What did you do to your WJ today? - Page 49 - JeepForum.com
 789Likes
post #721 of 44783 Old 11-23-2010, 01:47 PM
xJoshxx
2012 WK
Originally Posted by Stout95YJ View Post
do you know of someone makes adapters from the 6 hole CV style flange to hold a regular u joint?
Carolina Driveshaft Give em Call. But they Will Tell you switching to a U-joint is SO much stronger.
To change the front yoke what the guy told me on the phone was use 1/4-1/2 impact something around 220ftlbs remove the pinion nut. tap the yoke on the ears to get it off. replace with the new yoke. put the nut on tighten it in increments. what he said was to remove any of the Lateral Play the in and out play if you tighten it and it still moves in and out a little tighten it some more.
He did stress DO not all let it to rotate. he suggested blocking the wheels or laying a brick or something on the brakes.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #722 of 44783 Old 11-23-2010, 02:39 PM
huntandfish
i need some schooling on the different driveshaft links
1992 YJ 2.5 SOLD
2004 Grand Cherokee Special Edition 4.0
IRO 3",JKS BPE's,DoetschTech8000's,Tenneco SS,Cooper Discoverer STT's 245-75R16,RC wheel spacers,SSBC Slotted Rotors, IRO Prem-sliders...
A great place for outdoorsmen in the NW.
Member Screen name- addicted
huntandfish is offline
post #723 of 44783 Old 11-23-2010, 04:28 PM
sherker55
Originally Posted by GraKee99 View Post
That cv joint on the driveshaft is going to keep failing at 3" of lift. Maybe not right away but it will. You should get a u-joint style at both ends.
+1 I don't know sqwat about this stuff! and now I'm concerned because I am at 3" of lift as well!
sherker55 is offline
post #724 of 44783 Old 11-23-2010, 06:49 PM
compcrasher86
Its still two towns away !@#$%*&^% I'm having an insurance mishap so it isnt registered yet. I have this box with all these parts/accessories and no Jeep to put them in. Grr
compcrasher86 is offline
post #725 of 44783 Old 11-23-2010, 11:52 PM
jtwilk99
2003 WJ
replaced hood and liftgate struts. hood - super easy. liftgate, bolts came off fine, however, took a little more effort than expected to get new ones on.
Hood now stands open all by itself.
Liftgate flips up hard enough to put a kid in orbit.
I'm guessing that will wear off after a while.
jtwilk99 is offline
post #726 of 44783 Old 11-24-2010, 07:33 AM
WillMcD
Got my zone nitro shocks on this morning.
04 WJ Limited Black, 5.5" LA hybrid (IRO Trackbar, Teraflex Springs, Bilstein 5100/5125 Shocks, IRO Critical Path High Clearance LA's + KOR 3/4" spacers, JKS Disconnects) 32" Firestone Destination M/T's, JCR Stage 3 Sliders, Black Moabs, Muffler Delete, Hella 700ff's, Yakima Load Warrior
Phil:4:13: I can do all things through Christ which strengtheneth me.
Originally Posted by billzcat View Post
a lot of people waste their life playing FB games all day like Farmville, Cityville, Gangsterville, Hookersnblowville, Idonteffingcareville
August 2011 GCOTM Winner
Build Thread:
WillMcD is offline
post #727 of 44783 Old 11-24-2010, 07:53 AM
EisBlade
EisBlade's Avatar
Wj Unable to run on water alone; add KOH.
I haven't done much to mine in a while; it has been running like a dream though expect to redo some of the fluids soon.
Project 1: The driver window catches, rolls on the rubber lip of the inner door frame and won't go down. The new part just arrived. $55.00...phbbbt.
Project 2: Getting my 29-plate HHO booster up and running has been the priority. I have a 50 amp gauge with external shunt on the way via eBay so I can wire it to the dash, but yesterday went ahead and bought a handheld ammeter so we can begin testing sooner. The goal is to dial in the electrolyte mixture so the system doesn't exceed a 30amp draw maximum. This should have my electrolyte (KOH (100% drain cleaner) and distilled water) concentration at about 2.7lbs to 1ga. which will also keep it from freezing in the winter cold. I expect to get an increase of no less than 30% MPG's (I'm currently at 18/27), but they think we will be able to pull more.
JT
Facebook: Harley-Davidson Touring Group
EisBlade is offline
post #728 of 44783 Old 11-24-2010, 09:08 AM
Twistedrocker
Unhappy
Where did you get the new struts from? Stealership? I'm sick of my hood falling on my head...
On topic I welded up some brackets for a new bumper.
'04 4.0l WJ: Clayton LA, 4.5" Teraflex Springs, d30 + ARB Locked d35, 32"x11.5"x15" BFG KM2, JKS disconnects
Twistedrocker is offline
post #729 of 44783 Old 11-24-2010, 09:33 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Bought mine off of e-bay ~3-4 years ago - still holding up great
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #730 of 44783 Old 11-24-2010, 10:10 AM
compcrasher86
Monroe Struts can be had for like $13 on rockauto. Best deal I've seen around and I trust the brand
Matt
post #731 of 44783 Old 11-24-2010, 12:47 PM
MORUNA
Wj
Last week ,i fix the radiator,check the injectors,cooland fluid,and change the tires(with
winter tires) we are close to the winter here.
MORUNA is offline
post #732 of 44783 Old 11-24-2010, 01:34 PM
g-off70
bought all of it yesterday:
water pump
thermostat
upper radiator hose
cooling system flush kit
stuff for an oil change
power steering fluid
brake fluid
new glove box
rear 12 volt outlet
headlight restoration kit
CB mount and antenna
probably some more but just forgetting
2000 WJ- midland cb w/PA, KOR leveling kit and shocks, 12 in infitity sub w/ 600 watt infinity amp, magnaflow highflow cat, dynomax cat back exhaust. much more to come
Geoff
WTB: Tow hooks- let me know if you have any
g-off70 is offline
post #733 of 44783 Old 11-24-2010, 03:52 PM
GhostKnife
bought and installed a Airraid Intake for $50
13 Ram Cummins, PPEI Tuned and Full Carli/Thuren. JK Arctic Edition 2dr Winter Chill
GhostKnife is offline
post #734 of 44783 Old 11-24-2010, 05:14 PM
miller63b
i just bought the yokes off e-bay or from junk yard from any dana 30 will work.... my u joint yoke for my dana was from a tj dana 30 and the t-case yoke i bought from e-bay... but im sure a junk yard would have the parts..... just count your splines ..... should be 27 at the diff and i think 32 at the tcase... dont quote me on that though
miller63b is offline
post #735 of 44783 Old 11-24-2010, 05:31 PM
cb0y1
Got a transmission input shaft speed sensor. to cold to change it until this weekend. At least the problem went away for now.
cb0y1 is offline
wj
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
BDW , johnnyboy559
