What did you do to your WJ today? - Page 458 - JeepForum.com
 600Likes
post #6856 of 43877 Old 12-08-2011, 01:48 AM
DiabloYJ
Originally Posted by PhantomWJ View Post
I would say to
Torque them down...star pattern...90 lbs...IIRC
But, that may be the wrong answer.
The ones that didn't fully back out completely sheared off. I would have to remove the case and drill them out, then hope that nothing else was messed up. I hate to submit to actually having to take my Jeep to someone to get fixed since I normally do all of my own work, but messing around with gears and knowing if something is damaged just by looking at it is above my head this time.
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline
post #6857 of 43877 Old 12-08-2011, 01:57 AM
srmitchell
That's no shame man. I do all my own work, but I leave gears to the professionals. It's worth it.
I work on Mopars
srmitchell is offline
post #6858 of 43877 Old 12-08-2011, 08:47 AM
Terminator2
Started cutting my fenders yesterday. Those rear fenders are such a pain to cut all the way through because the double thick metal. It was the first sheet metal cutting I have done like this so I took my time. It took me 2.5 hours to do just one rear fender, pinch weld, and plastic on rear bumper, about 1 hour was spent just cleaning up the sharp edges and gorilla gluing the two pieces of metal back together. Now that I know what to expect I think I can get the other rear done in less than 2 hours. The gorilla glue is holding the two pieces of metal together like a champ so far. Need to sand the gorilla glue down, then calk any holes that are left and need to pickup some spray in bedliner in a can to finish up. Doing the other rear fender this weekend as it is dark by the time I get home this time of year. Front fenders are not double thick so it should be easier than the rear except right at the rocker, the pinch weld, and the front part of the fender right where the bumper bolts up. I will post pics when I am finished. Gained 1.75" of clearance height in the rear (3.5" of width across so wheel well now measures 38.5" across as opposed to ~35" stock), would have liked to be able to cut another 1.0" higher but the rear wheel wheel height is only 1.75-2.0" max height inside and I wanted the fender line to be smooth not hacked up looking. The wheel wheel opening flows very nicely with the rear door now.
Front fenders are getting opened up about 3.25" up top and at least another 2.0-3.0" down the plastic bumper and door line (I will likely taper it because I already cut about 1.0-2.0" off the bumper), front pinch welds will be gone which makes 1.0" of extra room when turning and I will take a BFH to the inner wheel well near the pinch weld to smooth it out some. I should have enough room when I am done to run 35s with only 4" of lift or 37s with 6" of lift (my goal is to run 37 x 12.50 15 pitpull rocker radials). Should have waited before I bought my 31s because 33s will easily fit once I am done cutting with just the BB. Oh well I will be able to disconnect without any worry of rubbing no matter what.
Terminator2 is offline
post #6859 of 43877 Old 12-08-2011, 09:14 AM
blazepsi
Originally Posted by EisBlade View Post
1. Picked up my JK rims
2. Bought this. http://www.hhokitsdirect.com/Black_F...ut_Sale772.php
Im interested w/ No.2. Can you explain more about it and how much for the total Kit? Thanks...
blazepsi is offline
post #6860 of 43877 Old 12-08-2011, 09:56 AM
Dasko
Well I accidently put this pic in the wrong thread so if admin sees it in the picture thread please delete it. Thanks
Anyway new steering wheel grip thingie. Not bad being that it was free. Score!
Sent from my Mobile Thing using JeepForum
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #6861 of 43877 Old 12-08-2011, 12:49 PM
rockcrawlernut
Did the ZJ washer bottle mod today. I picked the ZJ washer bottle up from Pick-N-Pull a few weeks ago. I think it was $12.00 with the pumps. All though I didn't use them I used the stock WJ pumps. It took longer to remove the stock washer bottle then it did to install the new one.
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #6862 of 43877 Old 12-08-2011, 01:08 PM
Terminator2
I got my stock bottle out in less than two minutes just 3 bolts, 2 hoses and a couple electrical connectors. I just threw mine out. I do not use washer fluid ever really.
post #6863 of 43877 Old 12-08-2011, 02:30 PM
alwaysHI
2003 WJ
pics please? this has been plaguing my mind on how to tackle the job lately
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #6864 of 43877 Old 12-08-2011, 02:34 PM
mrJ
2002 KJ Liberty
X2
Build In Progress...
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #6865 of 43877 Old 12-08-2011, 06:18 PM
Linus
i see a lot of people do this, what's the advantage of swapping washer bottles?
Linus is offline
post #6866 of 43877 Old 12-08-2011, 06:31 PM
roadcrew
The stock one is behind the fog light. When you get bigger tires they tend to reach out and do a bottle delete for you. The mod puts it under the hood out of harms way.
roadcrew is offline
post #6867 of 43877 Old 12-08-2011, 06:34 PM
little_Jeep
Again, I learn sum thin knew today..
little_Jeep is offline
post #6868 of 43877 Old 12-08-2011, 07:35 PM
PhantomWJ
2003 WJ
Bought used bumstops and inexpensive wrenches...
PhantomWJ is offline
post #6869 of 43877 Old 12-08-2011, 07:39 PM
Linus
cool, is there a write up on the swap?
Linus is offline
post #6870 of 43877 Old 12-08-2011, 08:42 PM
mrJ
2002 KJ Liberty
Got my wrenches tonite too. Killer!
mrJ is offline
Currently Active Users Viewing This Thread: 6 (5 members and 1 guests)
DavisI , jeeptchr , MrAnderson83 , pkman , Russ02Overland
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
