What did you do to your WJ today? - Page 394 - JeepForum.com
 1102Likes
post #5896 of 45739 Old 10-15-2011, 01:37 AM
Trevino
Originally Posted by alifted4x4
Bought some fluids...... I forgot how EXPENSIVE this stuff was!!!!!
Also installed my K&N Kit!!
Hmm do you use the limited slip additive together will the royal purple gear oil?? When I was gonna service my diff for the first time and got the royal purple I called up their customer service. They said their oil already has it added in. You think I messed up by not adding any??
Trevino is offline
post #5897 of 45739 Old 10-15-2011, 04:36 AM
Thomahawk
2006 XK Commander
I used the RP to in my diffs, got bindings, had to add about 3/4 bottle of FM in each to make it Go away, its different from diff to diff. Fill them up with RP, if you are not having any bindings you are good, if you have bindings, add FM a small amount at the time until it goes away.
Sent from my Iphone4
Buildthread
Thomahawk is offline
post #5898 of 45739 Old 10-15-2011, 08:45 AM
Trevino
Alright thanks guys. I didn't get any binding issues back when I did it so I thought I was good to go, then saw this and started to second guess myself.
Trevino is offline
post #5899 of 45739 Old 10-15-2011, 08:50 AM
Thomahawk
2006 XK Commander
If you aint have bindings you are all good, if you have you must add FM to it goes away.
To stay on topic, polished and put sealent on my hood today.
Buildthread
post #5900 of 45739 Old 10-15-2011, 10:22 AM
slimwj
Installed 2" bds coils and skyjacker nitros. Also put on some 245/75 falken rocky mtns.
ForumRunner_20111015_101933.jpg   ForumRunner_20111015_102020.jpg   ForumRunner_20111015_102110.jpg
slimwj is offline
post #5901 of 45739 Old 10-15-2011, 10:53 AM
blazepsi
Ohhh..Nice. Your My twin Jeep, you ts look better coz you got roof roack and Trail rated Badge..
blazepsi is offline
post #5902 of 45739 Old 10-15-2011, 02:46 PM
ifritzwj
2005 WK
Got hella 550s and still trying to figure out how to wire em.
ifritzwj is offline
post #5903 of 45739 Old 10-15-2011, 04:47 PM
alifted4x4
2009 JK Wrangler
Got some stuff today!!! A new to me front and rear bumper, front driveshaft with yokes, and bug shield
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #5904 of 45739 Old 10-15-2011, 04:56 PM
compcrasher86
Use a relay. Ground the lights to the front bumper or upper radiator bracket. Run power of lights to the terminal 87 (not 87a) of relay run the 30 of relay to the battery and put a fuse right near the battery. Terminal 85 on relay to ground and terminal 86 should go to your switch, other side of the switch should go to power from the ignition or cig lighter
Matt
compcrasher86 is offline
post #5905 of 45739 Old 10-15-2011, 05:35 PM
alifted4x4
2009 JK Wrangler
Also changed out my cluster!!!! Went from black to white!!!
post #5906 of 45739 Old 10-15-2011, 06:23 PM
thisguyhasadd2
Detailed and headlight restore
thisguyhasadd2 is offline
post #5907 of 45739 Old 10-15-2011, 07:58 PM
compcrasher86
Hero? Seriously?
Matt
post #5908 of 45739 Old 10-15-2011, 09:10 PM
alifted4x4
2009 JK Wrangler
Originally Posted by compcrasher86 View Post
Hero? Seriously?
post #5909 of 45739 Old 10-15-2011, 09:20 PM
snobrdrkid07
snobrdrkid07's Avatar
Hero? Seriously?
Originally Posted by alifted4x4 View Post
AGREED!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #5910 of 45739 Old 10-15-2011, 09:31 PM
bushido7seven
How did you do that ? Where can I find this
bushido7seven is offline
wj
Redjeepwj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
