What did you do to your WJ today? - Page 357 - JeepForum.com
 826Likes
post #5341 of 45000 Old 09-14-2011, 03:34 PM
4x4Jeep
i did spray it on evenly. i don't need it perfect..as long as it looks decent from a distance.
Build -
SOLD
4x4Jeep is offline
post #5342 of 45000 Old 09-14-2011, 03:36 PM
alwaysHI
2003 WJ
i'll take your word, not downing you or anything dude. its just one of those "pictures dont do it justice" kinda things, come to Hawaii so i can see it for myself, and you can enjoy the weather
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #5343 of 45000 Old 09-14-2011, 06:39 PM
GearHead84
2003 WJ
Installed OME HD springs & 5100 shocks on all four corners, Rancho SS, JKS adj. Trac-bar, and new coil isolators. Thanks to Kolak for all of these parts and GREAT customer service and information while trying to make up my mind. It rides GREAT...no issues with any of the parts not fitting right, as i've read in some threads here.
Before:
After:
After with 245/75/16 Duratracs:
I took measurements in the dark, so they were VERY rough, but the average was close to 3" all around. The Jeep seems to sit close to level at this point. Hopefully in for tires and alignment this weekend. Will post an update when everything settles in.
GearHead84 is offline
post #5344 of 45000 Old 09-14-2011, 06:49 PM
compcrasher86
I noticed it too. I'm assuming its just the picture but its noticeably darker around the edges. Not my slice of pie so I'm not one to judge.
Today I took my WJ to work and realized I havent washed it in 2 months. It really... really... looks god awful. Going to the self serve bay tomorrow.
Matt
compcrasher86 is offline
post #5345 of 45000 Old 09-14-2011, 07:07 PM
240impala
2003 WJ
Developed death wobble from hell today
"Don't Do It"
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #5346 of 45000 Old 09-14-2011, 07:19 PM
alwaysHI
2003 WJ
i've been there...hope you get it fixed and its an easy one bro
Build Thread -
SOLD
alwaysHI is offline
post #5347 of 45000 Old 09-14-2011, 07:54 PM
240impala
2003 WJ
Thanks man the steering stabilizer is pouring so I hope thats it.
"Don't Do It"
post #5348 of 45000 Old 09-14-2011, 07:57 PM
narnwv
narnwv's Avatar
a broken stabilizer will NOT cause DW. A good one will only mask DW. You don't need a SS at all, so if you've got DW, something other than the SS is the cause, and that's caused your SS to die an early death.
~Aaron
narnwv is offline
post #5349 of 45000 Old 09-14-2011, 08:06 PM
compcrasher86
I dont know how I dont have death wobble... I'm running worn out stock suspension, my rear A-arm has a good centimeter of play due to blown bushings, I dont have a rear sway bar, my steering stabilizer is completely shot, my shocks are shot, and one of my TREs is questionable. Suspension/steering overhaul next summer
Matt
post #5350 of 45000 Old 09-14-2011, 08:22 PM
240impala
2003 WJ
everything on my front end is tight. It only happens when I hit a bump going around 30 and I cant get it to stop unless a come to a complete stop.
"Don't Do It"
post #5351 of 45000 Old 09-14-2011, 08:39 PM
theskier74
sounds like my suspension exactly
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #5352 of 45000 Old 09-14-2011, 09:15 PM
deathwobblez
2003 WJ
If you haven't dealt with it before, put it on the asphalt so there is good friction on the tires, have someone work your steering wheel back and forth while you are looking at your front end. See if anything is wiggling when it doesn't look like it should, TRE's, trackbar joints.
**For Sale**2003 WJ Laredo 4.0 /JK Rubicon Wheels/4" Teraflex/MX6 Shocks/Flowmaster 40/Magnaflow Cat/OBX Header/Superchips Flashpaq**For Sale**
deathwobblez is offline
post #5353 of 45000 Old 09-14-2011, 09:40 PM
4x4Jeep
i know man. if i don't like florida weather i doubt i'll like hawaii weather, haha.
i see what you mean, i don't know why it looks like that. i can always go to a JY and pickup some cheap ones if i were to do it over.
the 1st one i did which was the driver's side, it started to drip when i applied the 1st coat of vht. but i just left it as is. i guess i might do one shade darker, we'll see.
Build -
SOLD
4x4Jeep is offline
post #5354 of 45000 Old 09-14-2011, 09:44 PM
240impala
2003 WJ
everything is in tact like it should be really. Tie rod is tight, tre are tight, track bar control arms, drag link the whole nine yards
"Don't Do It"
post #5355 of 45000 Old 09-14-2011, 11:41 PM
deathwobblez
2003 WJ
I understand. I dealt with death wobble for a year. Ended up being one tie rod end that went bad after replacing both on the tie rod. Didn't see it until I had someone work the steering on asphalt. There was not enough friction on my concrete driveway, but on the asphalt it torqued the components just enough.
You may need to get a lever under your wheels and check ball joints as well.
wj
Cerbere , Kxf327
