and never putting it back on. So far, it is just a thought, I haven't actually gotten motivated to actually remove it.
little_Jeep is offline
post #7431 of 45178 Old 01-05-2012, 01:37 PM
Terminator2
That skid plate is pointless for 99% of all WJ owners. The radiator support beam in front will normally take the hit.
post #7432 of 45178 Old 01-05-2012, 01:44 PM
little_Jeep
Kind of what I was thinking.....
Once the skid is off.... is the lower radiator hose a fairly simple change? Something that could be done on the side of an x-way, or better yet, just changed as a preventative type of thing?
post #7433 of 45178 Old 01-05-2012, 02:09 PM
4x4Jeep
Talking
got my CB in the mail today. just waiting on the antenna and mount.
Build -
SOLD
4x4Jeep is offline
post #7434 of 45178 Old 01-05-2012, 03:24 PM
KDF401
Got the jeep finally registered..now the fun begins
KDF401 is offline
post #7435 of 45178 Old 01-05-2012, 03:25 PM
straty1987
if you want to sell it pm me
straty1987 is offline
post #7436 of 45178 Old 01-05-2012, 03:49 PM
85IrocZ-28
I just ordered the following from Kolak:
-8 coil spring isolators (all four corners, top and bottom)
-5 brake hoses (all four corners, and the rear body to axle)
-1 brake booster
My isolators are worn/tearing/shredding and need to be replaced. I while I am at it, I plan on refreshing the brake fluid and thought I would toss in new lines as these ones have been on the vehicle for many years. Preventative maintenance is important if I am going to keep beating this thing offroad. I would hate for a line to fail while I am back in a trail somewhere. The brake booster is squeeking and needs to be replaced...I like stopping and would hate it if it failed in a critical moment.
Kolak responded very quick to multiple questions, so far this has been a great transaction. Now I know why people on here like ordering from him.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #7437 of 45178 Old 01-05-2012, 05:02 PM
little_Jeep
I don't have a reason to remove it at the moment.... if you want to send me a PM with your phone number, I'll put it in a safe place and when I do remove the skid, I'll call and see if you are still interested. However, I suspect this sucker would cost a pretty penny to ship.
post #7438 of 45178 Old 01-05-2012, 05:02 PM
Trevino
I've only had problems removing the skid the first time I had to do it. After that its only two bolts that actually have to be removed. The other two only have to be unthreaded a bit to give room to wiggle the skid free. I've done it on the trail to remove a stuck t stat. Just remove it one day at home to see what's involved and decide on keeping it or not. I keep mines on as it does have a dent. Don't know when I got the dent, but it wasn't there when I bought the jeep so I know I did it. I tend to bang up parts most people don't like my tranny pan.
Trevino is offline
post #7439 of 45178 Old 01-05-2012, 05:06 PM
little_Jeep
My transmission pan looks like it has lost a few battles... even through I have all the skids included in the Up Country package...
post #7440 of 45178 Old 01-05-2012, 06:31 PM
thisguyhasadd2
the last roommate finally left and i get some peace and quiet at home for about a week, it garbage day too. Cant wait to throw out bunch o crap to give my self some space to work in the garage.
Bot, im going to start collecting things i will want/need for a camp box i also want to build.
also today i cleaned my leather and suede, for the leather i found some saddle leather conditioner cleaner and for the fake suede i used a razor blade, new toothbrush, and some water and dawn in a shot glass. Got rid of some of the dingle-berries my seats had lol
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
wj
