What did you do to your WJ today? - Page 495 - JeepForum.com
 559Likes
post #7411 of 43595 Old 01-04-2012, 01:02 PM
little_Jeep
Originally Posted by theskier74 View Post
thats the problem...why so little came out. not before oil change, but after yes. it was a little below "full"...i put 5.28 i...which is know is .32 less than actually full but it should not make that much of a difference...am i just burning my oil in the winter or is it building up? should i now be worried about sludge or where all my oil is going?
Could be any of the above.... you won't know without checking your oil on a regular basis. Even if it has never used oil before, doesn't mean it isn't using it now. Also, watch for any drips on the driveway, etc. Always check your oil level before you change it, and always get oil as hot as possible... hot oil brings sludge out with it, cold oil does not.
little_Jeep is offline
post #7412 of 43595 Old 01-04-2012, 01:06 PM
little_Jeep
The fact that you put 5.28 quarts in it and it was a "Little below full" would lead me to believe that whatever oil was in the crankcase came out. The real question is "how much oil came out"? Was it actually only 1/4 the normal amount, or did it just look that way? We won't know the answer to this question without frequent oil level checks.
post #7413 of 43595 Old 01-04-2012, 01:11 PM
theskier74
thanks guys! and it was about that...it was a 5 gallon bucket and it was probably only 2 inches deep...maybe 1.5 inches deep. i dont know what that comes out to but there wasnt a lot. less than usual thats for sure. the oil was hot when i changed it...when should i next check my dipstick? about halfway to next oil change? and if a little low throw in like a quart or so
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #7414 of 43595 Old 01-04-2012, 01:12 PM
pyrrhus00
Put 3000 miles on her in the past week going alabama-ohio-alabama-texas-alabama, and the texas bit of that with 4 adults, an 8 month old puppy, and entirely too much junk in the vehicle!
Turns out doing plugs/fluids helps the fuel economy - averaged 19.4 mpg for the whole trip.
2004 WJ Overland
pyrrhus00 is offline
post #7415 of 43595 Old 01-04-2012, 01:26 PM
little_Jeep
Until you figure out what is going on, I would check the oil at least once a week. If there seems to rapid loss of oil, you might have to step this up to a couple times a week or even daily. Checking fluid level is free.... engines are not.
When oil is at the "ADD" mark, it is one quart low. You don't want to run the engine more than a quart low, but you also do NOT want to over fill it. Over filling can do as much damage as running engine low on oil. If in doubt about how much to add, add less than you think it needs, run engine, then after a few minutes check oil level again. As I stated in my other post, I think you **probably** have (assuming your estimate of the amount of oil that came out is correct) an oil loss issue, not a sludge issue.. the question is, do you have a leak, or is the engine burning oil. If burning oil, how much, and in how many miles? BTW, I forgot to tell you, keep a log of your oil level checks, date, miles, and approximate oil level. I assume you know to let motor sit for about two minutes after shutting it off, and be on level ground before checking oil levels.
post #7416 of 43595 Old 01-04-2012, 03:14 PM
mrJ
2002 KJ Liberty
Changed oil pressure switch. Hardest part was getting the retainer clip off the wire plug. Sumbish was dirty
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #7417 of 43595 Old 01-04-2012, 04:45 PM
theskier74
i will do all this...thanks a ton man!
200k+
post #7418 of 43595 Old 01-04-2012, 07:53 PM
pincheburro956
changed out the rear shock bushings. Now my rear end doesnt make noise. LOL...
also, changed out both upper and lower ball joints on the pass side. was a bi**ch. broke 2 sockets and a ratchet. good thing Sears swapped out all of my broken tools with no problems....
99 WJ, 4.7L, Quadratrac, 245/75/16.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #7419 of 43595 Old 01-05-2012, 12:34 AM
liquidxit2
Put the cargo husky liner in.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #7420 of 43595 Old 01-05-2012, 07:18 AM
sherker55
I'd be checking each time you fill up...
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline
post #7421 of 43595 Old 01-05-2012, 07:54 AM
mrJ
2002 KJ Liberty
Ordered an 18v Ryobi impact last night to go with the rest of my one+ set. Got the p260, which has 200 ft lbs. Sweet deal on eBay brand new. Waiting at an ihop right now to pick up a brand new Ryobi lithium hammer set for the battery and charger for $40 to add to my set. Also ordered ingersoll rand flip lugnut impact sockets too keep in the trunk so I can handle the lugs on anyone else's rig.
mrJ is offline
post #7422 of 43595 Old 01-05-2012, 10:09 AM
liquidxit2
Drove it to work and found out that the p.i.e. aux adapter is no longer working...
post #7423 of 43595 Old 01-05-2012, 10:11 AM
snobrdrkid07
snobrdrkid07's Avatar
Drove to the gym and found out that the passenger side heat isn't really working. Got the parking lot and heard my EVAP Purge thing under the hood happily clicking away. Only in a Jeep. D*** blend doors (Oh, I have manual controls for the HVAC system too, only my luck)
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #7424 of 43595 Old 01-05-2012, 11:59 AM
cbailey_21
What did I do to my wj today... What DIDN'T I do to my wj today..
All started as a waterpump/ thermostat job but I decided I wanted to check all the hoses and what not so I pulled the radiator, the electric and mechanical fan, thermostat out, water pump out, front skid plate off, front grille off, the fan housing, the cowling above the radiator, and the air filter housing.
Im In the process of getting a new water pump, new thermostat,new air filter and housing, buying hid bulbs for my headlights, and getting engine degreaser to clean up my oil/ coolant spill of an engine compartment.
Originally Posted by smuggler View Post
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #7425 of 43595 Old 01-05-2012, 12:09 PM
little_Jeep
(LOL).... I have done simple little repairs like this.. (LOL). They seem to grow larger and larger as I work I have the 4.0L with the Up Country skid on the front and have been told, that anytime I have access to that lower radiator hose, I need to replace it because it is a bear to get to.. (not something that can be done on the side of the highway).... Like I said, I haven't personally messed with this, but no repair is simple, quick, or easy on a WJ, so I'll assume what I was told is correct.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
tcpindy
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
