What did you do to your WJ today? - Page 395 - JeepForum.com
 1086Likes
post #5911 of 45717 Old 10-15-2011, 09:45 PM
alifted4x4
2009 JK Wrangler
Originally Posted by bushido7seven View Post
How did you do that ? Where can I find this
I bought a cluster out of a 2002 limited. Look for some one parting one out or check the local junk yards.
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #5912 of 45717 Old 10-15-2011, 10:37 PM
theskier74
do they light up in the back?
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #5913 of 45717 Old 10-15-2011, 10:55 PM
85IrocZ-28
Does the mileage get stored in the computer (and your true mileage is listed on the newer dash?)
Today I cursed the jeep, and the idiots that installed my RK shocks. If you don't own a bottle of anti seize, buy yourself one. It is one of the best things you can do when working on a Jeep to make sure the bolts will come out the next time you need to remove them.
If you don't use it, you may end up having to weld another bolt to the broken section, and a large nut over the top so that you can get two wrenches on it at the same time to get it out.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #5914 of 45717 Old 10-16-2011, 01:32 AM
N3KRV
Zj Finally got my cooling system all fixed
Originally Posted by mrJ View Post
$100 just to change pads is a little steep.... Unless it was all 4 wheels
Well it was for all 4 wheels, on another not after replacing the radioator, hoses thermostat I still had a water leak, I figured out it was the water outlet it was cracked! I went and bought a new water outlet, gasket and thermostat, got the bolts off and whenI pulled up on it the bottom of the water neck housing broke off! I cleaned the surfaces off with my dremel to make totally sure that it was spotlessly clean, I didn't like the idea of using silicone gasket sealent so I got the old fashioned permatex gasket shallac and put that on but the lower housing bolt did NOT want to line upthe sepentine belt was in the wayI worked and worked onit but could NOT get the bolt to start, a neighber was walking by and said he was a Mechanic and helped me and it even took him 2 hours to get that damned thing to line up and get the bolt in, we finally got it all assembled and tightend up and saw that there was NO LEAKS! FINALLY!!!!! but I kept hearing a buzzing sound and found out the power steering pump was empty! which was strange I had jsut filled it up a month ago, I drove it over to the nearest tire place and had the front two rims changed to the same gold alloy rims and just in the 10 minutes it saw in their parking lot there was a small puddle of what at first Ithought was water but checked it and it was oil, I checed the power steering fluid level and it had all leaked out!, I thought well hell! the guy said that since it has sat for a while the pump seals probly all dried out and cracked, so now Ihave to replace the power steering pump, and I might as well have the serpentine belt replaced as well, then hopefully I won't have anymore problems! I also got the gold letterings for "JEEP" "Grand Cherokee" and "4.0 Liter" put on her along with all 4 Gold alloy wheels, and chrome "laredo and $x$ Badges, so she actually looks a lot better now.
N3KRV is offline
post #5915 of 45717 Old 10-16-2011, 02:15 AM
N3KRV
BTW does anyone know where i can get the proper Center caps for my gold alloy wheels? I picked up some silver ones thining they woudl fit and was going to put the black jeep stickers on them BUT they are slightly too small. i've looked on ebay but can't seem to find any.
Thanks
N3KRV is offline
post #5916 of 45717 Old 10-16-2011, 09:08 AM
thisguyhasadd2
ha the hero thing is a joke between friends as i dont really drive the jeep unless im going camping ..... enduro ftw 80mpg
thisguyhasadd2 is offline
post #5917 of 45717 Old 10-16-2011, 09:29 AM
RedlegWJ
Where can I get a HERO decal?
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #5918 of 45717 Old 10-16-2011, 09:52 AM
justn
Take off GRAND C KEE and boom! Instant HERO badge.
My Build Thread for the old WJ
http://www.jeepforum.com/forum/f197/justns-build-thread-1236882/
justn is offline
post #5919 of 45717 Old 10-16-2011, 10:35 AM
ctwistedpair
ctwistedpair's Avatar
Wj Seized lugs
Installed my 1 1/2 inch wheel spacers today. 2 lugs on the passenger rear were seized, had to be burned off. Nasty bit of work. cutting torches near fuel tanks make me nervous.
ctwistedpair is offline
post #5920 of 45717 Old 10-16-2011, 10:40 AM
GearHead84
2003 WJ
My I6 sounds like a V8!
Couple nights ago threw on the K&N intake, yes there is a noticeable difference with throttle response and torque. No I will not have any problems with dirt/dust getting in the motor, if you keep it oiled and clean as designed you will be fine. This morning I threw on a 2.5" pipe and a Flowmaster Delta 50. I notice a lot of people going with the 70 series. If you like a deep mellow tone, I highly recommend the 50 series. I built a Camaro years ago and it had a full exhaust and E-cut out: LOUD even at idle. Flowmaster 50 on a Jeep: QUIET. Mild rumble at idle, NO noise on the highway, nice deep rumble while accelerating. Finally, obvious gains in throttle response and torque.
GearHead84 is offline
post #5921 of 45717 Old 10-16-2011, 10:43 AM
snobrdrkid07
Hey man, you have a ZJ there... WJ's are from 1999-2004
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5922 of 45717 Old 10-16-2011, 11:03 AM
TJSWJ
where did you get your spacers at? Ive been looking at spidertrax but there website only list 1 1/4 for the wj.
TJSWJ is offline
post #5923 of 45717 Old 10-16-2011, 11:06 AM
JRobes
ya... they glow light green
JRobes is offline
post #5924 of 45717 Old 10-16-2011, 01:21 PM
Blkdvll
Quick detail. Ran out of dressing for the trim though.
Also, pick of the Rola from Friday
2004 4.0L w/242 WJ - Front tow points, Rear D Shackel, 3"/2.5" lift, 245/75 Falken ATs, Sway Bar delete, Overland Sliders, T-Case Skid, Hella 500's, Halved Bumper, Custom Rad.Core Skid, Soft 8's, MV50 OBA, Hi-lift/lift mate, shovel, (1st)On-Board Cooler, OME S.S., Rola Basket.....more soon
Blkdvll is offline
post #5925 of 45717 Old 10-16-2011, 02:41 PM
snobrdrkid07
Looking really good man!
-Michael-
wj
alfaitalia
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
