What did you do to your WJ today? - Page 397 - JeepForum.com
 912Likes
post #5941 of 45332 Old 10-17-2011, 04:20 AM
JerseyWJ
JerseyWJ's Avatar
2015 WK
New windshield, starter, hvac control module...then I lit some of my money on fire and threw it in the ocean.
Altitude
JerseyWJ is offline
post #5942 of 45332 Old 10-17-2011, 04:49 AM
compcrasher86
Originally Posted by N3KRV View Post
yea I know I have a ZJ now whenI got it belive it or not whenI went to get my key cut the dealer told me it was a WJ so that is what I used whenI put the profile here and joined I don't know if it can be moved to the ZJ forum or not or even if it is worth it now. Update on mypower steering leake, it's not the pump or hoses they are all fine, it's the power streeing gear box that's squirting fluid out, now I have to decide do I want to replace it compleatly or just redo the seals.
and while I was talking to a mechanic about it I noticed teh passenger side front door was slightly out of alignment and bent out so I opend the door and bend the frame back in the 1/4" it was pulled out then I notices a LOT of small scratches and dents, someone TRIED to pry the door open to try and unlock it! I called the police and filed a report and they said they typically do not see this type of B&E, it's usually Smash and Grab around here! they said it was good I had the club on it and nothing visable for them to steal, and I called my insurance co. they are sending out an adjuster to take a look at it and cut me a check for the repairs. so does anyone know how to fix the alarm that came with these ZJ's????
Tell us what dealer it was so we know never to go there lol!
On the ZJs the alarm will not go off if somebody tampers with your door until they actually get it open. It only monitors the ignition and the door switches so it has no clue whats going on until the door is opened. If they also manage to start the car with the alarm enabled, the ZJ will also kill the engine after a second or two. If you want to test it lock the Jeep with the window open then wait 20 seconds. The light in the windshield should be flashing red slowly. Reach in through the window and open the door. If alarm goes off the factory system is working correctly. Disarm with key fob or using key in the door. For reference our WJs are the same but you can disable the alarm and start the Jeep with a programmed SKIS Key in the ignition.
Matt
compcrasher86 is offline
post #5943 of 45332 Old 10-17-2011, 05:29 AM
Fawkes
Originally Posted by alifted4x4 View Post
No the mileage is on the cluster. I had to write down the old mileage and the new mileage.
Actually it's stored both in the cluster and the ECM. The cluster will display the mileage of the cluster, but the ECM holds the original (true) mileage numbers so that folks can't roll back just by changing the cluster out.
Fawkes is offline
post #5944 of 45332 Old 10-17-2011, 09:31 AM
alifted4x4
2009 JK Wrangler
Thanks I did not know that.
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #5945 of 45332 Old 10-17-2011, 11:56 AM
wj4play
Originally Posted by dmextreme77 View Post
Without further adue.. photos and vids from this weekends trip to Harris, MO.
Aside from losing a spring and having the time of my life, here r the pics.
A place called Middle of No Where. A new place we are creating for Jeep offroading.
Middleofnowhere-mo.com
Middle Of No Where Trip
Waaaa, I think i have passed you a few times around DSM.. awesome pics
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #5946 of 45332 Old 10-17-2011, 01:48 PM
MavericG07
2003 WJ
decided I would post this pic because I think it's awesome. I need to repaint my front jeep emblem though because mine didn't turn out to well with the $0.97 rattle can
MavericG07 is offline
post #5947 of 45332 Old 10-17-2011, 01:52 PM
MavericG07
2003 WJ
This is actually from a week ago but I found a street in the middle of a field with a sign that said Overland Tr. so naturally I went exploring
http://a5.sphotos.ak.fbcdn.net/hphot...12870125_n.jpg
Yup. I just figured out how to upload photos. Bring it on world!! Ps. you can see that my Jeep emblem on the front didn't turn out all that well (plus now it's dirty)
post #5948 of 45332 Old 10-17-2011, 01:52 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Looks like your jeep is on the "hunt" for some yotas in the African Savannah!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5949 of 45332 Old 10-17-2011, 01:53 PM
MavericG07
2003 WJ
My Jeep emblem
post #5950 of 45332 Old 10-17-2011, 01:58 PM
mreed21
Ordered a blend door kit kit from the dealer that goes through the dash. It was $120 with tax!
mreed21 is offline
post #5951 of 45332 Old 10-17-2011, 01:58 PM
MavericG07
2003 WJ
yeah. I live in Texas so it's pretty flat and dry here. I still found it to be quite fun to go driving around in a field
post #5952 of 45332 Old 10-17-2011, 03:02 PM
alifted4x4
2009 JK Wrangler
Part # and pics please.
post #5953 of 45332 Old 10-17-2011, 03:14 PM
mreed21
I will put pictures up tomorrow. They had to order it.
mreed21 is offline
post #5954 of 45332 Old 10-17-2011, 03:27 PM
Planetcat
2010 WK
Wj
Originally Posted by TJSWJ View Post
where did you get your spacers at? Ive been looking at spidertrax but there website only list 1 1/4 for the wj.
Rough country sells the 1.5" spacers. I have them on my XJ and they are just as good as the spidertrax ones I have on the WJ.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #5955 of 45332 Old 10-17-2011, 03:49 PM
Thomahawk
been Droooooling on this 04HO today.
http://www.finn.no/finn/car/used/vie...nkode=31168458
Sent from my Iphone4
Buildthread
Thomahawk is offline
wj
