What did you do to your WJ today? - Page 438 - JeepForum.com
 684Likes
post #6556 of 44188 Old 11-21-2011, 06:49 PM
thisguyhasadd2
is the overland track bar any different from the laredos? if so does it have a value?
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #6557 of 44188 Old 11-21-2011, 06:53 PM
gcjeeping
There are a few of us out there.
On topic... Thinking about putting the full doors back on before it snows. But its supposed to be almost 70 tomorrow.
gcjeeping is online now
post #6558 of 44188 Old 11-21-2011, 07:01 PM
theskier74
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #6559 of 44188 Old 11-21-2011, 07:48 PM
WJwheelin
Gj jeeping, those doors look pretty sweet. Make me want to buy a set and do something like that. Thanks man. Maybe I should start a green WJ thread
WJwheelin is offline
post #6560 of 44188 Old 11-21-2011, 10:04 PM
holdfast
Changed the Fuel Filter, and of course it was nasty. Changed all 8 spark plugs. Replaced both tail light housings, guy at the shop wanted to charge me $357 for the tail light housing replacement, total horse ****. Getting her inspected tommorrow.
06LJ 35" MTRs, 15x10 Pro Comps, TnT front fenders/rear armor, Warn bumper/tire carrier, Monstaliner
holdfast is offline
post #6561 of 44188 Old 11-21-2011, 10:42 PM
KingSmoth
1978 CJ5
Replaced u-joints on the front driveshaft today, no more grinding.
Did the dual zone blend door repair today, was actually pretty simple. Used a heat knife to cut behind the dash and put in the new doors, then used the knife to plastic weld the removed portion back to the HVAC assembly. Absolutely solid seal, looks good, no need to even layer sealing tape over it. It's nice to finally have functional A/C and heat! My 02 is a smooth ride now.
2002 WJ Overland - stock
1978 CJ5 - 350, 34's
1990 XJ Laredo - sold...
KingSmoth is offline
post #6562 of 44188 Old 11-22-2011, 01:52 AM
Trevino
Hey kingsmoth by any chance did you take some pics of the blend door install. I've gotta due this soon and pics always help.
Trevino is offline
post #6563 of 44188 Old 11-22-2011, 04:54 AM
Fishinmission
Love the doors! Do you have any pics of the interior portion?
Fishinmission is offline
post #6564 of 44188 Old 11-22-2011, 07:40 AM
gcjeeping
Here is a thred with more info.
On topic. Filled it up.
post #6565 of 44188 Old 11-22-2011, 08:15 AM
Low98Dime
Are you ever in tallmadge? I'm pretty sure I saw you a few weeks ago on the circle. Any sort of modded wj is rare around here, especially doorless ones.
Low98Dime is offline
post #6566 of 44188 Old 11-22-2011, 08:57 AM
Jeep32
The Jeep has been getting some lovin with winter approaching here in Wisconsin.
quick list of replaced parts:
Oil Pressure Sending Unit
Throttle Position Sensor (TPS)
Front Pads
Rotors
Both Wheel Bearing Hubs
Tires
Air Filter
Miscellaneous Evap tubes to "try" and "fix" P0456
"so i did a full tune up soup to nutts."
4.7 213k+
Jeep32 is offline
post #6567 of 44188 Old 11-22-2011, 12:27 PM
alifted4x4
2009 JK Wrangler
Started the dash pulling process to do my heater core......
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #6568 of 44188 Old 11-22-2011, 12:35 PM
little_Jeep
I hope you have parts in hand.....
little_Jeep is offline
post #6569 of 44188 Old 11-22-2011, 01:57 PM
thisguyhasadd2
I have the fault codes 46 and 52, recirc motor not responding and door travel to large.... my air recirc works perfectly fine the motor opens and closes the door great! What the heck, my only complaint with my hvac is that it doesnt blow hard enough or equally through all the vents... i just checked my blower motor and its spinning counter clockwise which seems to be the right direction...
post #6570 of 44188 Old 11-22-2011, 02:11 PM
alifted4x4
2009 JK Wrangler
going to get them today. I work the next two days so I will finish this weekend.
wj
WJ_MOOSE
